Tomtom 4EN52 Z1230 navigation stops at the logo after an unsuccessful update
MQKris 5106 12
How can I recover a TomTom 4EN52 Z1230 that freezes on the logo after an interrupted MyDrive Connect update?
Try forcing the TomTom into the DOS window with the power button, then press the ON button three times and connect it to the computer [#17261673] If that does not help, use a Navcore card/microSD recovery method so the device can reload files from the card, but make sure the navigation is 100% charged first [#17261717] If the device generates a `ttgo.bif` file on the card, that suggests the card-based recovery is working [#17262049] One reply also notes that on MyDrive-supported devices the Navcore-from-card method may not work, so manufacturer phone support may be needed [#17262007]
  • #1 17260078
    MQKris
    Rate: 27
    The navigation connected to the computer hung up at 3% during the update and it remained like that for over an hour. After disconnecting, only the drum logo is activated and sometimes the navigation icon with 2 arrows in the shape of a circle appears on a blue background on the connected navigation computer. Is there any chance to revive this navigation?
    Thank you for your help.
  • #2 17260271
    Sniezynka
    Help: 199
    Rate: 841
    A damaged map file on the SD card, activate the card by the installation program and reload the map.
  • #3 17260884
    MQKris
    Rate: 27
    The navigation did not have an SD card. It crashed at 3% when updating NAVCORE from MyDrive Connect. After connecting to the computer, there is no additional disk in the manager.
  • #5 17261656
    MQKris
    Rate: 27
    The instruction on the Tomtom website doesn't help. I hold power for a long time but nothing shows up. After the standard turning on Navi, the picture below appears after a while. best regards
  • #6 17261673
    Sniezynka
    Help: 199
    Rate: 841
    Does the navigation have an SD card slot?
    If not, try to press the ON button as you normally turn on the navigation when the navigation is on the tom tom log plus beep, press the ON button again and do not release until the DOS window appears. Then press the ON button 3 times and connect to the computer.
  • #7 17261687
    MQKris
    Rate: 27
    Yes it has a MicroSD slot
  • #8 17261717
    Sniezynka
    Help: 199
    Rate: 841
    If the previous instruction does not help, you need to download the Navcore card and start navigating with the card, it should upload new files from the card itself.
    And very importantly, the navigation must be 100% charged otherwise it will not move.
  • #9 17261788
    MQKris
    Rate: 27
    Where can I find the right navcore for this model?
  • #11 17262007
    koala106
    Help: 471
    Rate: 1240
    It will not do anything - on all devices supported by mydrive you will not launch navcore from the card. Contact the manufacturer by phone. They will help.
  • #12 17262049
    Sniezynka
    Help: 199
    Rate: 841
    If the navigation generates a ttgo.bif file on the card, it should be successful.
  • #13 17262095
    koala106
    Help: 471
    Rate: 1240
    unfortunately it does not
The TomTom 4EN52 Z1230 navigation device encountered a failure during a NAVCORE update, freezing at 3% and subsequently displaying only the drum logo. Users suggested troubleshooting steps, including checking for a damaged map file on the SD card, ensuring the device is fully charged, and attempting to access the DOS window by pressing the ON button multiple times. The absence of an SD card was noted, complicating recovery efforts. Instructions from the TomTom support website were found unhelpful, and users were advised to contact the manufacturer for further assistance. The generation of a ttgo.bif file on the card was mentioned as a potential indicator of successful recovery, but it was confirmed that this did not occur.
TL;DR: TomTom 4EN52 Z1230 stuck on the logo after update? Keep battery at 100%—"navigation must be 100% charged otherwise it will not move." Use the Power-button recovery sequence, then connect to MyDrive Connect for restore. [Elektroda, Sniezynka, post #17261717]
Why it matters: This FAQ helps TomTom 4EN52 Z1230 owners recover devices that boot-loop after a failed MyDrive Connect update.
How do I fix a TomTom 4EN52 Z1230 that’s stuck on the drum logo?
Use the forced recovery sequence. Power on, wait for the logo and drum sound, then enter the diagnostic screen and trigger recovery. After that, connect to your computer to proceed. This method targets firmware recovery without relying on SD boot. Keep the device connected and do not interrupt the process. [Elektroda, Sniezynka, post #17261673]
Why did my update freeze at 3% and now it won’t boot?
The device experienced an interrupted Navcore update. Users report freezes at 3%, followed by a permanent logo screen at boot. When connected, you may see a blue screen with a navigation icon and two circular arrows. That indicates the unit awaits recovery. Start a forced recovery and then reconnect it to the computer. [Elektroda, MQKris, post #17260078]
Can I start Navcore from a microSD card on this model?
No. On MyDrive-supported TomTom devices, Navcore does not launch from an SD card. Use the official recovery route instead. If recovery fails repeatedly, contact TomTom. This model family expects firmware delivered through MyDrive Connect, not SD boot. [Elektroda, koala106, post #17262007]
My PC doesn’t show an extra drive when I plug the TomTom in. Is that normal?
Yes, for this model. It uses MyDrive Connect and does not present as a standard USB mass-storage disk. That is expected behavior during updates and recovery. Manage updates and recovery through the MyDrive Connect application rather than file browsing. [Elektroda, MQKris, post #17260884]
How do I perform a forced recovery boot on the 4EN52 Z1230?
Follow this 3-step sequence:
  1. Turn it on; at the TomTom logo and drum sound, keep holding Power until a diagnostic screen appears.
  2. Press the Power button three times to trigger recovery mode.
  3. Connect the device to your computer to continue the restore. [Elektroda, Sniezynka, post #17261673]
Do I need a full battery to recover the device?
Yes. Charge it fully first. As one expert noted, “the navigation must be 100% charged otherwise it will not move.” Low battery often prevents the recovery routine from starting or finishing. Connect it to a reliable charger until it reaches full charge before attempting recovery. [Elektroda, Sniezynka, post #17261717]
Where can I get the correct Navcore for 4EN52 Z1230?
Use the official TomTom support flow that starts by entering your device number. That determines the proper software for your exact hardware. Follow the guided steps provided after submitting the number. This avoids mismatched Navcore packages and failed installs. [Elektroda, Sniezynka, post #17261873]
What does the blue screen with a navigation icon and two circular arrows mean?
That screen indicates the TomTom is in an update or recovery state while connected to a computer. It appears after a failed update and signals that the device awaits data from the update tool. Proceed with the recovery steps and keep it connected. [Elektroda, MQKris, post #17260078]
Will creating a ttgo.bif file on an SD card help unbrick this unit?
No. Even if a ttgo.bif is generated on the card, MyDrive-based devices will not boot Navcore from SD. Rely on the official recovery path instead. SD-boot techniques that work on older platforms do not apply here. [Elektroda, koala106, post #17262095]
When should I contact TomTom Support?
If forced recovery does not start, or MyDrive Connect cannot recover the device, contact support. As one expert advised, “Contact the manufacturer by phone. They will help.” Prepare your device number and a description of the failure. [Elektroda, koala106, post #17262007]
Does this device have a microSD slot, and does it matter here?
Yes, it has a microSD slot. The slot is typically used for map storage or expansion. However, the recovery described here does not rely on SD booting for this model family. Focus on forced recovery and MyDrive-based restore. [Elektroda, MQKris, post #17261687]
Someone said the map file on SD might be damaged—should I reload the map?
That advice applies to units where maps reside on an SD card. The suggested fix is to activate the card with the installer and reload the map. If your model updates via MyDrive and the failure was mid-Navcore, prioritize firmware recovery first. [Elektroda, Sniezynka, post #17260271]
Which tool should I use: TomTom HOME or MyDrive Connect?
Use MyDrive Connect for the 4EN52 Z1230. The device was updating Navcore through MyDrive Connect when the issue occurred, indicating that is the correct platform. TomTom HOME targets different, older device families. [Elektroda, MQKris, post #17260884]
If holding Power does nothing, what’s the next step?
Move to official recovery assistance. Persistent failure to enter recovery suggests a deeper fault or a blocked update path. “Contact the manufacturer by phone. They will help.” Have your device number and symptoms ready for faster triage. [Elektroda, koala106, post #17262007]
