[Solved] Domoticz on Raspberry Pi Zero - error writing action on switch
kamilmialek 3744 3
  • #1 17266759
    kamilmialek
    Hello on this hot day
    I had a problem with domoticz, I once put domoticz on a raspbeery pi zero, it worked until one of the housemates broke the memory card in the raspbeery(don't know how), and I put everything from the beginning.
    I put Raspbian lite, updated apt-get, and installed domoticz with the command
    curl -L install.domoticz.com | sudo bash
    after installation, did not want to start error
     libssl.so.1.0.0: cannot open shared object file
    and after the command
    cd domoticz
    ./updatebeta
    it started up, but when I got down to adding sensors, and switches with esp, I ran into a problem that I can't find on the internet of anyone having something similar (maybe I'm looking wrong) so I'm asking for your help.
    The problem is that when I log in to domoticz via 192.168.#.###:8080 and set the action in the switch to turn on the GPIO I can't save it, I click save and zero response where I change the language adds the temperature sensors with no problem.
    as in the picture the save function does not work, so I cannot control the relays....
    Do you have any ideas?
  • #2 17301687
    tomkowal
    I have exactly the same problem, there is nothing in the log Someone may have a suggestion where to look?
  • #4 17700040
    kamilmialek
    The update has helped, I am closing
