Dishwasher connection to the water - 1 valve for the battery and the dishwasher
MaciekJ 60063 6
  • #1 17331837
    MaciekJ
    I have a situation like a photo - I have a water tap only for the battery, I need a distributor to which I can connect the battery + the dishwasher.
    Is this something OK?
    https://allegro.pl/invena-zawor-kulowy-trojdrogowy-1-2x3-4x1-2-i6923078706.html
    Possibly someone can take a specific link with what to buy?
  • #2 17331869
    czareqpl
    Help: 196
    Rate: 580
    I had a similar problem a month ago.
    I took a picture of the connection from the dishwasher, tap and went to the construction store.
    I gave the employee what I wanted, he selected the right valve and found the appropriate gaskets ... In your case, it will probably fit, what you found on the Allegro, but remember the gaskets.
  • #3 17331878
    MaciekJ
    I was in Casto that I completed with several elbows / gaskets / adapters that I gave up ;)
    I would prefer 1 proper valve to make it look and fulfill my role the best.
  • #4 17331897
    czareqpl
    Help: 196
    Rate: 580
    Hmmm I was in Casto too and I got it with one valve and a foil with a few gaskets ...
  • #5 17331919
    Kenworth 18
    Help: 2415
    Rate: 3702
    What a colleague found can be used, but from what I see, you still need to buy a 3/4-inch nipple.
    Another solution is to buy a tee and use 2 valves for 3/4 of the whole.
    A colleague still needs to check if the battery does not accidentally have 3/8 tubing, because it changes the form of things.
  • #6 17332517
    MaciekJ
    The battery has just been ordered, we will see what will come.
    I also ordered an adapter from one post - I will jump to Casto for a nipple.
    I'll let you know after assembly or I've managed to fold it
✨ The discussion revolves around connecting a dishwasher and a faucet using a single water tap. The original poster seeks advice on using a distributor valve to accommodate both the dishwasher and the faucet. Responses suggest various solutions, including using a combination valve that allows for independent shut-off of each appliance. Users recommend visiting construction stores for appropriate valves, gaskets, and fittings, with some mentioning the need for specific adapters and nipples. A link to a potential valve option is provided, along with suggestions to ensure compatibility with existing plumbing dimensions.
