NAC IDE105VS-GY 1050W vs POWERMAT PM-MW-2500+: Which Budget Drill to Buy for Home Renovation?
arab91 8919 4
  • #1 17274298
    arab91
    Hello, I am facing a choice of a drill in the budget up to 250 PLN. I am facing a renovation at home, so I don't want to spend more, a drill will probably be the best solution, it can be used for everything. On the popular website I found two that would suit me, but I don't know anyone who would come into contact with these companies. Can anyone recommend something?
    NAC IDE105VS-GY 1050W or POWERMAT PM-MW-2500 +?
  • #2 17274414
    adversus
    Level 32  
    Help: 188
    Rate: 597
    Rather, look for something from Castorama or Leroy. Why Because on alledrogo you can save something, but if it comes next year, it may not be anywhere.
    DIY stores sometimes give a 2 or even 3 year warranty, during which the return of the cash register, or you will get a new one (the most common option).
    Certainly, tools made for supermarkets are better than the ones you mentioned.
  • #3 17274612
    yogi009
    Help: 848
    Rate: 2650
    You ask, more or less, whether to risk throwing PLN 250. If you are buying a drill, you should really consider something branded. You won't buy Metabo or Makity, but there are slightly cheaper products. You are not writing anything about the applications that power should have, whether it should have the function of stroke, etc.
  • #4 17274857
    arab91
    A rather necessary stroke. Applications include home finishing and general home applications. Yogi, what do you suggest?
  • #5 17274905
    yogi009
    Help: 848
    Rate: 2650
    Look what's up at Bosch, for example, you probably won't make a budget, but personally I don't see the point of spending the average amount on anything. It is better to add a little and have some equipment. At least that's my approach. If a Chinese product fails you and you do the work, then you will find that it makes no sense.
