Vaillant VPAR-5 Pump Rotor Replacement: Compatible Models, VC186/3-5 EcoTEC Plus Issues & Tips
Qdlaty78 12951 13
What Wilo rotor or pump model can replace the worn VPAR-5 pump in a Vaillant VC186/3-5 EcoTEC Plus boiler?
The matching replacement identified in the thread is a WILO RS 25/60r pump; one user checked the boiler and confirmed it uses a WILO RS 25/60r, while the seller’s photos also showed RS 25/60r or RS 30/60r [#17721054] Another user reported buying a complete rotor with a Wilo coil from Hydroit for about PLN 250, describing it as a four-speed pump where the original connector is swapped for the boiler’s connector, with two speeds controlled by the boiler electronics [#17718532] If you only need a cheaper full-pump substitute and your boiler uses a normal 230 V 3-wire pump, a standard electronic Wilo or an Omnigena Omis 25-60 100 W was suggested as a physical fit [#17710830][#17713017] Grundfos was specifically warned against as a direct swap because of different screw spacing and Allen size [#17710830]
  • #1 17154455
    Qdlaty78
    Rate: 29
    Ladies and Gentlemen,
    Such a thing happened - the Vaillant VC186 \ 3-5 EcoTEC plus stove, after 9 years of operation (without maintenance, my fault), began to fail. I recently replaced the main exchanger (yes, I know it's due to lack of maintenance), quite a nice job. By the way, I decided to clean everything and review everything I can. Actually, everything is in good shape, except the pump .. The impeller has axial runout, it will be 5mm. This makes the rotor very noisy and sometimes jamming of the rotor itself.
    Nothing new.
    Visually, the VPAR-5 pump is similar to Wilo or Grundfoss (in fact they all look similar). Certainly, Vaillant does not produce these pumps itself, and the manufacturer, in turn, does not produce a "special" model, but brands something he already has - in this case Vaillant.
    Hence my question - is there any pump that has the same rotor? In my pump, the plastic of the turbine is clean, the winding is whole, not swollen, you just need to change the rotor. Does anyone know anything? I saw the info somewhere that this is Wilo, but without any details. It looks more like Grundfoss than Wilo.
  • #2 17706983
    robsum
    Maybe a colleague managed to establish something? Exactly the same thing happened to me, and the days of the original rotor are numbered.
  • #4 17710830
    BrodowskiG
    Help: 52
    Rate: 193
    Buy a regular electronic wilo and you'll be fine, grundfos has a different screw spacing and a different size of the allen. I changed the engines several times and it was always ok, as long as the brand was correct.
  • #5 17710865
    phonex
    Help: 6
    Rate: 30
    How about the connection? There are a few veins in the original one
  • #6 17710878
    BrodowskiG
    Help: 52
    Rate: 193
    there you probably have a zero protection phase without pwm speed regulation
  • #7 17712985
    kz61
    Help: 108
    Rate: 314
    Pro have a single-stage pump and a 3-wire cable. Plus it has a two-stage (electric switching from the board) and a 5-wire cable.
  • #8 17713017
    BUCKS
    Help: 536
    Rate: 1085
    If there is a pump in the boiler without power regulation, i.e. it has the usual 230V power supply with a 3-wire cable, I would see if the Omnigena Omis 25-60 pump with 100W power for about PLN 90 would physically fit.
    As a cheap replacement until the boiler is dying, it should be sufficient.
  • #9 17713190
    phonex
    Help: 6
    Rate: 30
    I have 5 wires in the boiler. Yellow, brown, and blue are probably power. And there are also black and white.
  • #10 17713577
    BUCKS
    Help: 536
    Rate: 1085
    as kz61 wrote, you have a two-stage pump controlled through the boiler MENU.
    In my old Vaillant VUW240 / 2-5 I have a 2-speed pump but gear selection is done with a mechanical switch on the pump housing.
    For this reason, the selection of the pump power has nothing to do with the boiler MENU, so I can safely use as a replacement for the aforementioned Omis 25-60, because the boiler's main board only gives 230V power for the pump at the right moment and it's all its task in terms of pump control.
    Although I would try to determine if it would be possible to connect an ordinary pump and possibly select its power with a mechanical switch, but this would require a practical test, if the boiler would not give errors then, which would prevent its correct operation.
  • #11 17718532
    Qdlaty78
    Rate: 29
    Hi. I bought a complete rotor with a Wilo coil (Hydroit, this one for PLN 250), when I am at home, I will write which model. The seller blurred rather carelessly ;) It is a four-speed pump, from which the original connection is removed and the one from the boiler pump is inserted. Two gears are then in operation, selected by the controller. T.
  • #12 17718550
    BrodowskiG
    Help: 52
    Rate: 193
    I would measure the tensions and leave it disconnected from the second gear
  • #13 17719938
    phonex
    Help: 6
    Rate: 30
    Great, I would be grateful
  • #14 17721054
    Qdlaty78
    Rate: 29
    The photos show the RS 25 / 60r or the RS 30 / 60r
    Added after 18 [hours]:
    I checked the pump on my stove. WILO RS 25 / 60r.
✨ The discussion revolves around the replacement of the rotor in the Vaillant VC186/3-5 EcoTEC Plus pump, which has begun to fail after nine years of operation without maintenance. Users share experiences with similar issues, noting that the VPAR-5 pump resembles models from Wilo and Grundfos. Suggestions for compatible replacements include the Wilo RS 25/60r and the Omnigena Omis 25-60, with emphasis on ensuring proper electrical connections and compatibility with the boiler's control system. One user successfully purchased a rotor with a Wilo coil, indicating that modifications may be necessary for installation.
TL;DR: For Vaillant VC186/3-5 with VPAR-5, a Wilo-based service rotor/motor swap works; paid PLN 250, and “It is a four-speed pump.” [Elektroda, Qdlaty78, post #17718532]
Why it matters: This FAQ helps EcoTEC Plus owners fix noisy/jamming VPAR‑5 pumps and pick proven, compatible replacements.
What rotor/motor actually fits a Vaillant VPAR‑5 in a VC186/3‑5 EcoTEC Plus?
A user confirmed installing a WILO RS 25/60r motor‑rotor in this boiler. That shows the VPAR‑5 is Wilo‑compatible here. Match RS 25/60r when sourcing parts. This solves noise and jamming from a worn rotor. [Elektroda, Qdlaty78, post #17721054]
How much does the Wilo service motor/rotor cost, and what wiring change is needed?
One owner bought a complete rotor with Wilo coil for about PLN 250 from Hydroit. Move the original Vaillant connector onto the Wilo motor. Then the controller selects two speeds from the four-speed motor. This preserves the boiler’s staged control. [Elektroda, Qdlaty78, post #17718532]
Can I swap in a Grundfos instead of Wilo?
Avoid that for this application. Grundfos units have different screw spacing and a different Allen size, so they won’t align. “Buy a regular electronic wilo and you'll be fine.” Use Wilo to simplify mounting and service. [Elektroda, BrodowskiG, post #17710830]
What do 3‑wire vs 5‑wire pumps mean on Vaillant EcoTEC?
EcoTEC Pro uses a single‑stage pump with a 3‑wire cable. EcoTEC Plus uses a two‑stage pump with a 5‑wire cable. The Plus model’s control board switches stages electrically. Plan replacements according to your wiring and staging. [Elektroda, kz61, post #17712985]
What do the extra two wires on a 5‑wire VPAR‑5 actually do?
They carry board control for two fixed pump stages. The boiler selects the active gear via the menu. This keeps factory behavior and hydraulic balance. Preserve these control leads during any motor swap. [Elektroda, BUCKS, post #17713577]
How do I swap in the Wilo service motor and keep Vaillant control?
  1. Isolate power, drain if needed, and remove the VPAR‑5 motor‑rotor assembly.
  2. Move the original Vaillant connector harness onto the Wilo motor.
  3. Fit the Wilo motor, restore seals, and verify two speeds via the controller. [Elektroda, Qdlaty78, post #17718532]
My VPAR‑5 is noisy and sometimes jams—what’s the likely cause?
Impeller axial runout can reach about 5 mm. That creates loud operation and can jam the rotor. Replace the rotor or motor assembly to fix it. Inspect components for wear during removal. [Elektroda, Qdlaty78, post #17154455]
Can I run a standard 230 V pump and set speed manually instead?
Some setups support a conventional pump with a mechanical speed switch. Confirm the boiler does not throw control errors afterward. Older models allowed manual selection on the pump. Newer Plus boards expect stage control from the PCB. [Elektroda, BUCKS, post #17713577]
Will the boiler menu let me pick the pump speed?
On two-stage Plus models, the main board handles stage selection via the menu. Older units used manual switches on the pump body. The menu determines which of the two gears runs. Check menu behavior after a motor swap. [Elektroda, BUCKS, post #17713577]
Where can I buy a compatible service motor for VPAR‑5?
Hydroit listed a “silnik serwisowy do pompy Vaillant VPAR5 Wilo.” Availability can change, so confirm stock before ordering. Users reported contacting the store for details. Verify compatibility against your pump model. [Elektroda, phonex, post #17710806]
Should I leave the second gear disconnected during testing?
If unsure about control voltages, measure them first. Leave the second stage disconnected initially. Reconnect after validating correct signals. This reduces miswiring risk during commissioning. [Elektroda, BrodowskiG, post #17718550]
What happens if I skip boiler maintenance for years?
A nine‑year gap led to a failed main heat exchanger and a noisy, jamming pump. The owner linked this to skipped maintenance. Address pump wear promptly once noise appears. Replace worn rotors before damage escalates. [Elektroda, Qdlaty78, post #17154455]
Is Vaillant the manufacturer of the VPAR‑5 pump?
In this case, the installed motor matched a Wilo RS 25/60r. That indicates a Wilo‑based unit inside this Vaillant boiler. Source Wilo service parts when replacing the motor‑rotor. Confirm markings before purchase. [Elektroda, Qdlaty78, post #17721054]
Does the EcoTEC Plus use stage switching rather than variable modulation?
Yes. The Plus variant uses electric stage switching from the main board. It selects between two fixed pump stages. Choose replacements that accept stage inputs to keep control working. [Elektroda, kz61, post #17712985]
Is there a cheap temporary pump option for non‑regulated setups?
Yes. One user suggested the Omnigena Omis 25‑60 (100 W) for about PLN 90. Use it on simple 230 V, 3‑wire systems. Treat it as a stopgap near end‑of‑life. [Elektroda, BUCKS, post #17713017]
