[Solved] Bosch WTS86515PL Dryer: Issues with Condensed Water Container Error During Long Programs
gregorsky123 50565 3
  • #1 17831871
    gregorsky123
    Rate: 41
    We have been using the Bosch WTS86515PL dryer for about 4 years. The first problems appeared 2 or 3 weeks ago.
    With long programs such as cotton and synthetics (approx. 2.5 hours), after a few minutes an error appears, which is described in the manual:
    empty the condensed water container or check the condition of the condensed water drainage hose.
    There is no external drainage, so the container remains.
    After such a shutdown, the container is only slightly full and after emptying the problem reappears. We dry clothes using short drying programs (about 10 minutes each).
    Has anyone encountered a similar problem and can help?
    Thank you in advance for your help and best regards,
    Grzesiek
  • #3 17833065
    gregorsky123
    Rate: 41
    Thank you for Link!!! I will act according to the advice.
    Regards,
    Grzesiek
  • #4 17852020
    gregorsky123
    Rate: 41
    Topic solved. A lot of disassembly, but worth it. There was a thick layer (several mm) of dirt, hair, etc. at the bottom of the tank. So the level sensor detected when the level was exceeded very quickly.
    I removed everything and it works fine.
    Thank you for the tip and best regards,
    Grzesiek
