Peugeot 206 (2003) 1.2 Petrol - Right Low Beam Not Working: Bulb & Fuse Box Help Needed
vasteq 29757 5
  • #1 17594228
    vasteq
    Rate: 184
    Hello, my wife has a Peugeot 206 petrol, I think 1.2, from 2003 and the right low beam bulb does not burn, and it is not the fault of the bulb because after switching places to the left lamp it is still the same. The left one is on. I'm looking for a fuse for this light. Someone will help to find it because I see that every year, different have fuse boxes.
    Below is a photo of the fuses under the steering wheel:
    And here is a photo under the hood next to the battery:
  • #2 17594417
    automobilklub
    Help: 21
    Rate: 176
    I don't think each light has a separate fuse. If one works, the reasons must be looked for in the cables between the lamps or in the bulb socket.
  • #3 17594459
    vasteq
    Rate: 184
    I don't know, maybe yes, but somewhere I found a description of fuses, which shows that each light has a different fuse, below is the photo. But I don't know what year and model it is from. For me, there are probably no numbers such as 32 (right passing):
  • #4 17596139
    automobilklub
    Help: 21
    Rate: 176
    This table shows that these are actually split circuits. The right dipped beam is connected to the indicator on the board - does the indicator light on when you turn on the dipped beam?
    If so, use the meter in your hand and it will be quickest to check each fuse in the 7.5A-10A range with a circuit continuity test. Only disconnect the battery earlier so as not to burn the meter ...
  • #5 19659010
  • #6 21769219
    arek182
    Rate: 20
    Hello I have a similar problem namely no dipped headlights on the left front side the lamp after short connection works the same when connected to the car computer, during the diagnostics also lights up the lamp after connecting to the plug which is factory in the car so in my case where should I look for the cause.please advise.... peugeot 206 2005
