[Solved] Mazda 6 gh 2.2 - Self-replacement timing chain on Mazda 6 gh 2.2
ryba240266 11784 4
  • Suspected timing chain jumped one or two teeth
    #1 17173789
    ryba240266
    Hello to all forum users,
    Please provide the diagram or photos of timing chain settings in Mazda 6 gh 2.2. I had such a situation that after a very unlucky start from the clutch the engine went into rotation on the border between stalling and idle speed. The engine started to jerk, you could hear a loud jerk, and then (after about 2-3 seconds) I turned off the engine. I suspect a timing chain change of 1 or 2 teeth. The engine is still running, everything is like ok, the "hack engine" indicator appears on the dashboard. The engine runs unevenly at low speed, there is a choking noise in the air filter. Do you have any other hints what you can do?
  • #2 17174340
    kkknc
    Help: 1915
    Rate: 6709
    Read the errors and not take the chain. It's quite durable.
    Diagrams without any but available on the web.
  • #3 17179864
    ryba240266
    Just the car was on the Mazda site check on diagnostics, some looseness, timing to be replaced for 1500 euros so thanked. I found a scheme to 2.0 but that's not it, only 2.2 I would be grateful if someone gave the settings. Regards
  • #4 17180088
    kkknc
    Help: 1915
    Rate: 6709
    There was a service action there. They do exchange for free.
  • #5 17206442
    ryba240266
    Hello again, the problem is solved, no errors on diagnostics and yet on the crankshaft jumped by one tooth. Regards
