Utilizing DMDE Software for NTFS Disk Partition Recovery: A Novice's Query
peter0 1806 1
  • #1 17499735
    peter0
    Hello there, I am not quite sure how to proceed with the following issue I have and mind I am a novice if it comes to hardware issues.
    My disk is failing obviously, but it did not collapse yet. I tried to many things with linux and windows tools (nothing too advanced, as I didn't want to do more harm to the disk) but I cannot recover the disk.
    Then I discovered DMDE and I decided to give a try. It looks the software loads the partitions. My question is: would it be possible to restore MTF or am I stuck with recovering files from the disk?
    I have preformed the full scan.
    Here is raw log:
     LBA:0                  block: 0
     0000000000: EB 52 90 4E 54 46 53 20  20 20 20 00 02 08 00 00  í³«Rí²NTFS    .....
     0000000010: 00 00 00 00 00 F8 00 00  3F 00 FF 00 1B 05 A5 04  .....í³ž..?.í³¿...í²¥.
     0000000020: 00 00 00 00 80 00 80 00  AF F8 50 09 00 00 00 00  ....í²€.í²€.í²¯í³žP ....
     0000000030: 04 00 00 00 00 00 00 00  39 BF 4A 00 00 00 00 00  ........9í²¿J.....
     0000000040: F6 00 00 00 01 00 00 00  4D 56 2A 19 90 12 7D 2C  í³¶.......MV*.í².},
     0000000050: 00 00 00 00 FA 33 C0 8E  D0 BC 00 7C FB 68 C0 07  ....í³º3í³€í²Ží³í²Œ.|í³»hí³€.
     0000000060: 1F 1E 68 66 00 CB 88 16  0E 00 66 81 3E 03 00 4E  ..hf.í³‹í²ˆ...fí²>..N
     0000000070: 54 46 53 75 15 B4 41 BB  AA 55 CD 13 72 0C 81 FB  TFSu.í²ŽAí²»í²ªUí³.r.í²í³»
     0000000080: 55 AA 75 06 F7 C1 01 00  75 03 E9 D2 00 1E 83 EC  Uí²ªu.í³·í³..u.í³©í³’..í²ƒí³¬
     0000000090: 18 68 1A 00 B4 48 8A 16  0E 00 8B F4 16 1F CD 13  .h..í²ŽHí²Š...í²‹í³Ž..í³.
     00000000a0: 9F 83 C4 18 9E 58 1F 72  E1 3B 06 0B 00 75 DB A3  í²Ÿí²ƒí³„.í²žX.rí³¡;...uí³›í²£
     00000000b0: 0F 00 C1 2E 0F 00 04 1E  5A 33 DB B9 00 20 2B C8  ..í³.....Z3í³›í²¹. +í³ˆ
     00000000c0: 66 FF 06 11 00 03 16 0F  00 8E C2 FF 06 16 00 E8  fí³¿.......í²Ží³‚í³¿...í³š
     00000000d0: 40 00 2B C8 77 EF B8 00  BB CD 1A 66 23 C0 75 2D  @.+í³ˆwí³¯í²ž.í²»í³.f#í³€u-
     00000000e0: 66 81 FB 54 43 50 41 75  24 81 F9 02 01 72 1E 16  fí²í³»TCPAu$í²í³¹..r..
     00000000f0: 68 07 BB 16 68 70 0E 16  68 09 00 66 53 66 53 66  h.í²».hp..h .fSfSf
     0000000100: 55 16 16 16 68 B8 01 66  61 0E 07 CD 1A E9 6A 01  U...hí²ž.fa..í³.í³©j.
     0000000110: 90 90 66 60 1E 06 66 A1  11 00 66 03 06 1C 00 1E  í²í²f`..fí²¡..f.....
     0000000120: 66 68 00 00 00 00 66 50  06 53 68 01 00 68 10 00  fh....fP.Sh..h..
     0000000130: B4 42 8A 16 0E 00 16 1F  8B F4 CD 13 66 59 5B 5A  í²ŽBí²Š.....í²‹í³Ží³.fY[Z
     0000000140: 66 59 66 59 1F 0F 82 16  00 66 FF 06 11 00 03 16  fYfY..í²‚..fí³¿.....
     0000000150: 0F 00 8E C2 FF 0E 16 00  75 BC 07 1F 66 61 C3 A0  ..í²Ží³‚í³¿...uí²Œ..faí³ƒí²
     0000000160: F8 01 E8 08 00 A0 FB 01  E8 02 00 EB FE B4 01 8B  í³ž.í³š..í² í³».í³š..í³«í³Ÿí²Ž.í²‹
     0000000170: F0 AC 3C 00 74 09 B4 0E  BB 07 00 CD 10 EB F2 C3  í³°í²¬<.t í²Ž.í²»..í³.í³«í³²í³ƒ
     0000000180: 0D 0A 41 20 64 69 73 6B  20 72 65 61 64 20 65 72  ..A disk read er
     0000000190: 72 6F 72 20 6F 63 63 75  72 72 65 64 00 0D 0A 42  ror occurred...B
     00000001a0: 4F 4F 54 4D 47 52 20 69  73 20 6D 69 73 73 69 6E  OOTMGR is missin
     00000001b0: 67 00 0D 0A 42 4F 4F 54  4D 47 52 20 69 73 20 63  g...BOOTMGR is c
     00000001c0: 6F 6D 70 72 65 73 73 65  64 00 0D 0A 50 72 65 73  ompressed...Pres
     00000001d0: 73 20 43 74 72 6C 2B 41  6C 74 2B 44 65 6C 20 74  s Ctrl+Alt+Del t
     00000001e0: 6F 20 72 65 73 74 61 72  74 0D 0A 00 00 00 00 00  o restart.......
     00000001f0: 00 00 00 00 00 00 00 00  80 9D B2 CA 00 00 55 AA  ........í²€í²í²²í³Š..Uí²ª
     LBA:0                  block: 0
     Disk identifier (Windows):
     2052474Dh
     Boot  System ID   :   First    :    Last    : Relative : Number of:
     Flag              :Cyl Head Sec:Cyl Head Sec:  Sector  :  Sectors :
     20h 70h ??        : 365  99 47 : 371 114 37 :   6579571:1917848077:  915 GiB
     65h 43h ??        : 288 115 51 : 364 116 50 :1953251627:1818575915:  867 GiB
     20h 72h ??        : 288 116 47 : 372 101 51 : 225735265:        10: 5.00 KiB
     00h 00h           :   0   0  0 :   0   0  0 :2642411520:     51890: 25.3 MiB
     MBR signature (0xAA55):
     AA55h
  • #2 17504684
    siasku
    Help: 17
    Rate: 14
    we need to see SMART attributes in order do diagnose of possible hdd damage.
    If i was at your place i would make an image of the whole disk using Acronis True Image for instance and i would try to recover the partitions using this image rather than on the hdd itself to avoid making it even worse.
