LG TV & TP-LINK TL-MR6400 Router Connected via WiFi, but No Internet Access - Troubleshooting
Miki2324 48372 5
  • #1 17510106
    Miki2324
    Rate: 10
    Hello, I have a problem with connecting the TV to the Internet using wifi, I bought an LG TV and wants to connect it via wifi with a TP-LINK TL-MR6400 router. TV sees the network and connects to it, but unfortunately there is no internet, even though it says "internet connection available". When entering the tv advanced wifi settings, all four icons glow green. The IP address and MAC etc. are correct, after entering the tp-link page, in statistics, it also shows me that everything is connected, on the list it shows me my TV. I tried to reset the TV and router, but nothing helps. I made a wifi hotspot from the phone, connected to the TV and the Internet works, and through the router I do not want
    Anyone have any idea? Thanks in advance
  • #2 17510148
    Epic
    Level 30  
    Help: 147
    Rate: 108
    1. Paste the LAN and Internet configuration from the router configuration.
    2. Paste the picture with the exact message displayed on the TV.
    3. Are other devices connected to this router working properly?
  • #3 17510258
    jimasek
    Help: 3783
    Rate: 2681
    DNS server addresses are a common problem in this connection. Add these to the DHCP of the router to which the TV connects, e.g. 8.8.8.8 and 8.8.4.4
  • #4 17510285
    Miki2324
    Rate: 10
    [Img-1]
    Added after 41 [seconds]:
    [Img-1]
    All connections work from other devices
    How to add it, I have the MAIN DHCP entries
    I setting, client, address
  • #5 17510311
    jimasek
    Help: 3783
    Rate: 2681
    Add them in the router configuration (DHCP server). Then reset the router and TV current.
  • #6 17510315
    Miki2324
    Rate: 10
    You are a master thanks to works
