Hussar Loncin 196: Increasing Speed on Low-Speed Mower with Drive - Can it Be Accelerated?
darko b 13629 9
Can the drive speed of a Husar mower with a Loncin 196 engine be increased?
Yes, but the thread suggests checking the drive hardware first, because some Husar mowers are simply built to run slowly and may have been fitted with a different gearbox ratio after repair or replacement [#17214451] If the belt is slipping or the control cable is pulling the drive too tightly, remove the belt covers and inspect how the drive engages [#17202948] Also check whether the wheel tread is worn, because slipping wheels can make the mower seem even slower [#17210398] One suggested way to change the speed is to replace the pulley on the motor shaft, but that can also require a different belt [#17338761][#17338770] In the reported case, tightening the belt did not change the speed, so the slow drive may just be characteristic of this model [#17250215][#17338396]
  • #1 17202886
    darko b
    Rate: 103
    Hello, some time ago I bought a less-used Husar mower with a Loncin 196 engine, but I wonder the speed is too slow. Revolutions for max. and I'm going for a walk. I cut the lawn much faster without a drive. Can it be accelerated?
    lisekey
    Help: 12
    Rate: 77
    Perhaps the cable too tightly pulls the belt with the drive and just slips, remove the belt covers and see how the drive mechanism engages.
  • #3 17210398
    AWJR1951
    Help: 10
    Rate: 70
    Hello, if the tread of the wheels driving the mower is worn, then the wheels slide on the grass and it will also be slow to drive.
    zommbi
    this is unfortunately the disadvantage of these Husar mowers - unfortunately I have the same.
    When she was new, she rode at normal speed, unfortunately very short, because after 2 hours of work the gearbox broke down and the service replaced the gears with a new one (under warranty) - after this replacement the mower drives slowly like a turtle. When trying to make a repair claim they said everything was OK and that's how it should go! :(
    I was also able to find out from the service that the first transmissions in these mowers were weak and often had to be replaced - apparently for a more durable model. He concludes that, however, one with a different gear ratio, which is the reason for a much slower ride. They should probably also replace the pulley with a properly selected one to maintain the correct speed. But why should they pack at additional costs - and let the customer get tired!
    As for the "more durable" gears - in fact, instead of 2 hours, it lasted 2 years, but it is ONLY 2 years! and I need to replace it again after the warranty (digging through the net in this case, I came across this thread). It's good that the drive in the previous 15-year-old mower never broke and I had something to finish mowing (and what was my surprise that I can't keep up with this old one)
    From other adventures with this Husar mower:
    - after the purchase and the first firing, it turned out that the engine was screwed badly and the knife hit the side of the gun carriage - I have a rubbing to this day ;)
    - after the first return from service, it turned out that the mounting of the front wheel is bent - but as I heard, I certainly bent it myself
    - after replacing the gearbox by the service, at the second mowing one wheel ceased to be driven - the reason was the wrong rotation of the drive and wheels by the service
    - the courier's comment was also invaluable, which took her to the website: "it's probably the third this week ... and so every week"
    To sum up neither Husar's equipment nor their inept service I DO NOT RECOMMEND!
    Unless a person who more than using mechanized gardening equipment as intended,
    they like to spend time repairing it (e.g. with a beer) ;)
  • #5 17250215
    darko b
    Rate: 103
    I pulled the belt harder because it was loose but the speed did not change. I think that this type has it.
  • #6 17338396
    lukk9314
    Rate: 10
    I have a Hortmash with this engine and the drive is also slow is probably the affliction of all other productions, I have seen Hechty on Youtube and they were just as slow
  • #7 17338761
    Staszek49
    Help: 228
    Rate: 1141
    Consider shifting, in particular changing the pulley on the motor shaft.
  • #8 17338770
    lukk9314
    Rate: 10
    The problem is that you would have to change the belt and you do not know how to drive
  • #9 17466484
    darko b
    Rate: 103
    The son began to mow the grass and the slow pace of the drive suits him.
  • #10 18240850
    kitkat
    Rate: 28
    My mower, like Arabians from Michałów, I have to almost run after her. How do you slow down the mower's speed?
The discussion revolves around the slow speed of a Husar mower equipped with a Loncin 196 engine. Users suggest potential causes for the reduced speed, including a tightly pulled drive belt, worn wheel treads, and issues with the gearbox. One user reported that after a gearbox replacement, their mower's speed significantly decreased, indicating a possible design flaw in the transmission system. Recommendations for improvement include checking the drive mechanism, replacing the pulley for better gear ratios, and considering belt adjustments. Overall, the slow drive seems to be a common issue among various mowers using similar engines.
