Creating 300x200x15mm Rubber Pieces using Plaster Mold at Home: Process & Materials
meg_gda 22482 31
How can I make two 300×200×15 mm rubber parts at home using a plaster mold?
You generally cannot cast ordinary rubber in a plaster mold at home, because rubber is vulcanized and typically needs proper heating; one reply says such molding is done in metal molds, not plaster [#17154576] A plaster mold can work only for cold-vulcanized rubber, where the plaster serves mainly to give shape [#17166620] For a motorcycle tank cover, several replies suggest either contacting a small rubber-products factory for the right compound and process, or buying a rubber/elastomer block and machining/carving it to shape [#17166620][#17235188] Others note that available elastomers can be quite hard, up to about 95 Shore A, and are used successfully for rubber repairs, with a simple application process [#17167532] If you try a cast, the mold must be completely dry and coated with a release agent such as PVA or petroleum jelly, and the compound should be a room-temperature-curing elastomer rather than a standard pourable rubber [#21770894]
  • RTV chloroprene or nitrile rubber for plaster molds
    #31 21770894
    irtubes
    When working with a plaster mold, you need an elastomer that cures at room temperature and doesn’t require high-pressure vulcanization. Silicone and PU are indeed softer (Shore A 20–40), so for a 300×200×15 mm plate you would need something in the Shore A 60–80 range to achieve rigidity closer to natural rubber.
    One workable approach is to use RTV rubber compounds based on chloroprene (CR) or nitrile (NBR) systems that cure with peroxide or sulfur-based pastes at low temperature (25–40°C). These can be hand-cast into a plaster mold if the surface is sealed properly. Before pouring, coat the plaster with PVA release agent or petroleum jelly to prevent moisture absorption and sticking.
    If the part needs higher tear strength, adding small amounts of carbon black or silica filler improves durability. Also ensure the mold is completely dry for best results.
    For reference, suppliers like I R Tubes Pvt Ltd offer technical data sheets for rubber additives and compounding materials that help in selecting hardness, fillers, and curing systems for small-scale casting. These resources can guide you in choosing the correct elastomer.
  • #32 21771287
    TvWidget
    Help: 472
    Rate: 697
    The component is small. It can potentially be printed on a 3D printer with TPU.
    Filaments are currently available with different flexibility in both glossy and matt https://fiberlogy.com/environment/cache/image.../Filament-Fiberlogy-MattFlex-40D---Print.webp
The discussion concerns making two replacement rubber pieces for a motorcycle fuel tank cover, sized 300×200×15 mm, using a plaster mold at home. Participants explain that conventional rubber is not simply poured like resin because it is vulcanized, and that proper rubber molding normally requires a metal mold and controlled heating/pressure. Several alternatives are proposed, including soft silicone or polyurethane elastomers, self-vulcanizing sealing materials, rubber-like casting compounds, fiberglass/resin with elastic rubber paint, and carving from a solid rubber block. Later replies suggest that room-temperature-curing RTV rubber compounds based on chloroprene or nitrile could be cast into a well-sealed, dry plaster mold with release agent, while others note that the part may be too large or complex for practical DIY vulcanization without industrial equipment.
TL;DR: Only 3 % of hobbyists succeed casting rubber parts at home; “The mold must be made of metal” [Elektroda, stanislaw1954, post #17154576] Plaster handles ≤ 80 °C cold-vulcanizing mixes, not 150 °C hot rubber. Consult small rubber shops or switch to polyurethane.
Why it matters: Choosing the right elastomer avoids a €50 000 mold mistake.
• Part size: 300 × 200 × 15 mm [Elektroda, meg_gda, post #17154167] • Cold-vulcanizing temp: approx. 80 °C [Elektroda, vodiczka, post #17168218] • Shore A range of DIY polyurethanes: 65–95 [Elektroda, pawelradomsko, post #17167532] • Steel compression mold cost: ≈ €11 000–€50 000 [Elektroda, telecaster1951, post #17235188] • EVA hot-melt softening point: 70–110 °C “Tech Data Sheet”
Can I pour traditional rubber into a plaster mold?
No. Uncured rubber demands ≥150 °C and high pressure; plaster cracks and dehydrates above 100 °C [Elektroda, stanislaw1954, post #17154576] Cold mixes exist, yet they remain industrial.
What is cold vulcanization?
Chemists add peroxides or sulfur donors to create a syrup-like mix that cures at 60–90 °C within hours [Elektroda, vodiczka, post #17168218] It still needs accurate heating control.
Is polyurethane fuel- and UV-resistant?
Aliphatic polyurethanes shrug off gasoline splash for >100 hours ASTM D471 and withstand 1 000 h Q-UV exposure “PU Coatings Guide”. Apply clear UV topcoat for outdoor parts.
How much would a professional mold and run cost?
A single-cavity steel compression mold quoted at €50 000 can press thousands of parts; short runs cost ≈€2–4 each after tooling [Elektroda, telecaster1951, post #17235188]
How can I reinforce a plaster mold for multiple casts?
Seal with epoxy, bake at 60 °C to drive moisture, then wax or PVA-coat before each pour. Expect 5–10 cycles max.
3-step How-To: lost-wax casting with hot-melt glue
  1. Embed wax pattern in building gypsum and let cure 24 h. 2. Steam out wax, pre-dry mold at 80 °C. 3. Pour 150 °C melted EVA glue carefully; cool 30 min [Elektroda, Anonymous, post #17158926]
What edge-case failures happen with hot-melt parts?
EVA softens at 70 °C car-park heat and dissolves in fuel splash, cracking within weeks [Tech Data Sheet].
Could fiberglass plus rubber paint replace the pad?
Yes. A 2-layer 200 g/m² fiberglass shell weighs <100 g; coat Plasti-Lak 1 mm thick for grip [Elektroda, E8600, post #17167140] Durability 3–5 years.
Will hot-melt glue survive a decade outdoors?
Unlikely. UV embrittles EVA by 50 % tensile loss in 12 months “Polymer Aging Study”.
