[Solved] Laptop Stuck at 'Preparing Automatic Repair' Screen - MSI gv62 7rc Windows 10
AdameSzz 13950 7
  • #1 17363567
    AdameSzz
    Level 4  
    Rate: 15
    Hello. I have been struggling to start my laptop for several hours. Every now and then after starting the inscription "preparing automatic repair" appears and when you do it it shows a blue screen with the inscription "The automatic repair program could not repair your computer" and there is also the inscription "log file: E: \ Recovery \ WindowsRE \ Winre.wim \ System32 \ logfiles \ Srt \ SrtTrial.txt ". It doesn't even help to restore to factory settings, because an error pops up. The laptop is MSI gv62 7rc
    Windows 10
  • #2 17363576
    iJuliusz
    Help: 29
    Rate: 9
    Have you changed the BIOS settings?
  • #3 17363585
    AdameSzz
    Level 4  
    Rate: 15
    Yes. I restored to factory settings
  • #4 17363595
    iJuliusz
    Help: 29
    Rate: 9
    If after this a problem occurred, it means that the Windows startup access settings have changed
    Take a look at Manual
    Page 3-26
    Description of the boot mode in the BIOS
    Code: Dos
  • #5 17363631
    AdameSzz
    Level 4  
    Rate: 15
    I have set to Uefi and continue the same
    iJuliusz
    Help: 29
    Rate: 9
    Try switching to Legacy and check
    then if you have UEFI with CSM options
    In other Bios there are such settings, maybe also in yours
    Set Secure Boot to Custom
    Launch CSM on Enable
  • #7 17363678
    AdameSzz
    Level 4  
    Rate: 15
    I set it to flying and it didn't help like UEFI with CSM
    I did not help secure boot on custom, and launch CSM I could not find
    Added after 14 [hours] 48 [minutes]:
    Anyone can help me?
  • #8 17372727
    AdameSzz
    Level 4  
    Rate: 15
    However, the system failed. I had to reinstall
✨ The discussion revolves around an MSI GV62 7RC laptop that is stuck on the "Preparing Automatic Repair" screen while running Windows 10. The user has attempted to restore the laptop to factory settings but encountered errors. Responses suggest checking and adjusting BIOS settings, specifically the boot mode configuration. Recommendations include switching between UEFI and Legacy modes, enabling CSM (Compatibility Support Module), and setting Secure Boot to Custom. Despite these attempts, the user ultimately had to reinstall the operating system due to persistent issues.
