[Solved] Audi A6 C6 VCDS: Disable Unfastened Seatbelt Warning, Original Coding Values Changed
gawi89 24621 4
  • VCDS coding changes from 2113158 to different values
    #1 17544477
    gawi89
    Hello, recently the belt light started blinking while driving (you had to move the buckle to stop it).
    I decided to disable the control via VCDS, unfortunately problems arose.
    Here is a picture from the manual, module 17, coding
    The default was 2113158, so I changed the penultimate digit to 0.
    It seems to have improved, but my big surprise caused me to enter the coding again, it changed to completely different numbers.
    Even more interesting is that after trying to enter the value that was at the beginning (2113158), I click do, I enter and there are other numbers.
    I would like to add that now I have an average fuel consumption in miles per gallon, because according to the instructions above, the third from the last two is USA.
    Am I doing something wrong? Is it coded / converted differently?
    What to do to go back to the standard (2113158) settings?
    Thanks in advance for your answers and tips.
    best regards
    AliYO
    Help: 27
    Rate: 57
    Since you are using version 17.8.1, I guess it's another rice clone. Perhaps another ADAKO security. Drive to someone with non-VCDS hardware and try recoding again. If it goes, let us know, it would be important information for clone owners.
  • #3 17545449
    gawi89
    I don't know, it's soft and my friend's cable, from what he told me, he paid quite a lot for it, so I guess it's not a pirate trip, but I don't know myself. So I'm doing everything right?
    1133
    Help: 12
    Rate: 29
    Chinese maple. I had the same thing in A4b7. And with this cable I was not able to return to the value that was at the beginning. In the end, I returned to the original value with a different cable, and then turned off the squeaking of unfastened belts without much problem.
  • #5 17549302
    gawi89
    Thanks so much for the answers, you were right, it's the cable's fault. I drove up to a guy who apparently had the original VCDS and he entered the same value with me without any problems, except that everything worked.
