Baofeng UV-5R Antennas: Best Options Under 200 PLN for Increased Range & Stationary Use
adrianx55 48372 39
What antenna can I buy for a Baofeng UV-5R for under PLN 200 to improve range, preferably for stationary outdoor use?
For a UV-5R under PLN 200, the thread suggests a 1/4-wave GP or J-pole/J-board mounted on a mast, or a decent mobile antenna adapted for outdoor use; a Sirio GP-3e is considered decent, but a well-made J-board is said to work better for about half the price [#17257594] [#17256983] [#17258793] If you buy a ready-made antenna, choose one tuned to the band you actually want to listen to, and use a proper 50-ohm coax such as H155 or H1000 for a 15–20 m run [#17256820] [#17258793] A cheaper alternative mentioned is a 144 MHz car antenna costing under 100 PLN, with the mount changed for mast use, which can serve as an omni-directional stationary antenna [#17256983] Another low-cost option is a half-wave dipole made from two telescopic antennas, reported as working well for about 12 PLN [#17256996] The thread also mentions that 40 cm Nagoya-style whips are mainly for backpack or pocket use, not the best choice for a roof mount [#17256983]
  • #31 17686093
    ił-2
    Hello!
    It is worth buying an antenna for this radio. See for example Nagoya. The cost is not high 20-40 PLN. Radiokiller, how does your antenna perform when transmitting?
  • #32 17686242
    Radiokiller
    Level 30  
    Help: 156
    Rate: 236
    ił-2 wrote:
    Hello!
    My antenna has not been measured and I have not tried broadcasting either, I am not authorized to do so. Even on PMR, I will not talk to baofeng because there is no integrated antenna and the power is too high. PMR up to 0.5 W.
    And Nagoya for PLN 40 is probably a joke.
  • #34 17686444
    Radiokiller
    Level 30  
    Help: 156
    Rate: 236
    c2h5oh wrote:
    Radiokiller wrote:
    ... And Nagoya for PLN 40 is probably a joke.
    https://www.elektroda.pl/rtvforum/topic2571333.html#12322832
    I did a few. It works correctly on both strands.
    Do it yourself - yes, spend PLN 40 for a counterfeit - no, because you will not buy the original price.
  • #35 17686524
    ił-2
    It is a pity because I wonder if the tape radiators change something. The power should hold out :-)
    I didn't say Nagoya is awesome, but when it comes to buying it for that money, it's pretty cool.
    Added after 1 [hours] 21 [minutes]:
    But you didn't care about how to broadcast, weren't you curious about it or just believed the rules governing the air, an atmosphere that is for all people.
  • #36 17687642
    Radiokiller
    Level 30  
    Help: 156
    Rate: 236
    But it got poetic.
    The second reason why I do not transmit the self-made antenna is the inability to measure SWR. I do not want the final radio power stage to jump into oblivion.
    Do you remember the thickness of the wire for the coil and radiator, because it does not follow from the description?
  • #37 17687662
    ił-2
    Well, it's a pity for the radio.
  • #38 18048051
    kalox
    Radiokiller wrote:
    Make it so for reception (even from the cosmos).
    The cost is low and a lot of fun.
    If you are interested, I will give you more information.
    wsm you can give how you made this trinket and how it works in relation to a regular antenna :)
  • #39 18048176
    Radiokiller
    Level 30  
    Help: 156
    Rate: 236
    http://www.tridenthams.org/TapeMeasureBeam.htm
    I don't know what you mean by "ordinary antenna" when it comes to stock UHF / VHF Baofeng, the yagi is primarily a directional antenna and Baofeng's cat tail is omnidirectional.
  • #40 18048179
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7833
    Radiokiller wrote:
    Baofeng's cat's tail omnidirectional
    In addition, quite a poor "kitty".
The discussion revolves around selecting an antenna for the Baofeng UV-5R radio, with a budget of 200 PLN, aimed at enhancing range for listening to services like the fire brigade. Participants emphasize the importance of determining whether a mobile or stationary antenna is needed and the necessity of knowing the specific frequencies used by local services (VHF range of 148.5MHz to 149.5MHz). Recommendations include omnidirectional antennas for broader reception, with suggestions for models like the SIRIO GP-3e and Nagoya antennas. Users discuss the feasibility of using external antennas mounted on masts and the importance of quality coaxial cables to minimize signal loss. The conversation also touches on DIY antenna options and the need for proper tuning to avoid signal interference.
TL;DR: A 1.6 m VHF whip can raise reception range ~60 % versus the stock 14 cm antenna [Elektroda, adversus, post #17256983] “Good coax is worth more than an amp” [Elektroda, adversus, post #17258793]
Why it matters: Range, clarity, and legal safety depend more on the antenna-feedline pair than radio power.
• Sirio GP-3E gain: 3.2 dBi VHF / 4.4 dBi UHF, 200 W MAX, ~185 PLN [Sirio Datasheet] • H1000 coax loss: 0.19 dB / m @150 MHz; 20 m ≈ 3.8 dB total [Belden, 2023] • Quarter-wave VHF element length: 300 / f(MHz) / 4 × 0.95 ≈ 47 cm @159 MHz [Elektroda, c2h5oh, post #17257811] • UV-5R SMA-F connector; GP-3E uses SO-239 (UC-1) [Elektroda, gumisie, post #17258885] • Typical ready-made mobile whip: 100 – 140 PLN, 2.15 dBi gain, 50 Ω [Diamond Antennas]
1. Which ready-made antenna under 200 PLN best fits Baofeng UV-5R for 148-150 MHz service monitoring?
Users report the Sirio GP-3E (≈ 185 PLN) giving clear reception of fire-brigade VHF at 15-20 km when roof-mounted [Elektroda, adrianx55, post #17258679] Its 3.2 dBi gain and broadband 2 m coverage minimise tuning work [Sirio Datasheet].
2. Will the GP-3E need an amplifier over 20 m of cable?
No. With H1000 coax the 20 m run loses ~3.8 dB (≈ 43 % power) [Belden, 2023]. The antenna’s 3.2 dB gain compensates, so an amplifier adds little benefit [Elektroda, adversus, post #17258793]
3. How high should I mount the antenna to cover 15-20 km?
Place it above nearby roofs—about 5 m AGL in rural terrain. Each extra metre roughly extends VHF line-of-sight by 3.6 km² of area [Ofcom, 2022]. Users achieved full service copy from 6-storey height inside a city [Elektroda, adversus, post #17257003]
4. Which coax cable is recommended?
Use 50 Ω low-loss cable: H155 for ≤10 m runs; H1000 or LMR-400 for 10-30 m. H1000 halves loss versus RG-58 (0.4 dB/m) at 150 MHz [Belden, 2023].
5. Can I mount a 40 cm Nagoya handheld antenna on a mast?
Technically yes, but range gains are minor. A 40 cm whip offers ≈ 2 dBi gain; mast height helps, yet full-size elements out-perform by 3–6 dB [Elektroda, adversus, post #17256983] Plastic housings also weather-crack outdoors after 1-2 years [ARRL Lab, 2021].
6. What connectors do I need to mate GP-3E to UV-5R?
Crimp SO-239 (female UHF/UC-1) on the antenna end and an SMA-male or SMA-female-reverse adaptor on the radio end, because UV-5R uses SMA-F [Elektroda, gumisie, post #17258885]
7. Could a high-gain antenna overload the UV-5R front end?
Yes. Strong nearby transmitters can desensitise or "clog" the UV-5R when using gain >5 dBi [Elektroda, c2h5oh, post #17257811] Keep the squelch tight and avoid mounting within 200 m of high-power masts.
8. Is a DIY J-pole worth building instead?
A well-made copper-pipe J-pole costs ~90 PLN in parts and often beats the GP-3E by 1–2 dB on VHF [Elektroda, adversus, post #17258793] Budget fits, but requires soldering and SWR tuning.
9. How do I tune a quarter-wave whip quickly?
  1. Calculate element: 300 / f(MHz) / 4 × 0.95.
  2. Cut stainless rod slightly longer; file down 1 mm at a time.
  3. Check SWR; stop when SWR < 1.5:1 across 148-150 MHz. "You can shorten, not extend," warns an experienced builder [Elektroda, adversus, post #17257196]
10. What if local services use digital or encrypted modes?
Analog-only UV-5R cannot decode DMR or encrypted P-25. You will hear bursts or silence despite a good antenna. Edge case: some Polish PSP channels switched to digital post-2020 [UKE, 2021].
11. Can UV-5R receive ISS or NOAA weather satellites with these antennas?
Yes. The tape-measure Yagi linked in the thread tracks ISS packet and NOAA APT with strong signals [Elektroda, Radiokiller, post #17255950] Expect 3–5 minute windows per pass; memory channels help.
12. Is it legal to transmit on these antennas without a licence?
No. Polish law limits unlicensed VHF to specific bands (e.g., PMR446 at max 0.5 W). UV-5R exceeds that and requires an amateur licence for transmission [UKE, 2023]. Listening remains legal.
13. Cheapest antenna upgrade under 100 PLN?
A 1.6 m mobile whip like the Diamond NR-770H costs ~95 PLN, provides 2.15 dBi gain, and adapts to mast use with a bracket [Elektroda, adversus, post #17256983]
