SkyConnect Satellite Internet: Setting Up a 25/3 Mbps Network for 8 Computers near Katowice
michal_kato 11592 9
Should I choose LTE or SkyConnect satellite internet for an 8-computer office near Katowice, and what setup is best for stable office use?
Use LTE instead of satellite if you can, because satellite was described as expensive, unstable, and having very high ping [#17305247][#17306162] For your location, check the nearby base stations and test Orange and T-Mobile SIMs with an LTE phone plus the Network Cell Info app, because stability and speed depend on signal quality, band availability, and cell load [#17306162][#17306457] The advice was to start with these LTE tests first and only consider satellite if LTE proves unusable [#17306154][#17306162] If you choose Orange, avoid the Flybox Sky / IDU-ODU200; the better option mentioned was a ZTE MF286 router with an external antenna [#17306443][#17306457]
  • #1 17304724
    michal_kato
    I have read your forum many times, getting help. This time I didn't find an answer to my question.
    I am setting up a network in a small company (about 8 computers). It is on the outskirts of Katowice and, unfortunately, I can only choose LTE, which I am not convinced of, and satellite internet. I have never had contact with him. I am considering the 25/3 option - it is enough for office work.
    http://www.skyconnect.pl/oferta
    Please share your experience. Thank you very much in advance for your statement.
  • #2 17305247
    makosuu
    Help: 369
    Rate: 370
    Horrendous cost, huge ping. LTE is better, you can check them on the phone what is the signal and speed, after that you can choose something.
  • #3 17306096
    michal_kato
    Thanks for the comment. I will give you more details. The price criterion is not taken into account. The price of 99/149 is acceptable.
    I checked LTE offers and they have a limit of 100GB, which I think is definitely not enough for 10 computers (it is not possible to buy additional packages) If you know such an offer, please send a link.
    Internet is used for e-mail / browsing / maybe 2 remote sessions a month.
    The question is: What is the stability / failure rate of the internet?
  • #4 17306154
  • #5 17306162
    matek451
    Help: 4352
    Rate: 5810
    Location? you need to check what the base stations look like nearby. Plus the tests. Unlimited offer for companies in T-mobile http://www.t-mobile.pl/r/repo1/tm/documents/doc_00008/D_007_0016492.pdf in the B525 router subscription with aggregation of 2 LTE bands /. Alternatively, an offer for individuals with no limit home internet for PLN 49 with DL up to 20 Mb / s, for PLN 65 with DL up to 60 Mb / s in the B525 subscription. In addition, MAX internet for individuals for 79.99 without data and speed limits, in the B525 subscription http://www.t-mobile.pl/r/repo1/tm/documents/doc_00008/D_007_0016555.pdf In Orange offer for Internet companies office office for PLN 51 / net https://www.orange.pl/view/internet-mobilny-dla-firm#chcenowynumer + PLN 14 for the MF286 router, total PLN 65 net in exchange for 1TB of data. Stability, speeds depend on several factors, signal parameters, base station load. Forget the crap on the internet via satellite, random storms and on the internet. Expensive, space ping. Enter the location, I will advise you what to do next. You can do the tests on t-Mobile, Orange cards and LTE phones with the Network Cell Info application.
  • #6 17306423
    michal_kato
    I am waiting for the Orange cable until Monday, but initially they said that they do not have any lines. Therefore, I am already looking for an alternative. Location Katowice, Wożniak. I have already looked at the maps BTS, Orange and T-mobile. 1 station is approx. 700m away and the second station is 800m away.
    Indeed, an offer of 999MB would be sufficient.
    What is your opinion on the Orange Flybox Sky.
  • #7 17306443
    makosuu
    Help: 369
    Rate: 370
    michal_kato wrote:
    999MB
    Rather 999GB, because 999MB is not enough :)
    LTE category 4 for a pile of money, a joke not equipment. Avoid this. In Orange, the best ZTE MF286 is currently the best, and an external antenna.
  • #8 17306457
    matek451
    Help: 4352
    Rate: 5810
    Starting with the hardware, their IDU-ODU200 (Flybox Sky) is junk for me, I gave what equipment comes from Orange and none other than the MF286. And why Orange, did you do some test of this operator? The price of this 999GB internet is gross, like the MAX from T-Mobile for individuals for PLN 79.99 / month, but in T-Mobile there are no limits. Both operators use the same NetWorks BTS and the infrastructure on them is poor, only shared LTE1800 at 15MHz in MIMO2x2 at Lwowska 32, Bednorza 2a and Bednorza 19. There are permits for LTE2600 and LTE800 but you need to check if they work. In general, as I wrote, we start with tests on Orange and T-Mobile cards and an LTE phone with Android and the Network Cell Info application, we show the DATA and speedtests tab. God forbid we listen to the consultants of Orange or T-Mobile.
  • #9 17306727
    michal_kato
    Tomorrow I will be there and I will do the tests for sure. I will share the results here.
  • #10 17327108
    michal_kato
    Orange succeeded. Despite everything, thank you for every statement.
The discussion revolves around setting up a satellite internet connection (25/3 Mbps) for a small company with 8 computers near Katowice. The user expresses concerns about the high costs and latency associated with satellite internet compared to LTE options. Several participants suggest exploring LTE solutions, highlighting the limitations of data caps on various plans. Recommendations include testing local LTE coverage from providers like T-Mobile and Orange, with specific mentions of the ZTE MF286 router and the Flybox Sky equipment. The user is advised to conduct signal tests using an LTE phone and relevant applications to assess the best option before committing to a satellite service.
