Ways to control 11 external roller shutters - individually and with one switch
Mikhaił 2067 8
  • #1 18964385
    Mikhaił
    Rate: 22
    Welcome,
    I would like to close and open the shutters individually and all with one shutter switch. There will be 11 roller shutters. I am in the process of doing the installation, so everything can still be done.
    Which solution would you recommend for controlling the external roller shutters?
    Kind regards.
    adamjur1
    Help: 772
    Rate: 1003
    There are many solutions, I used individual controllers in boxes behind roller shutter switches, type ZAMEL SRP01, power supply locally at the roller shutters, and a two-wire bus to the distribution board. You only need to consistently power and control the roller shutters from the same phase. It is best to equip the central control pushbutton with two three-pole contactors or supply power to all roller shutters from one phase (easier to install, but there may be "insufficient current" in this phase).
    The one with contactors allows you to connect other controls - remote controls, twilight control, etc.
    Yours sincerely J.
  • #3 18964451
    Mikhaił
    Rate: 22
    Thanks for the idea, although I was already thinking about these contactors but it involves a lot of extra switchboard wiring.
    Any other solution, perhaps a radio link between the central roller shutter switch and the local switches?
  • #4 18964690
    e-sparks
    Electrician specialist
    Help: 77
    Rate: 216
    Mikhaił wrote:
    any other solution
    E.g. like this: https://www.fif.com.pl/pl/sterowniki-rolet/82-sterownik-rolet-str-422.html
    Requires 4x1.5mm from the dashboard to each box by the window.
    Or one like this: https://www.fif.com.pl/pl/26-sterowniki-rolet#/montaz-w_puszce_podtynkowej_o60
    Requires only a 3x1.5mm supply to the box by the window.
  • #5 18964988
    Mikhaił
    Rate: 22
    Such as: https://www.fif.com.pl/pl/sterowniki-rolet/82-sterownik-rolet-str-422.html
    Requires 4x1.5mm from the distribution board to each box at the window.
    Or such: https://www.fif.com.pl/pl/26-sterowniki-rolet#/montaz-w flush-mounted box o60
    requires only a 3x1.5mm supply to the box by the window.
    This is also a good solution, but costly, one module 70zl plus wiring, but I think it is cheaper to run 5x1.5mm2 from each window to the switchboard and use these two contactors for the control.
  • #6 18965050
    e-sparks
    Help: 77
    Rate: 216
    Mikhaił wrote:
    I guess it's cheaper though
    Yeah?
    What is the price of these "contactors" and the difference in price of 4x and 5x wires? For each window...
  • #7 18965058
    Mikhaił
    Rate: 22
    2 contactors at a price of approx. 200zl, you can also get cheaper,
    If you choose the option with the modules, you will also have to lead the wires for the central control, which means you won't save on wires anyway. The option with contactors and a 5x1.5mm2 wire from the distribution board and connect all roller shutters in series. Probably the cheapest option in my opinion.
  • #8 18967016
    Marek J.
    Help: 526
    Rate: 951
    Mikhaił wrote:
    and on these two contactors do this control
    Bravo you... On two contactors 11 roller shutters? Please explain how you intend to connect this to make it work properly. Do you want to connect several motors in parallel????
  • #9 18967118
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    Mikhaił wrote:
    As another solution, perhaps a radio link between the central roller shutter switch and the local switches?
    - see Shelly 2.5 and ShutterBox.
The discussion revolves around controlling 11 external roller shutters both individually and collectively using a single switch. Various solutions are proposed, including the use of individual controllers like ZAMEL SRP01, which require a two-wire bus for power and control. The option of using contactors for central control is also mentioned, allowing for additional features like remote and twilight control. Alternatives such as Shelly 2.5 and ShutterBox are suggested for wireless control. The cost implications of wiring and components are debated, with a preference for using contactors and a 5x1.5mm2 wire setup for cost efficiency.
