[Solved] Newly Assembled Computer Loses Network Connection: DNS Server Not Responding Error
KapaCiak 19842 3
  • #1 17801689
    KapaCiak
    I put together a new computer about 2 weeks ago and since I started it there is only one problem, so every now and then it loses connection to the network, which is quite annoying when you play or use a program that requires a constant connection to the network. When I scan the connection I get this error "This computer is probably configured correctly but the device or resource (DNS server) is not responding". I have tried many methods, including:
    -https: //www.youtube.com/watch? v = MNbm0oBAXXw
    -https: //support.microsoft.com/en-pl/help/2779064/your-computer-appears-to-be-correctly-configured-but-the-device-or-res
    But neither helped. Please help
    PS
    The computer has internet via an Ethernet cable.
  • #2 17801855
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. What is this LAN cable from the computer connected to?
  • #3 17801887
    KapaCiak
    LAN is connected directly to the router. Thank you for the answer, but I think that I have dealt with the problem in changing the network card settings options, you had to enter the above-mentioned device properties and deselect IvP 6 there
  • #4 17801892
    KapaCiak
    Go to the control panel, give tasks and options for the network card, go to change the network card settings, right-click on the device we use, go to the settings and deselect IvP 6
