Overcoming False Motion Detection in Hikvision DS-2CD1041 Cameras & DS-7608NI-K2/8P Recorder
tomek7040 1644 19
Why do my Hikvision cameras keep losing their motion-detection grid and schedule, and how can I stop it?
Disable Hik-Connect on the cameras, keep Hik-Connect enabled only on the DVR/NVR, and turn off automatic updates and auto time sync on each camera; also make sure the time zone and region are set correctly [#21360600] [#21360637] [#21360742] If the issue continues, try moving motion detection from the cameras to the recorder, because the reply suggested that camera-side detection may not behave reliably in this mixed setup [#21360643] One commenter also noted that mixing Hikvision product series can affect functionality, and that the problem may be firmware/software-related, so checking for updates is worth doing [#21360525] [#21359827]
  • Motion settings reset and OSD save error 0xffffffff
    #1 21359575
    tomek7040
    Rate: 8
    Hi
    About 2 weeks ago I put together a home monitoring kit for myself on Hikvision components, the question is why the system forgets my motion detection setting?
    I set the grid on the cameras in the settings, and after a while it loses the grid and detection schedule.
    Hilook NVR-8CH-5MP DVR
    Hilook IPC-B180HA-LUF/SL cameras - 3 pieces
    Hikvision DS-2CD1043G2-LIU camera - 1 camera
    Hikvision DS-2CD2087G2-LU camera - 1pc
    PTZ-N2C400M-DE - 1 pc.
    all connected on Hikvision switch
    With this DS-2CD2087G2-LU camera I still have such a problem that when changing the OSD an error 0xffffffff pops up when I want to save the settings, e.g. after changing the camera description.
  • #2 21359658
    lopr_pol
    Level 32  
    Help: 164
    Rate: 491
    Because this type has so :) .
    Like everything Chinese it has bugs in the software ( and holes for their government), of course fixes are missing.
    I also struggled with detection on hikvision, after a week I gave up, it either lost the config or after 2-3 days it stopped working.
  • #3 21359735
    gkwiatkowski
    CCTV and Stationary Alarms specialist
    Help: 650
    Rate: 1230
    Where did you buy these cameras?
    Advertise them as soon as possible.
  • #4 21359739
    tomek7040
    Rate: 8
    In a shop in Krakow, why do I need to advertise them as soon as possible? Can you elaborate?
  • #5 21359751
    gkwiatkowski
    Help: 650
    Rate: 1230
    If you bought online, you only have 14 days to return, and you wrote that you bought 2 weeks ago. Maybe the deadline hasn't passed yet?
  • #6 21359754
    tomek7040
    Rate: 8
    I bought from a stationary shop. Tell me why they need to be advertised? What happens to them?
  • #7 21359811
    gkwiatkowski
    Help: 650
    Rate: 1230
    After all, you yourself describe that they lose their settings. They probably have some problem in the software.
    Are they from European or Chinese distribution?
    I have never had such problems with Hikvision.
  • #8 21359818
    tomek7040
    Rate: 8
    They lose but only from traffic, rather Polish distribution, I write rather because the only certainty is that I will have to pay taxes.... I am asking here for the time being out of curiosity if anyone has had a problem, after Christmas I will write to the support to the shop. Perhaps a problem in the registrar.
  • #9 21359827
    gkwiatkowski
    Help: 650
    Rate: 1230
    See if there is a software update.
  • #10 21359831
    tomek7040
    Rate: 8
    It's home now, thanks for now, unless anyone else has any further comment....
  • #11 21360525
    sosarek
    Help: 9320
    Rate: 15532
    @tomek7040 Also, you are mixing product series which also affects functionality.
    How powered are the cameras?
    Z
    Pka, Poznań, 60-850
  • #12 21360589
    tomek7040
    Rate: 8
    Power supply is from the switch via POE, the guy in the shop has no reservations about the assembled kit
    EC system shop
  • #13 21360600
    sosarek
    Help: 9320
    Rate: 15532
    Nothing like putting unconditional trust in a salesman....
    Time zone, region selected correctly?
    Disable auto check and download updates, auto time sync on each camera.
    Z
    Pka, Poznań, 60-850
  • #14 21360613
    tomek7040
    Rate: 8
    Well, if that's the case... Then who should I put my trust in? not necessarily without condition...
    UTC +1, region I do not know how to check
    synchronisation disabled, updates I don't know how to disable
  • #15 21360637
    sosarek
    Help: 9320
    Rate: 15532
    Log in to each camera from the browser and disable updates there, also access via Hik-Connect.
    Z
    Pka, Poznań, 60-850
  • #16 21360639
    tomek7040
    Rate: 8
    Do I understand this correctly? Should I disable access to hikconnect?
  • #17 21360643
    sosarek
    Help: 9320
    Rate: 15532
    In the cameras.
    Also see what happens if you disable detection in the cameras and set it in the DVR.
    Z
    Pka, Poznań, 60-850
  • #18 21360666
    tomek7040
    Rate: 8
    Once again... Should I disable hikconnect in the settings?
    What about accessing the monitoring via the internet?
    I am supposedly using the hilooka app 🤔.
    But I prefer to ask right away.
  • #19 21360742
    gkwiatkowski
    Help: 650
    Rate: 1230
    Disable Hikconnect on the cameras.
    Leave Hikconnect enabled on the DVR.
  • #20 21403982
    tomek7040
    Rate: 8
    I think I may have misunderstood the whole thing a bit, I mean the system, in the preview the grid disappears after a while, but all in all the cameras show detection when necessary. So I'm not dragging the subject any further, thanks for your efforts and help. I will contact you again if I have any problems. Thank you for now.
The discussion revolves around issues with motion detection settings disappearing on a Hilook NVR-8CH-5MP DVR connected to various Hikvision cameras. The user reports that after configuring the motion detection grid, the settings are lost over time. Other users suggest potential software bugs, the importance of checking for updates, and ensuring proper configuration of time zones and synchronization settings. There are also recommendations to disable Hikconnect on the cameras while keeping it enabled on the DVR. The user expresses uncertainty about the functionality of the system but acknowledges that the cameras still detect motion as needed.
TL;DR: Motion detection overlays can vanish; "after 2–3 days it stopped working" was reported. This FAQ shows thread‑backed fixes to stabilize settings. [Elektroda, lopr_pol, post #21359658]
Why it matters: If you use mixed HiLook/Hikvision gear and see disappearing grids or lost schedules, these steps help you restore reliable motion events.
Why does my motion detection grid disappear in preview, but motion alerts still trigger?
The grid is a preview overlay, not the detection engine. Users noted the grid disappearing while motion alerts still triggered normally. Treat it as a UI issue, not a lost configuration. Walk through a zone and confirm events or alerts. If events fire, your detection remains active. [Elektroda, tomek7040, post #21403982]
How do I disable Hik‑Connect on cameras and keep remote access via the DVR?
Use DVR P2P only. "Disable Hikconnect on the cameras. Leave Hikconnect enabled on the DVR." Then use the NVR for remote access via HiLook/Hik‑Connect apps. How‑To:
  1. Log into each camera’s web interface.
  2. Disable Hik‑Connect/P2P service and save.
  3. Ensure Hik‑Connect remains enabled on the NVR. [Elektroda, gkwiatkowski, post #21360742]
Should I configure motion detection on the NVR instead of the cameras?
In mixed setups, disable detection on the cameras and set it in the DVR to compare stability. The thread suggests testing this change directly. If DVR‑side detection holds, keep camera detection off. Re‑enable per‑camera detection only if needed. [Elektroda, sosarek, post #21360643]
My DS‑2CD2087G2‑LU shows error 0xffffffff when saving OSD text. What fixes it?
This error indicates a firmware or save failure. Check for a software/firmware update for that camera and apply it. Reboot and try saving the OSD again. If it persists, document steps and firmware for support escalation. [Elektroda, gkwiatkowski, post #21359827]
Does mixing HiLook and Hikvision camera series affect motion features?
Yes. "You are mixing product series which also affects functionality." Expect mismatches in available events, overlays, or analytics. Standardize models where possible, or centralize event logic on the DVR. This reduces feature drift across devices. [Elektroda, sosarek, post #21360525]
Which time and region settings should I verify?
Confirm each camera’s time zone, regional setting, and time are consistent with the NVR. The thread asks to validate these before other steps. Misaligned clocks can break schedules and confuse playback markers. Set them identically across devices. Disable auto sync while testing. [Elektroda, sosarek, post #21360600]
How do I turn off auto updates and auto time sync per camera?
Turn off automatic update checks and automatic time synchronization during troubleshooting. Save changes and reboot each camera. Re‑enable only after confirming stability. How‑To:
  1. Log into the camera’s web UI.
  2. Disable auto update check and auto time sync.
  3. Save and reboot. [Elektroda, sosarek, post #21360600]
Can I still view cameras remotely after disabling Hik‑Connect on cameras?
Yes. Keep Hik‑Connect enabled on the DVR only. You will still view all cameras through the NVR remotely. This avoids duplicated P2P paths and centralizes control. [Elektroda, gkwiatkowski, post #21360742]
What models and counts were in the reported setup?
One HiLook NVR‑8CH‑5MP and a Hikvision switch. Cameras: three HiLook IPC‑B180HA‑LUF/SL, one Hikvision DS‑2CD1043G2‑LIU, one DS‑2CD2087G2‑LU, and one PTZ‑N2C400M‑DE. That is a six‑camera, mixed‑series stack. [Elektroda, tomek7040, post #21359575]
I thought detection failed, but only the grid disappeared. How can I sanity‑check detection?
Walk through a masked area and watch for alerts or event markers in the NVR. The OP confirmed detection still worked despite the missing grid. If events trigger correctly, keep your configuration and proceed with stabilization steps. [Elektroda, tomek7040, post #21403982]
Can I return the gear if settings keep resetting?
If purchased online, "you only have 14 days to return." For local shop purchases, use warranty or RMA channels instead. Consider this route if firmware updates and configuration changes do not help. [Elektroda, gkwiatkowski, post #21359751]
How do I access each camera from a browser to change settings?
Use each camera’s web interface for direct changes. "Log in to each camera from the browser and disable updates there, also access via Hik‑Connect." Apply changes, save, and reboot. Repeat per camera for consistent behavior. [Elektroda, sosarek, post #21360637]
