How to control all the roller shutters simultaneously with rnp-01 and srp-02?
herejs1 1590 7
  • #1 17318205
    herejs1
    Hi. I have 7 external roller shutters in my house. I have a zamel srp-02 controller mounted at each one and I control them only with a zamel p-256/36 remote control (I have no switches mounted) I raise and lower them individually, but I would also like to control all of them simultaneously. How do I do this? I don't own any central on/off switch. I do, however, have a zamel rnp-01 transmitter. Is it possible to get hold of this?
    kj1
    Electrician specialist
    Help: 278
    Rate: 850
    Can't you use your remote control for this? From its operating insructions:
    Bank 6 is dedicated to the central control function (central switching on or off of several receivers or roller shutters),
  • #3 17318749
    herejs1
    But how do you do it? I've been looking for instructions on how to program it, but unfortunately I haven't found anything anywhere, hence my question. Is it possible to lower them individually and all together.
    kj1
    Help: 278
    Rate: 850
    You will find a description of the programming in the roller shutter controller's manual. You will have to reprogramme each roller shutter separately. If the description in this manual is not clear to you, please call zamel support. The telephone number is on the website.
  • #5 17319797
    herejs1
    I programmed it and it works . Thanks :-) , which means it comes out that I was misled in the shop. They told me to buy the RNP-01 transmitter, which I now have left. What can I use it for?
  • #6 17320037
    kj1
    Help: 278
    Rate: 850
    Try returning it.
    You can also programme it. Mount it somewhere (by the door) permanently.
  • #7 17320075
    herejs1
    Giving it away is out of the question, as I bought it last year when I was in the building stage. Mounted permanently under what? And how do you program it? Can you explain any more?
    kj1
    Help: 278
    Rate: 850
    This is a circuit that is designed to work in the box (permanently connected). It has 4 inputs (you can connect 4 buttons, e.g. 2 raise/lower sets). You can divide the roller shutters into two groups and open and close each group from the buttons . Mount the buttons in a place convenient for you (as long as they are close to the switch so you can get power from them). You operate the programme in the same way as with this portable remote control - each roller shutter separately using a new transmitter.
A user with seven external roller shutters controlled individually via Zamel SRP-02 controllers and a Zamel P-256/36 remote sought a method to operate all shutters simultaneously. The solution involves reprogramming each SRP-02 controller individually using instructions from the controller's manual or Zamel support. The Zamel RNP-01 transmitter, initially recommended for centralized control, is a permanently mounted device with four inputs for connecting buttons to control up to two groups of shutters. It requires installation near a power source and programming similar to the portable remote, enabling group control via physical switches. The RNP-01 can be used to divide shutters into groups for simultaneous operation, but individual programming of each shutter remains necessary.
