BU-808A: How to wake up a dormant Li-ion battery?
42027 25
  • Li-ion batteries can enter sleep mode when self-discharge and the protection circuit drain them below the cutoff, disconnecting the cells from the terminals.
  • A charger with a boost function wakes the pack by applying limited current to the contacts until the protection circuit reactivates, typically in about a minute.
  • Cadex tested 294 returned cell phone batteries and recovered 91% of the cells with 80% or more capacity; 9% would not wake up.
  • Do not revive cells below 1.5V per cell for a week or more, and watch polarity carefully because reversed connection can permanently damage a dormant Li-ion cell.
  • About Author
    Anonymous wrote 0 posts with. Been with us since 1978 year.
  • #2 17245014
    simw
    Help: 94
    Rate: 288
    Another interesting article. Thanks.
  • #3 17245097
    398216 Usunięty
    Help: 3925
    Rate: 9447
    Marek_Skalski wrote:
    Do not use this method on batteries that have dropped below 1.5V / cell
    How to check it if, as you write yourself,:
    A dormant battery shows no voltage at its terminals
  • #4 17245166
  • #5 17245409
    abdul.98
    Help: 21
    Rate: 57
    Gentlemen, I do not know how you, I only have Imax B6 (original), unfortunately it does not have the function of waking up the cells, but it successfully manages to lift the cells manually by setting the charger to the NiCd battery charging mode, the current set to 1A and charging to slightly over 3V and checking the temperature every now and then the cells do not heat up then normal charging and the lajonki lift up nicely without special chargers
  • #6 17245463
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3350
    It should be mentioned that the most popular 18650 cells or modeling packages do not have any protection system apart from protection against overheating. We will not wake them up, because at 0V they will be dead.
    Those with added security are marked as "protected".
    The battery is a cell + safety electronics.
    The battery is a rechargeable cell, period.
    Protected 14500 and regular 18650:
  • #7 17245521
    abdul.98
    Help: 21
    Rate: 57
    18650 maybe not to zero, but 0.1V and they get up
  • #8 17245608
    abart64
    Help: 271
    Rate: 633
    I have a 18650 complete with a Dell package. Unfortunately, I left it for half a year, they have gone to zero and nothing can pick them up anymore. I cracked the battery, cut it into individual pieces, but each one is like a piece of wire, the short circuit is almost complete - 8A at 1V. Even one piece does not start :(
  • #9 17246070
    abdul.98
    Help: 21
    Rate: 57
    A colleague probably wants to lose his paws by giving 8A, I pick up the 18650 with the Imax B6 charger, I charge first as NiCd 1A until it gets 3V, checking if it does not heat up and then like a normal lajon and they rise
  • #10 17246137
    rafbid
    Help: 153
    Rate: 418
    abdul.98 wrote:
    piotr_go wrote:
    It should be mentioned that the most popular 18650 cells or modeling packages do not have any protection system except overheating protection. We will not wake them up, because at 0V they will be dead.
    I picked up the phone battery from 0.00V, it only had overheating protection.
  • Ohmmeter current revived a 0 V Li-ion cell
    #11 17246660
    koczis_ws
    Help: 43
    Rate: 391
    You learn all your life :) . I did not know about such protection and I managed to revive the battery from the cell, which showed 0 V by accident. I wanted to measure the voltage again but I did not notice that the meter was set to ohms. The meter showed something there, but I realized my error, I switched to volts and, surprisingly, something around 3 V appeared. You can see the current from the ohmmeter revived the battery.
    After charging with a standard charger, the battery started to work normally.
  • Rejecting salvaged Li-ion cells from junk packs
    #12 17246748
    max-bit
    Help: 117
    Rate: 857
    There are, for example, guests on ajeglo who sell such picked up akku from junk packages (mainly from laptops)
    These are generally used garbage batteries
    Recently, there has been a flock of scandals with burning garbage cans (reportedly such landfills have already recorded more than 60 fires since the beginning of the year.
    As they call it, the so-called junk mafia that brings garbage from the EU, there is nothing to do with it, a fire breaks out.
    Unfortunately, it quickly turned out that no one knows how many such dumps (because they are not registered).
    Interestingly, the reason is that so far such garbage went to, for example, China, only that the latter stopped accepting the world's garbage.
    SO we say no to all originators to pick out junk akku from packages.
  • Advocates extending battery life over disposal
    #13 17246790
  • Raise storage charge and recharge yearly
    #14 17247535
    vodiczka
    Help: 1185
    Rate: 4311
    The purpose of this topic is to extend the life of the battery and use its potential to its limit. I think it's better for us and the environment than throwing away and buying the next and the next and the next ...
    Rather, it is a corpse resuscitation because a properly used battery does not require magic tricks
    Knowing that the battery will not be charged for more than 12 months, it makes sense to increase the starting charge.
    It is enough to recharge regularly once a year :)
    Situations in which the battery cannot be recharged with this frequency are an exception to the exceptions.
  • #15 17247719
    kowal011
    Help: 21
    Rate: 267
    But bullshit. The batteries from the phone can be saved more or less like this, but the 18650 from the laptop does not go to sleep ...
  • #16 17248229
    szeryf3
    Level 30  
    Help: 12
    Rate: 674
    With this article, I'll try to wake up a few batteries that I thought were completely dead.
  • #17 17249368
    CMS
    Help: 258
    Rate: 2601
    kowal011 wrote:
    but 18650 from the laptop does not go to sleep ...
    Fact. If it is not, then the link is secured. But also some 18650 0V ones can be raised.
  • #19 17249648
    398216 Usunięty
    Help: 3925
    Rate: 9447
    oskare2345 wrote:
    As a curiosity. Maybe risky, but as you can see it works.
    The power of the Internet and YT in particular ...
  • #20 17250010
    CMS
    Help: 258
    Rate: 2601
    I did that too, but no drilling. There is something like a bimetallic fuse under the positive pole, only one time. Sometimes it is possible to save such a link by gently pressing the fuse so that it returns to its original position.
  • #21 17251881
    szeryf3
    Level 30  
    Help: 12
    Rate: 674
    In the video, YT warns a lot against wrongdoing, but you can try and the knife will work.
  • #22 17254512
    E8600
    Help: 529
    Rate: 2520
    Personally, I can say that such protection can be a trap. This is because I encountered several cases, that this protection was damaged, and as a result the cell was charged above the safe voltage. This happened mainly in the batteries of the phones, which quickly became round as a result of overcharging. After checking the microscopic electronics, she was to blame for charging the Li-ion cell up to 5V.
    Recently, I have encountered such a thing in the battery from the Huawei modem.
    A recycled battery, after 1 charge it was ok, but when discharging it showed a negligible capacity of 150 mAh, while during the 2nd charge it swelled. So play, show your kitty what's inside, check the tensions. The voltage on the cell was 4.3 V, the voltage on the electronics contacts was only 3.7 V and it did not want to go up. Checking the voltage on the cell during charging, and 5V there, I cut the cell and checked the voltage on the electronics, and there it was over 5V, even though the electronics was powered by 4.2V from the TP4056 charger module.
    The cut-off link under the charger has come to life and has a decent capacity of about 2000 mAh. As the link was a bit swollen after this one charge, I treated it a bit with a vice and despite the subsequent cycles, the hold does not swell.
    It will be used to power an oscilloscope / multimeter or other invention.
    Another note for posterity, this battery consists of 2 cells connected in parallel, probably from Nokia.
    My theory, excessive discharge during long storage of an uncharged cell can damage electronics in some models.
  • #23 17257715
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    Wake-up is based on applying voltage to the battery contacts while limiting the current to a small level.
    Can someone give some specific values? Although the range "from to"?
  • #24 17258101
  • #25 17258128
    E8600
    Help: 529
    Rate: 2520
    I do not know if it makes sense to play with power supplies when the cheapest TP4056 charger does the trick. Initially, the cell gives a slight current of 5-10 mA, after increasing the voltage to 2.5 V, it starts charging with full power to 1A.
    I put a dozen or so cells on this charger.
  • #26 17298959
    lufex
    Rate: 18
    By the way, the battery, the battery taken out of a 2-3 year old asus, so swollen that only a small needle was enough to end its life quickly.
Li-ion batteries can enter a dormant state due to over-discharge, where a protective circuit disconnects the battery to prevent damage. To revive a dormant battery, specific chargers can boost the voltage to deactivate the protection system. Users discussed various methods to wake up batteries, including using chargers like the Imax B6 in NiCd mode, which can manually raise the voltage. Some users reported success in reviving 18650 cells, while others noted that batteries left at 0V may be irreparable. The discussion also highlighted the importance of proper battery management and disposal, as well as the risks associated with damaged batteries. Additionally, the use of TP4056 chargers was mentioned as an effective solution for waking dormant cells.
TL;DR: 91 % of warranty-returned phone packs revived after “a one-minute 0.05 C boost” [BatteryUniversity]. “Treat voltages below 1.5 V as irreparable” [Elektroda, Marek_Skalski, post #17244865] Safe trickle to 2.9 V wakes protection, but cells left at 0 V for weeks remain hazardous.
Why it matters: Successful revival cuts e-waste and prevents fires from misidentified dead cells.
• Protection IC opens at 2.2–2.9 V per cell [Elektroda, Anonymous, post #17244865] • Recommended wake-up current: 0.05–0.1 C (≈60–120 mA for 1200 mAh) [Elektroda, Anonymous, post #17258101] • Do NOT revive cells ≤1.5 V for over a week: copper bridging risk [Elektroda, Marek_Skalski, post #17244865] • Lab test: 91 % of 294 packs restored to ≥80 % capacity [BatteryUniversity] • Hobby TP4056 charger starts at 5–10 mA until 2.5 V, then 1 A max [Elektroda, E8600, post #17258128]
What is a “dormant” Li-ion battery?
A dormant battery still contains charge, but its protection circuit has tripped because the open-circuit voltage fell below the safety threshold (≈2.2–2.9 V) [Elektroda, Anonymous, post #17244865] Externally it measures 0 V, making ordinary chargers treat it as defective.
How can I tell if the cell is below 1.5 V when I read 0 V at the terminals?
Feed the pack with a constant-current source (≤0.1 C) for 60 s. If terminal voltage remains near 0 V or current hits its limit, the cell is likely <1.5 V and shorted internally [Elektroda, Anonymous, post #17245166]
What wake-up current and voltage limits should I apply?
Use 0.05–0.1 C current until the cell reaches 2.5–2.9 V, then switch to normal CC-CV charging [Elektroda, Anonymous, post #17258101] This level re-energises the protection IC without stressing the chemistry.
Is it safe to revive cells stored below 1.5 V for weeks?
No. Copper bridges may have formed, causing partial short circuits. Charging can overheat the cell or ignite it [Elektroda, Marek_Skalski, post #17244865] Treat such packs as electronic waste.
Which commercial chargers include automatic wake-up?
Many Cadex, SkyRC and Texas-Instruments-based designs apply a built-in boost pulse of 0.05 C for about one minute, then proceed if voltage exceeds 2.8 V [BatteryUniversity].
What failure signs appear during the boost test?
Signs include voltage stalling below 2 V, current quickly maxing out, or rapid temperature rise. Lab tests showed 9 % of packs could not reach threshold and were scrapped [BatteryUniversity].
How can I prevent batteries from going to sleep?
Store Li-ion at 40–50 % state-of-charge and top up annually. If storage will exceed 12 months, start nearer 60 % to offset self-discharge [Elektroda, Anonymous, post #17244865]
Does a successful revival hurt long-term capacity?
The Cadex study found 91 % of revived packs still delivered ≥80 % of original capacity after cycling [BatteryUniversity]. Capacity loss mainly depends on how deep and how long the prior discharge lasted.
What environmental benefit comes from reviving instead of disposing?
Each smartphone battery contains about 37 g of cobalt-bearing cathode. Recovering one pack avoids mining roughly 44 g of ore and keeps toxic metals out of landfills [USGS, 2022].
Are there legal or recycling rules for dead Li-ion cells?
EU Directive 2006/66/EC requires separate collection and recycling. If revival fails, place the cell in an approved battery recycle box; never incinerate because metallic lithium can ignite [EU Legislation].
