Popping Sound from Bathroom Socket with Gas Boiler Plugged In
Karolinadz 17757 10
Why does a bathroom socket with a gas boiler plugged into it make a popping sound, and is it dangerous?
It is dangerous and should be treated as a serious fault because it can cause electric shock or fire [#17706977] The most likely cause is a poor contact or loose wiring in the socket, especially if the boiler draws significant power, so the socket front should be opened and checked for soot, burning, or other damage [#17706911] If the socket has already been replaced and the noise still occurs, the fault may be in the apartment’s old electrical installation, not just the outlet [#17710723] In that case, a specialist should inspect the wiring and decide whether only cables need repair or whether the installation must be modernized [#17710723]
  • #1 17706897
    Karolinadz
    Good morning, I have a problem with the socket in the bathroom. From time to time it makes a popping sound (like a light bulb when it burns out). Is it serious ? A gas boiler is plugged into the socket.
    MoniTOX
    Help: 80
    Rate: 322
    Poor contact/high power consumed by the gas boiler.
    All that remains is to remove the front panel of the socket and check if there is anything sooty/burnt.
  • #3 17706927
    ta_tar
    Help: 700
    Rate: 2053
    Maybe you have loose wires in the socket. Check the socket.
    Ps. I was late.
    zbich70
    Help: 1171
    Rate: 6668
    Karolinadz wrote:
    Is it serious ?
    Yes, very serious, it may result in shock or fire.
  • #5 17707688
    Karolinadz
    I`m calling an electrician then. Thank you very much for your help and I will let you know the diagnosis.
  • #6 17710555
    Karolinadz
    There was an electrician, he checked and replaced the socket with a new one, the other one was cracked and old. After he left, the sound of the socket shot was heard again. Generally, the building dates back to the 1950s. What now, gentlemen? Call a specialist again?
  • #7 17710615
    Kenworth 18
    Help: 2446
    Rate: 3756
    The electrician didn`t mention anything about the condition of the apartment`s electrical installation?
  • #8 17710710
    jozgo
    Help: 1023
    Rate: 1346
    Since the building dates back to the 1950s, the installations are probably in Bergman tubes.
    Maybe this "shot" is transmitted through a pipe from a plastered junction box.
  • #9 17710713
    Karolinadz
    He mentioned that it was old and that it was falling apart in the next room because the socket was sparking. He didn`t mention the bathroom, but they were plugged into one wall and under the same fuse. I called him to say it had shot again and he was surprised. He`ll come back to check on Monday. I`m worried something will happen to it by then.
    Kenworth 18
    Help: 2446
    Rate: 3756
    If this is your apartment, unfortunately, the electrical installation should be repaired.
    Whether it is enough to replace the cables or whether some modernization of the electrical installation will be necessary must be assessed by a specialist.
  • #11 17710751
    Karolinadz
    I rent the apartment, so the decision will not be up to me. Well, I hope nothing bad will happen until it`s fixed.
    Thank you very much for your answers. You gentlemen are invaluable.
    If the matter is resolved, I will tell you what was the cause.
    Regards.
The discussion revolves around a popping sound emanating from a bathroom socket where a gas boiler is plugged in. Initial suggestions point to poor contact or loose wiring as potential causes. Concerns are raised about the seriousness of the issue, with warnings about possible electrical shock or fire hazards. After an electrician replaced the old, cracked socket, the popping sound persisted, leading to further inquiries about the overall condition of the apartment's electrical installation, which dates back to the 1950s. It is suggested that the electrical system may require modernization or repair, particularly if it is using outdated materials like Bergman tubes. The author expresses concern about the safety of the situation while awaiting further inspection from the electrician.
