[Solved] Pilot Elmes TH7c Remote Control: Resurrecting a Water-Damaged Device (Washed & LED Not Responding)
Yuiop28 4548 8
  • #1 17735383
    Yuiop28
    Hello Dear Colleagues
    By accident, I washed the remote control, type as in the topic, after drying the clothes I saw what happened, the LED on the remote control was on.
    For safety, I unscrewed and put the remote control on the radiator and after about 3 hours I wanted to turn it, but the remote did not respond, the LED was off.
    Can it be brought back to life so that it works properly?
    Thanks to everyone for your help.
  • #2 17735401
    sosarek
    Help: 9320
    Rate: 15540
    Have you replaced the battery?
    Paste the photo of the tile on both sides.
    Z
    Pka, Poznań, 60-850
  • #3 17735444
    Yuiop28
    The remote control was washed with the battery, after drying the clothes and clicking the green button, the LED turned on, then I took out the battery and the radiator.
    Below are photos
  • #5 17735509
    Yuiop28
    Wiping with an ordinary handkerchief or something special? Battery replaced.
  • #7 17735603
    Yuiop28
    Thank you for your help, my colleague's method helped 100%.
    sosarek
    Help: 9320
    Rate: 15540
    Yuiop28 wrote:
    helped my colleague's method 100%.
    Which? Cleaning or replacing the battery?
    Z
    Pka, Poznań, 60-850
  • #9 17735650
    Yuiop28
    Wiping with a tissue and battery replacement helped, and it worked. The 10 out of 10 gate opening test worked.
A user accidentally washed a Pilot Elmes TH7c remote control, leading to a non-responsive device despite initial signs of life from the LED. After drying the remote and replacing the battery, the user sought advice on restoring functionality. Responses emphasized the importance of thoroughly cleaning the circuit board and suggested that a simple handkerchief may not suffice for effective cleaning. Ultimately, the user reported success after cleaning the device and replacing the battery, confirming that the remote was operational again.
