Using Samsung Galaxy Note 3 to Control Infrared Gate: App/Frequency Suggestions
OPservator 28581 5
  • #1 17427186
    OPservator
    Help: 557
    Rate: 1246
    Hello, I am using Samsung Galaxy Note 3 and I wonder if there is any application or other way to enter a specific frequency in my phone so that it can open and close the gate.
    PS. I don't know if it's a good department.
    Thank you in advance for your reply, best regards.
  • #2 17427239
    TvWidget
    Help: 472
    Rate: 699
    Is it about automatically opening the gate when you appear near it?
    Almost all smartphones now have the option of enabling BLE broadcasting. This works in the background and does not drain the battery faster. The receiver at the gate detects the presence of such a smartphone at a certain distance, establishes a connection with it and performs authorization. If it succeeded, the gate is opened. The whole operation takes a split second. Of course, the automatic mode can be switched to manual.
  • #3 17427248
    leonov
    Help: 1039
    Rate: 2248
    The gates do not have bluetooth, the gates are controlled by radio, so how will your phone connect to the controller? unless you have infrared control, then any remote control application from the store that has the function of copying the original remote control.
  • #4 17427473
    TvWidget
    Help: 472
    Rate: 699
    Of course, the smartphone cannot control the gate by radio without a special receiver.
    I assumed that the author of the question allows adding a module to the gate controller.
  • #5 17427603
    Zbigniew 400
    Help: 283
    Rate: 794
    Have you thought about the simplicity of control and safety?
    In addition, not every control has a separate open input.
    TvWidget
    Help: 472
    Rate: 699
    Virtually every driver has so-called multi-family building mode. In this mode, the gate probably always opens when you press the button on the remote control. Closing is automatic. In more sophisticated solutions, the receiver has two outputs with opposite states. One contact opens the gate in a classic way and the other breaks the photocell circuit to prevent it from closing. It's a case of someone stopping in front of the gate for a long time.
    Where security reasons do not allow automatic opening, this can always be done at the push of a button in the application.
    I live in a multi-family building. I can open the gate by means of an intercom. This solution is widely used in many places. I think the potential threats are similar to those of automatic opening.
