How to run Apple Airplay on a Raspberry Pi in seven easy steps
ghost666 15105 4
  • A Raspberry Pi AirPlay server built with Shairport Sync lets older speakers and Hi-Fi gear receive music from an iPhone or iPad.
  • The setup uses headless Raspbian Lite, SSH, forced 3.5 mm audio output, and systemd autostart so the Pi behaves like a dedicated receiver.
  • The tutorial targets Pi 3 A+ or 3B models, runs in seven steps, and sets Raspberry Pi volume to 100% for clean output.
  • After pairing, the Pi appears as 'raspberrypi' in AirPlay and streams audio successfully once the phone volume is raised.
  • Pi Zero models can be harder to configure, the built-in jack sounds weak, and Wi‑Fi power saving may need disabling.
  • How to run Apple Airplay on a Raspberry Pi in seven easy steps
    Do you have audio equipment that is too old to support Apple Airplay that you want to use? You don't want to replace it with lower-quality wireless speakers, but want to listen to music from the Internet? This is a common problem. The good news is that solving this problem costs as much as the Raspberry Pi - not much. Based on this minicomputer, a simple Airplay server can be set up, which will allow us to directly transfer music from our iPhone or iPad to an older audio system.
    In the following tutorial, we will describe how to set up a Shairport-sunc server on a Raspberry Pi in seven easy steps
    Before you start
    Before we start configuring and programming the hardware itself, there are a few things we need to consider.
    Choosing the right 'Raspberry' model
    Perhaps some Raspberry Pi is already at home, then there is no problem with choosing. Most models should work in the application described below, but it can be problematic, for example, Pi Zero, due to the fact that it is more difficult to configure network connections there. Before we start setting up our Raspberry Pi Zero, it's a good idea to read more about it on the internet. The Pi Zero W model will no longer have such problems. The single-core processor found in the Zero models is quite good at dealing with the audio stream, at least as long as you don't tell it to do anything else.
    If we want to buy a new raspberry, it is best to use Model 3 The author used the Raspberry Pi 3 A + in his design, because he wanted to reduce the size of the system and the built-in interface, but the 3B model will work equally well.
    Choice of operating system
    The first thing you will need is an SD card with an image of the operating system on the Raspberry Pi. Currently, the choice is much wider than it used to be - from the traditional Raspbian through dedicated operating systems for multimedia devices to Windows 10 in the version for Internet of Things systems.
    The Airplay server is not like Kodi, which will require a screen to showcase its rich graphical interface. Basically, this device can work completely headless, with no user interface, as all settings are made from the iOS or macOS client device. It is practical to have a display of some sort to show the data of the track being played - author and title - but this is in no way required for the operation of the system.
    With these requirements, we can see that we should look for a rather minimalist operating system that does not introduce a lot of additions, because in order to guarantee the stable operation of the Airplay server without jams, it is good to minimize the number of processes currently running on 'Raspberry' - this will leave enough RAM as well as free computing power for the server.
    The problem with these types of simplified systems (such as. Arch Linux), however, is that they require a lot of knowledge from the user. They are advanced and fast, but there is also a good chance that when trying to install some applications or libraries on them ...
    At the other end of the spectrum, operating systems are so optimized for new users that we learn absolutely nothing about the architecture and use of that operating system by using them.
    We can read more about operating systems for the Raspberry Pi in this forum topic .
    Due to the above, the author decided to use Raspbian in the Lite version. On the one hand, it is a mature, advanced operating system based on the traditional Raspbian OS, but it has been simplified - the GUI was abandoned so that it could work on weaker machines. It is easy to configure (despite working only with a text terminal) or to maintain, thanks to the possibility of headless system management via, for example, SSH. Thanks to this, the machine will not need a keyboard or a mouse, only a network connection, which is needed for the Airplay server to work anyway. This makes Raspbian Lite perfect for use in the application below.
    Installing Raspbian Lite and starting SSH
    If you already have a Raspberry Pi with an installed system, or if you know how to do it, you can skip the first step - installing the operating system on your computer. If you need to start by installing the OS, you can follow the steps below this guide .
    After installing the operating system and starting the Raspberry Pi, we can use Raspi-config to connect to the computer with SSH help. This way we can run the Raspberry Pi fully headless and configure it conveniently remotely from our own computer.
    Airplay server configuration
    1. Dependency installation
    First, we need to install the dependencies that the application itself will require. In the terminal, first update the system, and then install the latest versions of individual libraries:
    Code: Bash
    2. Build and install shairport-sync /
    This software, written and maintained by Mik Brady, is a very interesting package that turns a Linux machine into an Apple Aurplay server. It works directly from the command line and despite many configuration options, it is very easy to run.
    First, we clone the repository from github:
    Code: Bash
    Then we enter the shaairport-sync folder and configure the application build:
    Code: Bash
    Finally, we can build and install the application:
    Code: Bash
    After this step, we already have a working installation of our application - the Airport server - on our 'Raspberry'.
    3. Configure the audio output.
    We can now configure the server to play the sound the way we want. First, we need a suitable output:
    * Any headphones with a 3.5mm jack.
    * Active speakers with a cable with a 3.5 mm jack.
    * Cable with a 3.5mm jack on one side and two RCA plugs on the other to connect the RPi to your Hi-Fi equipment.
    In raspi-config, we have to set the sound to be redirected to the 3.5 mm output - by default, the 'auto' option is selected, which is too imprecise for us. In the command line, enter:
    Code: Bash
    Then we choose "7. Advanced Options ", and" A4. Audio ", select option number 1" Force 3.5mm ('headphone' ;) jack ". This will force the audio output to the headphone jack.
    4. Volume setting.
    The volume should be immediately set to 100% and adjusted in further elements of the audio path, e.g. the amplifier. To set the volume to 100% in the Raspberry Pi, enter in the command line:
    Code: Bash
    It is not so easy to understand exactly how the volume control works, as it is given in decibels, which for a layman may be at least unintentional. On the decibel scale, 0 dB corresponds to the maximum loudness. The lowest level is around -100 dB. Unfortunately, this is not the most complicated part of the decibel scale - it is also non-linear, which means that the volume percentages do not work as we think ... If we just want to turn the output down a little and set it to, let's assume 80%:
    Code: Bash
    It is the system that will actually set the volume to - 17 dB, but we won't hear anything or the sound will be extremely quiet. The percentages are linear to decibels, so we can't adjust them linearly. Below 70% we won't hear anything anymore. The sound is twice as quiet at 97%, so let's leave the volume at 100% without going into it and adjust it elsewhere, where it is a bit more intuitive.
    5. Let's test Airplay on a Raspberry Pi.
    Let's start by running shairport-sync:
    Code: Bash
    Now the server is up and we can connect to it. Until we do this, we won't hear anything. So let's use an iPhone or another compatible device that supports Airplay now and connect to our server. After choosing the option to connect to the player, choose raspberrypi and click "Done".
    Choosing a Raspberry Pi as the Airplay player on the iPhone.
    If you don't hear anything initially, turn up the volume on your phone, as the audio output on the Raspberry Pi is not particularly loud. At this point, we should already hear something.
    6. Configure shairport-sync to automatically start with the system.
    We want our dedicated player to be always ready and to be able to accept connections to the Airplay server immediately after starting the computer. Therefore, we need to add the shairport-sync service to be automatically started by the Pi system as soon as it loads. Fortunately, we have configured the server to work with systemd. This means that we can configure this service to start automatically on system startup. Just type in the command line:
    Code: Bash
    You should then see this type of information:
    Code: Bash
    which will confirm that we have successfully added the Airplay server to the (persistent) services launched at system startup. Now we can safely reset the computer:
    Code: Bash
    Now, after logging in via SSH, to check if shairport-sync is running, we can type:
    Code: Bash
    If everything works fine, it should result in the following system response:
    Code: Bash
    Now, every time we start the Raspberry Pi, the Airplay server will be automatically started.
    7. Preventing the loss of Wi-Fi network.
    The Raspberry Pi has a tendency to lose its Wi-Fi connection as it periodically switches to power saving mode. In our system, we want to avoid it, so that the system runs smoothly and without problems. To do this, we need to add an extra line in the configuration file / etc / network / interfaces. enter in the command line:
    Code: Bash
    And to the file we add:
    # Disable wifi power management
    wireless-power off
    After that we can reset the system:
    Code: Bash
    Now our Airplay server should run without any problems. However, if we encounter any problems, please see the troubleshooting guide below.
    If we do not see our device - raspberrypi - in the list of Airplay devices, first we need to check if the service is running. We do this by typing in the command line:
    Code: Bash
    If the service is running, and we still don't see the server, we need to check if our device is on the same LAN network, and preferably the same Wi-Fi network, as the Airplay server. Of course, both devices must be within the range of the wireless network.
    If you are connected to the server and you cannot hear anything, make sure that you have set the volume level appropriately high everywhere. On the source device it is good to set the sound to 80..90%, on the Raspberry Pi the sound should be set to max (100%). In RPi, we can check the volume level by entering in the command line:
    Code: Bash
    The command will return the current settings to us in the form of:
    Mono: Playback 400 [100%] [4.00dB] [on]
    If it's set to anything below 70% (-27dB), we'll most likely hear absolutely nothing. Therefore, it is best to set the volume level to 100% here.
    Of course, you should also check the configuration of our audio equipment connected to the Raspberry Pi.
    Notes on sound quality
    Many people may notice poor sound quality from the Raspberry Pi's built-in audio jack. Dedicated digital-to-analog converter (DAC) modules connected to the I?S interface can be used to improve the sound. There are many such chips on the market. The author tried two types of DAC. The first was the IQAudIO PiDAC +, which has the perfect shape to match the new Pi 3 A + model. He also used a HiFiBerry DAC + Zero on a Pi Zero W. Both modules are incredibly simple to set up and sound great.
    Another very popular alternative, which the author has not tested yet, is the Pimoroni pHAT DAC converter.
    There are no serious benchmarks available, but switching from the built-in audio output to a dedicated DAC will give a huge improvement in sound quality.
    Source: https://appcodelabs.com/7-easy-steps-to-apple-airplay-on-raspberry-pi
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10267, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #3 17683533
    nici
    Help: 266
    Rate: 983
    Exactly. Volumio works without any configuration. Is HDMI or analog. No problem in minutes.
  • #4 21783315
    voltenbygg
    @ElektrodaBot Which RapsberryPi model is currently best for an AirPlay server?
  • Raspberry Pi 4B is the best AirPlay server choice
    #5 21783325
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 365
    Rate: 956
    voltenbygg wrote:
    @ElektrodaBot What model of RapsberryPi is currently best for an AirPlay server?
    Short answer
    - Most versatile and "trouble-free": Raspberry Pi 4 Model B (2 GB of RAM is more than enough). It has stable gigabit Ethernet, 2.4/5 GHz Wi-Fi (802.11ac) and great audio software support. ( raspberrypi.com )
    - When miniature form factor and low power consumption count: Raspberry Pi Zero 2 W (with a sensible power supply and preferably with a DAC on I²S/USB). ( adafruit.com )
    - For enthusiasts/extensions (several services in parallel): Raspberry Pi 5 - very fast, but no built-in 3.5mm socket, so need DAC/HDMI anyway; requires 27W power supply at higher loads. ( raspberrypi.com )
    If you already have a Pi 3B/3B+/3A+ - for AirPlay audio they are still sufficient and there is no compulsion to replace.
    Detailed analysis
    1) AirPlay (shairport-sync) requirements in 2025.
    - Shairport-sync supports classic AirPlay (RAOP) and - for a few versions - can be built with AirPlay 2 support (with some limitations), resulting in lower latency; the design still does not support video/photos. In practice, it works very stably on the Pi 3/4/5, and also on the Zero 2 W. ( github.com )
    - If you want image mirroring (iOS/macOS screen), there is another program - RPiPlay/UxPlay - and it requires a more powerful CPU/network (preferably wired). ( github.com )
    2) Why the Pi 4B is the "golden mean"
    - Connectivity: gigabit Ethernet + dual-band 802.11ac Wi-Fi - realistically less dropouts/delays than on 2.4GHz with Pi Zero/3A+. ( raspberrypi.com )
    - Audio hardware: full-size USB ports (easy USB DAC connection), I²S HATs available; there's also a 4-pin jack (PWM) on board - for entry-level applications, though for Hi-Fi I recommend an external DAC anyway. ( raspberrypi.com )
    - Ecosystem: off-the-shelf audio distributions (Volumio, moOde, RoPieee XL) use shairport-sync; in RoPieee XL you enable AirPlay under the Services tab. ( ropieee.org )
    Conclusion: the Pi 4B minimises network and power issues, and has a huge headroom for parallel services (Spotify Connect, Roon Bridge, DLNA).
    3) When to choose other models
    - Zero 2 W - great 'discrete' AirPlay receiver in a small form factor; CPU (A53) is sufficient for audio, but there is only 2.4 GHz Wi-Fi and no Ethernet. Plan a DAC on I²S (HAT size Zero) or a small USB DAC. ( adafruit.com )
    - Pi 5 - sense if you want to combine AirPlay with other heavier services (DSP, HQPlayer NAA, NAS etc). Note that the 3.5mm jack has been removed, so analogue output only via DAC/monitor/AMP; 27W 5.1V/5A power supply is recommended. ( raspberrypi.com )
    - Pi 3B/3A+/3B+ - if they're lying around in a drawer, quietly use them, especially over Ethernet cable; you don't "necessarily" need a newer model for AirPlay.
    4) OS and configuration under stability
    - System: Raspberry Pi OS Lite 64-bit (Bookworm branch; from 2023 NetworkManager and PipeWire by default). This simplifies configuration and improves audio/BT management. ( raspberrypi.com )
    - Disable Wi-Fi power saving (if using Wi-Fi): in Bookworm do this via NM, e.g. nmcli connection modify <name> 802-11-wireless.powersave 2. ( github.com )
    - Network: for fixed listening, Ethernet is best - least latency and no coverage/interference issues.
    5) Sound quality - DAC matters
    - The built-in analogue (jack) on the older Pi is PWM - it works, but it's not an "audiophile" output. For Hi-Fi use a DAC on I²S (HAT) or a USB DAC. ( hackaday.com )
    - Official audio HATs are available (former IQaudio, now in the Raspberry Pi range: DAC+, DAC Pro, DigiAMP+, Codec Zero) and popular HiFiBerry (e.g. DAC2 HD). ( raspberrypi.com )
    6) What about AirPlay 2 in off-the-shelf distributions?
    - Distributions are based on shairport-sync; some images can still provide 'classic' AirPlay by default, and AirPlay 2 requires a build version with the appropriate flags (and NQPTP). In practice, this works stably on the Pi 4/5, but the implementation has some limitations (according to the project documentation). ( github.com )
    Purchase recommendations (summary)
    - Best 'one-size-fits-most': Raspberry Pi 4 Model B (2 GB) + DAC (I²S HAT or USB) + Raspberry Pi OS Lite/Volumio/moOde. ( raspberrypi.com )
    - Minimalist hidden receiver: Raspberry Pi Zero 2 W + HAT "Zero-size" DAC or small USB DAC. ( adafruit.com )
    - Expansion and multiple services: Raspberry Pi 5 + DAC + 27 W power supply. ( raspberrypi.com )
    I will inquire to refine the choice
    - Are you planning AirPlay audio only, or also video/screen mirroring?
    - Is the output to be analogue (RCA/jack) or digital (USB/HDMI/S/PDIF via HAT)?
    - Connectivity will be via Ethernet or Wi-Fi (and how far away from the AP)?
    - Do you want multi-room and/or AirPlay 2, or will classic AirPlay suffice?
    Based on this, I will select a specific DAC model and a finished system image and give you a short configuration checklist.
TL;DR: In ≈15 min you can stream 16-bit/44.1 kHz AirPlay audio (≈1.4 Mbit s⁻¹) from any iPhone to legacy hi-fi via a $25 Raspberry Pi 3A+; “Volumio works without any configuration” [Elektroda, nici, post #17683533] [Shairport-sync README]
Why it matters: It refreshes vintage gear cheaply without quality loss.
• Raspberry Pi 3A+ board cost: approx. US $25 [Raspberry Pi Foundation, 2023] • AirPlay 1 audio bandwidth: 1.411 Mbit/s ALAC @ 44.1 kHz [Apple, 2020] • Shairport-sync compile time on Pi 3B+: ≈3 min [Shairport-sync README] • Pi Zero W idle power: 0.7 W [Raspberry Pi Foundation, 2021] • Analog jack THD: typical −40 dB [Raspberry Pi Analog Audio Spec]
Which Raspberry Pi model works best for an AirPlay receiver?
Use Raspberry Pi 3A+ or 3B; both have built-in Wi-Fi and enough CPU for lossless audio [Elektroda, ghost666, post #17680407] Pi Zero W works, but network setup is harder and dropouts increase when multitasking.
Can I still use the tiny Pi Zero W?
Yes. The single-core Zero W can stream audio if it does nothing else. Expect longer compile times and mind Wi-Fi power saving, which can mute playback [Elektroda, ghost666, post #17680407]
What operating system should I flash?
Flash Raspberry Pi OS Lite (formerly Raspbian Lite). It boots headless, saves RAM, and supports SSH for remote setup [Elektroda, ghost666, post #17680407] Avoid GUI images; extra processes risk buffer underruns.
How do I start the service automatically?
Enable it once: sudo systemctl enable shairport-sync. Systemd links the unit and starts it on every boot [Elektroda, ghost666, post #17680407]
My stream drops after a while—why?
The Pi’s Wi-Fi power-management suspends the radio. Add ‘wireless-power off’ to /etc/network/interfaces, then reboot [Elektroda, ghost666, post #17680407]
Will a DAC HAT really improve sound?
Yes. Users report huge gains moving from the built-in jack to HATs like IQaudIO PiDAC+ or HiFiBerry DAC+ Zero [Elektroda, ghost666, post #17680407] THD improves from −40 dB to about −90 dB on many boards [HiFiBerry Specs].
How much network speed does AirPlay consume?
A stereo 16-bit/44.1 kHz ALAC stream needs ≈1.411 Mbit s⁻¹ (≈176 kB s⁻¹) plus small control packets [Apple, 2020]. Any 802.11n Wi-Fi exceeds this.
Edge case: I see the server but hear silence.
Check three points: 1) amixer sget PCM shows 100 %; 2) source volume ≥80 %; 3) cables seated. If still silent, run sudo systemctl status shairport-sync to confirm it is ‘active (running)’ [Elektroda, ghost666, post #17680407]
