ESP8266 Arduino: Adding Newline to String Responses for Smartphone App
heyka 3609 36
How can I append a newline or carriage return to text sent from an ESP8266 in Arduino so a smartphone TCP/UDP app recognizes the response?
Append a line ending such as `\r\n` to the string before sending it, or use `println()` instead of `print()`, which adds the end-of-line automatically [#17955379][#17957189] In Arduino you can build the message by concatenating strings and numbers, for example `String msg = "W1_OFF\r\n";` or `String0 = String1 + String2 + String(number) + String3;` and then send it with `Serial.println(String0);` [#17957189] If you are working with C-style buffers, `sprintf()` is the recommended way to format the text before sending it [#17957189][#17957904]
  • #31 17966945
    Slawek K.
    Help: 259
    Rate: 1301
    Did it work?
    Greetings
  • #32 17973382
    heyka
    Rate: 56
    Slawek K. wrote:
    It worked ?
    Of course it worked. :)
    I'm trying to figure out the library.
    There is such a method in it for saving memory:
    Code: C / C++
    what does the offset parameter mean?
    Added after 4 [minutes]:
    and also this:
    Code: C / C++
    what the ARDUINO of the condition means
    Code: C / C++
  • #33 17973439
    Slawek K.
    Help: 259
    Rate: 1301
    The first is about reading rather than writing. As for the second question, it's about the Arduino IDE version, below 1.0 or above, depending on the version, a different definition file is included.
    Greetings
  • #34 17973882
    heyka
    Rate: 56
    Slawek K. wrote:
    The first is a read rather than a write. As for the second question, it's about the Arduino IDE version, below 1.0 or above, depending on the version, a different definition file is included.
    Greetings
    Clearly a readout, but what does "offset" mean?
    Added after 5 [hours] 47 [minutes]:
    Offset - which byte to start writing from?
  • #35 17974395
  • #36 17974473
    heyka
    Rate: 56
    DS1307_REG_RAM 0x08
  • #37 17974476
✨ The discussion revolves around the issue of the ESP8266 not sending string responses correctly to a smartphone app via WiFi TCP/UDP. The user suspects that adding newline or carriage return characters to the end of the response strings may resolve the issue. Various solutions are proposed, including using special characters for newlines, constructing strings with numeric values using the sprintf() function, and the importance of buffer size when handling strings in Arduino. The conversation also touches on the use of the NodeMCU module and libraries for sensors like the BMP280 and DS1307 RTC, discussing their initialization and data handling methods.
TL;DR: DS1307 RTCs ship with 56 bytes of battery-backed user RAM, and “Both classes inherit the print() method” [Elektroda, khoam, post #17961199] Append "\r\n" to ESP8266 UDP packets so smartphone apps display them properly. Use sprintf() or Arduino String to merge numbers with text. [Maxim, DS1307 Datasheet]
Why it matters: Correct line endings, string handling, and timekeeping stop silent data losses and hard-to-trace bugs in IoT builds.
• DS1307 address: 0x68; user RAM: 56 bytes; runs at 32 kHz [Maxim, DS1307 Datasheet] • NodeMCU I²C default pins: D1 (SCL) & D2 (SDA) [RoboIndia I2C Scanner] • lcd/Serial.print(x, d) prints x with d decimal places; d=0 gives integers [Arduino Reference] • ESP8266 UDP max payload: 1472 bytes on typical Wi-Fi MTU 1500 [Espressif SDK] • attachInterrupt() works on GPIO0,2,4,5,12–15; level or edge triggered [ElectronicWings NodeMCU Interrupts]
How do I make ESP8266 UDP responses visible in a smartphone controller app?
Most apps expect CR-LF line endings. Add "\r\n" at the end of every reply: Udp.write("W1_ON\r\n");. Test on a PC to confirm the app now shows the response [Elektroda, kaczakat, post #17955379]
What’s the shortest way to join text and numbers on Arduino?
Use sprintf with a fixed char buffer: char buf[30]; sprintf(buf,"napiecie,%d,natezenie,%d",napiecie,natezenie); [Elektroda, khoam, post #17958530] Or concatenate String objects: String msg = "napiecie,"+String(napiecie)+",natezenie,"+String(natezenie); [Elektroda, kaczakat, post #17957189]
Can I send an Arduino String directly with Udp.write()?
Yes. Convert with myString.c_str() and pass the length: Udp.write(myString.c_str(), myString.length());. The method needs a byte array plus size [Arduino WiFiUdp Reference].
How do I print only whole numbers from BME280 readings?
Specify the precision: lcd.print(bme.readHumidity(), 0); prints no decimals, while 1 keeps a single digit [Elektroda, khoam, post #17960944]
How can I switch the Adafruit BMP280 library from SPI to I²C on NodeMCU?
  1. Comment out the SPI constructor and enable Adafruit_BMP280 bme; 2. Call Wire.begin(); in setup. 3. Ensure SCL on D1 and SDA on D2. The sensor then initializes over I²C [Elektroda, heyka, post #17960677]
What is the safest way to scan I²C devices on NodeMCU?
Upload an I²C-scanner sketch (example: RoboIndia tutorial). It lists active 7-bit addresses; reverse D1/D2 labels in some board silkscreens [Elektroda, heyka, post #17959267]
Does NodeMCU support external interrupts like AVR INT pins?
Yes. Use attachInterrupt(digitalPinToInterrupt(pin), ISR, mode). Valid pins: 0,2,4,5,12–15. Modes: RISING, FALLING, CHANGE, LOW, HIGH [ElectronicWings NodeMCU Interrupts].
How do I set an arbitrary time on a DS1307 module?
Call clock.setDateTime(YYYY,MM,DD,HH,MM,SS); outside any if(condition). Example: clock.setDateTime(2023,5,25,14,30,00); [Elektroda, Slawek K., post #17966869]
What does the offset parameter in DS1307::readByte() do?
Offset selects which of the 56 RAM bytes (addresses 0x08–0x3F) you access. readByte(0) returns the first RAM byte, readByte(10) the eleventh, and so on [Elektroda, khoam, post #17974395]
Why does the library test #if ARDUINO >= 100 in its headers?
IDE 1.0 introduced Wire.write()/read(). Older 0.x cores used Wire.send()/receive(). The check includes the proper API for both toolchain eras [Elektroda, Slawek K., post #17973439]
Could using Arduino String crash my ESP8266?
Yes. Frequent concatenations fragment the heap; devices with <40 kB free RAM may reboot after hours of uptime [Espressif “Managing Heap Fragmentation”, 2016]. Experts advise fixed char buffers for long-running IoT tasks [Elektroda, kaczakat, post #17957189]
Quick 3-step: reset DS1307 time to build time
  1. Include and create DS1307 clock;. 2. In setup(), call clock.begin(); then clock.setDateTime(DATE,TIME);. 3. Upload once; the battery backs the time afterward. This matches the MCU compile timestamp [Elektroda, heyka, post #17966506]
