Combination of IKEA TRADFRI remote control with ZIGBEE 3.0 gateway (Lidl) - functionalities and 2.4G
austin007 6357 3
  • #1 19127417
    austin007
    Help: 6
    Rate: 278
    Can I log the IKEA TRADFRI remote into the zigbee BRAM (lidl zigbee 3.0) and what functionalities will it support. He works on the 2.4GHZ band?
    I tried and it paired the Lidl led "bulb" with this IKEA remote logging the device out of the Zigbee network.
    Combination of IKEA TRADFRI remote control with ZIGBEE 3.0 gateway (Lidl) - functionalities and 2.4G .
  • #2 19829664
    xdcer
    Rate: 26
    I'm linking to the topic, I have the original Tuya gateway and with it the Ikea Tradfri button doesn't connect. I wonder if it will connect to the Lidl Silvercrest because the Tradfri bulbs connect.
  • #3 19863628
    austin007
    Help: 6
    Rate: 278
    I have not found a solution. Maybe some alternative firmware needs to be uploaded, a la HA.
    Lidl gateway uses Tuya Zigbee, not IKEA TouchLink
    #4 20181042
    agendek
    You will not be able to 'connect' IKEA remotes directly to other manufacturers' devices using TouchLink, due to the encryption key that only IKEA devices have (by the way, the same is true for other manufacturers supporting TouchLink - each manufacturer has its own 'secret' key :) ).
    The remote should connect to the gateway using the classic connection (aka 'network steering' or 'classic join') (4 clicks of the pairing button) (but this Lidl one I see doesn't accept it).
    Generally the gateway from LIDL is based on the TUYA ecosystem - and this has its communication layer on the standard ZCL Zigbee - presumably to avoid Zigbee certification/fees. Some of the devices work (e.g. light bulbs, which TUYA can handle on the standard Lightning cluster - but only to a limited extent - I don't think colors work from what I remember).
