Domoticz on Raspberry Pi 3 does not collect data from ESP Easy sensors
junkier 2622 1
  • #1 16991681
    junkier
    My domoticz does not collect data from several types of sensors. It displays an exclamation mark icon there is no button for logs with graphs.
    The system consists of a raspberry pi 3 and a sensor on espEasy. If I add a UV sensor in the raspberry pi then yes it exists with an icon and graph until it sends data to the raspberry pi in espEasy. Also the same happens with the wind sensor. I would like to mention that in the equipment tab you can see the collected values but the icon with the logs is not there either.
    What could be the cause?
    I found a similar problem
    Link
  • #2 17005759
    junkier
    The anomalies in domoticz are due to the incorrect format of the data sent from the sensor to the software.
    I gave up on espeasy. I wrote my own procedure for sending the data.
