[Solved] VW Passat B8 Hook Installation: CAN Connection, PINs 16 & 17, Kufatec.de Wiring Bundle
misiek2123 17976 5
  • #1 17176080
    misiek2123
    Rate: 13
    Yesterday I started to mount the hook for VW Passat B8, the wiring has already been pulled to the fuse box, I just have a problem with CAN connection because the manual says, CAN High on PIN 16 (orange / green wire), CAN Low on PIN 17 (orange / brown wire), Ignition on PIN 14 (black / violet wire). and under these PINs or I have a different color or the PIN is empty, e.g. the PIN 16 cable is located under PIN 8, the cable bundle is from kufatec.de, I wrote a message there but maybe someone encountered such a problem.
  • #2 17176827
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    Which controller do you want to connect to? The hook control is factory connected to can comfort.
  • #3 17176886
    misiek2123
    Rate: 13
    I got this scheme, I need to connect to picture 3 but my cube looks a bit different, there are no cables as described in the description, i.e. PIN 16, 17 and 14, exactly CAN Low, CAN High and one more cable.
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    Maybe you are looking at this connector
    • VW Passat B8 Hook Installation: CAN Connection, PINs 16 & 17, Kufatec.de Wiring Bundle 20180420_112713.jpg (4.69 MB) You must be logged in to download this attachment.
    • VW Passat B8 Hook Installation: CAN Connection, PINs 16 & 17, Kufatec.de Wiring Bundle 20180420_112958.jpg (1.04 MB) You must be logged in to download this attachment.
    • VW Passat B8 Hook Installation: CAN Connection, PINs 16 & 17, Kufatec.de Wiring Bundle 20180420_113017.jpg (900.06 KB) You must be logged in to download this attachment.
  • #5 17178245
    misiek2123
    Rate: 13
    It turned out that there was one more connector hidden deep enough, the cables were connected and everything works, topic to close.
  • #6 17178249
    misiek2123
    Rate: 13
    Added after 55 [seconds]:
    It turned out that there was one more connector.
