[Solved] HDMI dvi or hdmi stb? - Which input to connect the computer to the TV through?
Dominik0990 23376 3
  • #1 17378511
    Dominik0990
    Rate: 76
    Hello, I have a Samsung TV with two HDMI inputs and I want to connect my Pc through one input, I have already done it, but I wonder which input is better to connect via HDMI DVI or HDMI STB? I am asking for help and best regards :)
  • #2 17378550
    sosarek
    Help: 9320
    Rate: 15542
    I have via HDMI DVI, in the TV settings additionally the computer option (or something similar) is selected for this input.
    Z
    Pka, Poznań, 60-850
  • #3 17378600
    sylweksylwina
    Help: 1883
    Rate: 2356
    Strange descriptions, HDMI to HDMI should not matter. The port described STB is supposed to be for the decoder ... But rather wherever you connect it will work. I met with the fact that the port described as MHL in the Samsung monitor / TV deteriorated the image quality, but you do not have this connector.
  • #4 18056713
    Dominik0990
    Rate: 76
    I connected via dvi.
