[Solved] Wifi dimmer/to work with Alexa with cable control option - I am looking for.
m-blue 648 3
  • #1 17702140
    m-blue
    Rate: 57
    maybe someone knows of a dimmer for leds, it can be for white or rgb only, because I would need both, but with the option to control them also via cable. I know that the easiest way is to put some node in the wall and that's it - I am looking for such a dimmer which would work on the radio and have some kind of cable input. At the moment I have a lamp which changes brightness by temporarily taking away power, with remote control such a thing is rather out of the question, although I would also survive:) .
    I'm generally keen to work with amazon's alexa, but that's a secondary concern.
  • #3 17919352
    m-blue
    Rate: 57
    Thank you, I think it will be ok.
  • #4 17919361
    m-blue
    Rate: 57
    Added after 5 [minutes]:
