Permanent Infrared Disabling for Hikvision Camera & Recorder - Turn Off IR Feature
goofee 13440 8
  • #1 17198104
    goofee
    Hikvision camera, also hikvision recorder - can the infrared on the camera be turned off permanently?
  • #2 17198221
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 642
    What camera? Enter the PTZ control of the selected camera and push the plus of the first from the bottom on the right (from the top you probably have zoom, focus and underneath). If the menu opens, the camera supports this function (i.e. changing parameters, etc.), but not all cameras have such functions as IR disabling.
  • #3 17198279
    mikan4
    Help: 85
    Rate: 76
    @goofee something more, because it is late, and I will not drink coffee or tea for the night, telling the coffee grounds :) What camera and what recorder.
  • #5 17198965
    michualex
    Help: 82
    Rate: 134
    goofee wrote:
    recorder: DS-7604NI-E1 / A
    camera 1; TUBE CAMERA TRI2H2812
    camera 2: AVB-IPC20SW
    please train me if I don't know something ;)
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #6 17198975
    dawidedziu
    Help: 500
    Rate: 642
    Well, that changes things. Perhaps the camera itself can disable IR by logging into its interface.
  • #7 17199069
    goofee
    I just found nothing there. I even disassembled the camera and combined with the diode connectors, but it did not work.
  • #8 17199105
    dawidedziu
    Help: 500
    Rate: 642
    Well, if you did not find anything there, the cameras do not have such functions - sorry. Personally, I would cut the wire from the infrared circuit, if there is one - I have no idea what it looks like inside the camera.
  • #9 17511541
    barondary
    Help: 31
    Rate: 71
    The case is still relevant and other. I had a problem with the DAHUA camera and I was able to disconnect the infrared without any problem by taking the camera apart and disconnecting the plugs. The description on this blog was helpful:
    https://darmagedon.blogspot.com/2018/10/jak-wyaczyc-oswietlenie-nocne-czyli.html
    For now, all other camera functions work without any problems.
The discussion revolves around the possibility of permanently disabling the infrared (IR) feature on Hikvision cameras and recorders. Users inquire about methods to turn off the IR functionality, with some suggesting accessing the camera's PTZ control interface to check for options. However, it is noted that not all models support IR disabling. One user attempted to modify the camera by disassembling it and connecting the diode connectors but was unsuccessful. Another user shared their experience with a DAHUA camera, where they successfully disconnected the IR by taking the camera apart. The conversation highlights the lack of built-in options for IR disabling in certain Hikvision models and suggests physical modifications as a potential solution.
