Satel Perfecta - remote programming - several functions simultaneously
uniorek 7977 7
  • #1 17238145
    uniorek
    Welcome
    Is it possible to program several functions simultaneously under one button on the MPT-350 remote control, e.g. gate control with simultaneous arming of the alarm? Unfortunately, I have not come across such a description anywhere in the documentation / www.
    I would not like to make special combinations, e.g. connecting a controlled relay to the output from the gate control and the input that will arm the alarm.
    regards
  • #2 17238415
    montersi.pl
    Help: 26
    Rate: 26
    There is a possibility. For the keyfob button, set the "Violate zone" option, eg zone 10. Then set the given zone (10) to "Arm".
    In case of outputs, set the given output as "Controllable" and set the triggering from input 10. Operating time 1s (impulse to the gate).
    E-SYSTEM Sp. z o.o.
    Czarnoleska 10, Zabagnie k. Wolbromia, 32-340 | Tel.: 32 XXX XX XX (Show) | Company Website: https://www.montersi.pl
  • #3 17238792
    michualex
    Help: 82
    Rate: 134
    We have a gate with a step-by-step entrance and a whole intricate plan in ... ;)
    MK ALARMY
    Widziszewo, Długa 3, Kościan, 64-000 | Tel.: 663XXXXXX (Show) | Company Website: www.mkalarmy.pl
  • #4 17238930
    montersi.pl
    Help: 26
    Rate: 26
    We don't know what the gate is (the switchboard to the gate) ;) After all, the very idea of controlling the standby with the use of a remote control is controversial. It does not change the fact that as part of the author's inquiry, such a solution is technically feasible.
    E-SYSTEM Sp. z o.o.
  • #5 17239339
  • #6 17239473
    uniorek
    Garage door - already integrated with Satellite - the output controls the input short-circuit. in the drive controller - after pressing the appropriate button on the remote control. 2 buttons on the remote control - at the moment they perform the same functions, I just want one of them to additionally arm the zone in which the garage is located.
    Added after 3 [hours] 38 [minutes]:
    Garage gate - the user will consciously close the gate while arming the zone in which the garage is located - I do not understand what is controversial here?
  • #7 17240857
    bhtom
    Help: 446
    Rate: 605
    It is controversial that the keyfob is not used to control the armed status of the alarm system, but only to activate the entry delay time in the garage zone. Of course, a reed switch must be installed on the garage door. Full disarming of the garage zone after entering the password on the keypad installed inside the garage.
    You can arm the system with the remote control, but disarm it not.
    Best regards.
  • #8 17240925
The discussion revolves around the possibility of programming multiple functions simultaneously on the MPT-350 remote control for the Satel Perfecta system, specifically to control a gate while arming an alarm. A solution is proposed where the keyfob button can be configured to set a "Violate zone" option, allowing the simultaneous operation of the gate and alarm. However, there are concerns regarding the appropriateness of using the remote for alarm status control, as it is typically reserved for activating entry delay times. The integration of a reed switch on the garage door is suggested for proper functionality, with a focus on ensuring that the system can be armed remotely but requires a keypad for disarming.
