FX 8350 CPU Temperature: Is 60-62 Degrees High During Load? (AMD, Processor, Overheating)
Marcinelolo 6657 16
Is 60-62°C under load too high for an FX-8350 CPU?
60-62°C under load is generally acceptable for an FX-8350, because AMD lists about 61-62°C as the safe maximum for the FX-8xxx core temperature [#17143497][#17147349] Make sure you are checking the right sensor: use HWinfo64 in “Sensors only” mode and look for “CPU Package” or “Core temp,” since SpeedFan can be misleading on AMD CPUs [#17143497][#17147349] AMD OverDrive is also recommended; its “Thermal Margin” value is the key number to watch [#17147349] If you run Prime95 SmallFFT for 20-30 minutes and still have at least a 10-15°C margin, the cooling is fine [#17147349] If the system is stable and does not cut clocks or shut down, the temperature is not an immediate problem [#17143497]
  • #1 17142619
    Marcinelolo
    Unfortunately, I am the owner of FX 8350: /
    Are the load temperatures between 60-62 degrees high?
  • #2 17142846
    Radek1024
    Replace the cooling with a larger one as soon as possible. I also have an FX and in my opinion the standard heat sink is a failure
  • #3 17142849
    Marcinelolo
    Hah, only that I have a cooling better than silentium pc spartan, but I do not remember the exact name
    And that's how it holds 60 degrees in games
    At rest about 30 degrees
  • #4 17142866
    Radek1024
    This is probably the norm for such a temperature.
  • #5 17142867
    Marcinelolo
    May I want to get rid of it in 3 months and buy a new processor ...
  • #6 17142871
    Radek1024
    Honestly, I have to tell you that I am already in the fourth year of this fx and it's not bad, but I am also slowly thinking about something stronger.
  • #7 17142893
    Marcinelolo
    I've had it since November 10, 2015
    Honestly, it is also not bad, but I want this pubg game, which has terrible optimization
    I am thinking about buying the i5 8400
  • #8 17143467
    310artur
    Help: 980
    Rate: 670
    So over a new computer? Because on this CD you won't install it.
  • #9 17143471
    Marcinelolo
    Exactly
    I leave only the graphics and the power supply
  • #10 17143477
    310artur
    Help: 980
    Rate: 670
    And 62 degrees as max is a good temperature for basically any CPU.
  • #11 17143482
    Marcinelolo
    Thanks for talking because I was circulating on the internet and someone wrote that 62 degrees is max for fx
  • #12 17143497
    310artur
    Help: 980
    Rate: 670
    https://www.amd.com/en/products/cpu/fx-8350
    AMD even gives 61. The only question is where the temperature should be. These are usually the temperatures that are difficult even to measure. At Intel it seems the surface of IHS.
    Since it works stably, it does not cut the clocks, it is good.
    What do you even read these temp? Most people find reading from AMD OverDrive the most reliable
  • #13 17143501
    Marcinelolo
    Unfortunately, I'm not in it like that and I look at the temperature only thanks to the speedfan program
    Everything works fine, but what I should do to reduce the temperature in this prock because I read on the internet that it is difficult to keep the temperature on this prock below 60 degrees
  • #14 17143519
    310artur
    Help: 980
    Rate: 670
    You can fight, but why. Power-hungry processor, you've given better cooling. Let it be that way.
    I do not have AMD myself, I will not check it, but in AMD OverDrive it seems the distance to the maximum temperature is given.
    Speedfan as such is a very old program. I'd rather skip it. AMD OverDrive should give you speed controls too. And if you need to read the temperature from more sensors, you still have HWiNFO in sensor only mode. It will read everything it can (and maybe a little more of what cannot).
  • #15 17143525
    Marcinelolo
    The most important thing is that at these 62 degrees, nothing will happen, in addition, when I want to sell almost the entire computer to my friend because he plays on a cheap laptop and better such fx than a laptop where barely on low has 40 frames in cs go
  • #16 17146253
    hexon6
    Rate: 14
    I also get very hot fx-6300 (especially when I raise the tension and timing a little) and I fight it all the time. From what I remember, it used to be much lower in temperature. After some time, these processors do not work well and this is the norm. It looks as if there was a glut under the cap and with time the paste of poor quality lost its usefulness, but these processors are soldered ... Anyway, what settings do you have this fx on now?
  • #17 17147349
The discussion centers around the temperature of the AMD FX 8350 CPU, specifically whether 60-62 degrees Celsius under load is considered high. Responses indicate that these temperatures are generally acceptable for the FX series, with some users suggesting that the standard cooling solutions may be inadequate. Recommendations include upgrading to better cooling systems and using software like AMD OverDrive or HWinfo64 to monitor temperatures accurately. Users also mention the importance of thermal margins and the built-in safety features of the CPU to prevent overheating. Overall, while 60-62 degrees is within the normal range, some users express a desire to upgrade to more powerful processors due to performance limitations.
TL;DR: On FX‑8350, 61°C max core temp is the spec; "AMD even gives 61." If it’s stable and not throttling, you’re fine. Use AMD OverDrive or HWiNFO for reliable readings. [Elektroda, 310artur, post #17143497]
Why it matters: Knowing true safe temps helps you avoid throttling and plan cooling or upgrades if you game or overclock.
Is 60–62°C under gaming load high for an AMD FX‑8350?
It’s near the FX‑8xxx core limit, but still acceptable if stable. Verify using HWiNFO’s CPU Package/Core temperatures, not socket. Keep cores at or below 62°C. If clocks hold and you see no stutter or errors, you’re within safe operating range. [Elektroda, Anonymous, post #17147349]
Which temperature should I trust on FX—Package, Core, or Socket?
Monitor CPU Package or Core temperature in HWiNFO. Treat 62°C as the upper limit for FX‑8xxx cores. Socket readings can differ and mislead. Focus on core values when assessing safety and cooling adequacy. [Elektroda, Anonymous, post #17147349]
How do I test my FX‑8350 thermal headroom with AMD OverDrive?
Use Thermal Margin in AMD OverDrive.
  1. Install AMD OverDrive and open Thermal Margin.
  2. Run Prime95 SmallFFT for 20–30 minutes.
  3. Ensure Thermal Margin stays 10–15°C or more; increase cooling if it shrinks. [Elektroda, Anonymous, post #17147349]
Is SpeedFan reliable for AMD FX temps? What should I use instead?
Skip SpeedFan; it’s an old tool. Use AMD OverDrive for reliable AMD temperature reads and fan controls. For a comprehensive sensor view, run HWiNFO in Sensors‑only mode. These tools provide better accuracy on FX systems. [Elektroda, 310artur, post #17143519]
What happens if my FX‑8350 hits its temperature limit?
FX CPUs have built‑in protection. Approaching the limit triggers throttling, a restart, or a shutdown to prevent damage. It will not suddenly burn at 62°C. Maintain a thermal margin to avoid protective actions during heavy loads. [Elektroda, Anonymous, post #17147349]
Will the stock FX cooler be enough, or should I upgrade?
Users report the standard heatsink as inadequate on FX. Replacing it with a larger aftermarket cooler can reduce load temperatures. If you observe high temps or noise, a bigger tower cooler is a practical improvement. [Elektroda, Radek1024, post #17142846]
Are ~30°C idle and ~60°C in games normal on FX‑8350?
Yes, a user reported around 30°C at idle and about 60°C in games with aftermarket cooling. Those figures are normal if the system stays stable and core temps remain under the limit. [Elektroda, Marcinelolo, post #17142849]
Why does the FX‑8350 run hot compared to newer CPUs?
Its TDP is 125 W, which means higher heat output under sustained load. You need stronger cooling to hold safe core temperatures during gaming or productivity tasks. [“AMD FX-8350 | AMD”]
Can I install an Intel i5‑8400 on my AM3+ motherboard?
No. The i5‑8400 uses a different socket and platform. You cannot install it on an AM3+ board. Plan on a motherboard replacement when upgrading from FX to that CPU. [Elektroda, 310artur, post #17143467]
How do I tell if the CPU is throttling due to heat?
Watch for clock drops and instability under load. "Since it works stably, it does not cut the clocks, it is good." Use AMD OverDrive to monitor behavior; if clocks hold, cooling is sufficient. [Elektroda, 310artur, post #17143497]
My FX temps rose over time—what’s going on?
One owner saw higher temps over time, especially with increased voltage and tighter timings. FX chips are soldered under the IHS, so internal paste isn’t the usual culprit. Voltage and aging can increase heat output. [Elektroda, hexon6, post #17146253]
Do FX CPUs use solder under the IHS? Can I delid?
Yes, AMD FX CPUs use solder under the IHS. Delidding is uncommon and not a typical path to better temps. Focus on cooler capacity and airflow rather than removing the IHS. [Elektroda, Anonymous, post #17147349]
Is 62°C a universal safe max for all CPUs?
One participant claimed 62°C is a good max for basically any CPU. Do not assume this universally; always check your processor’s specific thermal guidance and monitoring method. [Elektroda, 310artur, post #17143477]
How can I lower FX‑8350 temps without chasing perfection?
Use AMD OverDrive to set fan speeds and verify temps, and view full sensors in HWiNFO. Avoid SpeedFan. The FX is power‑hungry, so a few degrees won’t matter if clocks remain stable. [Elektroda, 310artur, post #17143519]
