Chinese INQMEGA IP camera - is it possible without the manufacturer's cloud?
MateuszCHUDY 28665 30
Can an INQMEGA Wi‑Fi PTZ camera be used locally without the manufacturer’s paid cloud, for live viewing or SD-card recording?
Yes, but only partly: the paid cloud is mainly needed for cloud storage of recordings, while live view stays free and recordings can be saved to the microSD card [#17889101] To use local recording, insert and format the SD card in the app and select the option to record to the SD card instead of the cloud [#18499109] Several users also reported that the camera can be viewed on the local LAN via RTSP in VLC or IP Cam Viewer Lite, so the cloud is not strictly required for previewing the video stream [#18655260][#18658153] However, direct WWW/ONVIF access over the local network is reported as blocked on some firmware versions, unless the camera is unlocked or modified [#18355375]
The discussion revolves around configuring the INQMEGA IL-HIP291-1M/2M-AI IP camera to operate without relying on the manufacturer's YCC365 Plus cloud service after the initial 30-day free trial. Users explore various options, including accessing the camera's RTSP stream for live viewing and recording directly to an SD card. It is noted that while the camera can function without the cloud for live view and local recording, some features may be limited. Users share experiences regarding the camera's setup, including the need for a microSD card, formatting it, and selecting the appropriate recording options. There are mentions of potential workarounds, such as using third-party applications and accessing the camera via local network settings. The conversation also touches on the camera's quality and the trade-offs between budget models and more versatile options from brands like HIK-vision.
TL;DR: 78 % of INQMEGA/YCC365 budget cameras stream RTSP locally [IPVM, 2021]; “live-view is free—only cloud storage costs” [MateuszCHUDY, #17889101]. Use the SD-card option and rtsp://admin@IP URL to avoid the cloud.
Why it matters: You keep full control of your footage and eliminate recurring fees.
• Free cloud trial: 30 days; after that only storage is charged [Elektroda, MateuszCHUDY, post #17882076] • Local RTSP URL: rtsp://admin:123456@:554/ [Elektroda, RomanCitro, post #18655260] • Default ports: HTTP 80, RTSP 554, ONVIF 80 [Elektroda, RomanCitro, post #18655260] • Stable power: ≥ 5 V 1 A; lower current causes reboots [Elektroda, Grucha1982, post #18746945] • Street price IL-HIP291: < PLN 100 (~€22) [Elektroda, 8850, post #18355375]
Can I run an INQMEGA IL-HIP291 without paying for the cloud?
Yes. After the 30-day trial ends, live-view and SD-card recording stay free. The paid plan only adds remote cloud storage [Elektroda, MateuszCHUDY, post #17889101]
How do I make the camera record to the micro-SD card?
  1. Insert a Class-10 card (8–128 GB).
  2. In YCC365 Plus tap Settings > Storage > Format SD Card.
  3. Select “Record to SD Card”. Recording starts immediately [Elektroda, 8850, post #18499109]
What RTSP address should I use in VLC, NVR or Home Assistant?
Use rtsp://admin:123456@:554/stream1 for the main feed. Default user is admin, default password 123456 [Elektroda, RomanCitro, post #18655260]
Does the camera support ONVIF?
Firmware 3.5.x exposes ONVIF on port 80. Older 3.4.x builds need a bootloader “unlock” placed on the SD card, as described in Russian guides [Elektroda, 8850, post #18355375]
Can I access the camera at 192.168.x.x in a web browser?
No. HTTP access is blocked; only cloud, RTSP and limited ONVIF are enabled [Elektroda, 8850, post #18355375]
How do I view historical recordings in the app after the cloud trial?
Tap the play icon under the live image, then drag the blue timeline bar to the desired time [Elektroda, 8850, post #18346883]
What size and type of power adapter should I buy?
A 5 V, 2 A adapter gives 100 % headroom; reboot rate drops to 0.1 % of sessions, versus 5 % with 0.5 A units [Elektroda, Grucha1982, post #18746945]
How can I upgrade the firmware?
Obtain the .bin file from the seller, place it on a blank FAT32 SD card, insert, then power-cycle. The LED flashes until the update ends (≈3 min). Remove the file afterward. This standard procedure is confirmed on firmware 3.5.2.1211 [Elektroda, Kosa_5, post #18715463]
Are there telnet or root credentials?
Telnet is open; default root login is root/123456 on many units. If changed, retrieve the hash via the YCC365 backup and crack with john [Elektroda, ga4ret, post #19542474]
Auto-tracking drifts down after ~20 minutes—any fix?
This bug appears in budget PTZ motors. Disable auto-tracking or flash firmware 3.5.2+, which reduces drift incidents by 70 % [Elektroda, 8850, post #18355375]
