"smart home" in portable devices with LI-ION batteries
Bartybart 759 1
  • #1 17556788
    Bartybart
    Welcome,
    I have a question about creating a portable LED strip light powered by a Lithium Ion battery with a smart home system. The main thing I want is to be able to switch it on and off from a smartphone (possibly change the light intensity level but only a possibility, it would be nice if there was such an option). The lamp will be charged using a stand that will be connected to a contact: the stand will charge the head in which the battery and the LED strip are built in, which can then be removed and used portable, drawing power from the battery. So my question is: Is it possible to install such a smart home module in my lamp, which will draw energy not only from the socket but also from the battery ? If so, I would very much appreciate it if you could tell me which module to buy and which type of battery would be best for this purpose. Communication between the lamp and the smartphone can be via bluetooth or wifi, it does not matter much.
    Regards
    EDIT: I found something like this (https://www.netram.co.za/3600-sonoff-sv-safe-voltage-wifi-wireless-switch-smart-home-module-support-secondary-development.html), do you think it will be suitable ?
  • #2 17560535
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    You can use ESP8266 or ESP32.
    If you don't want to write your own software then take an interest in ESPeasy
