Press for PEX TH/U: Identifying Coupler Types & Differences Between TH AU Profiles
stefbut 92013 3
  • #1 17965844
    stefbut
    Rate: 98
    How to identify what type of coupler I have
    What is the difference between th au?
  • #2 17977641
    arson18
    Help: 28
    Rate: 65
    the connector is standard and what die you crimp is a subjective choice, both types of dies fit pex fittings, TH crimps with two circles (wide circle) and the U tup die crimps with 3 circles but thinner circles. I generally use a hand press and I use the TH type, it seems more massive
  • #3 17977716
    stefbut
    Rate: 98
    The problem is that Chinese all-purpose presses are suitable for U-fittings
    Because they are too thick.
  • #4 18880632
    marcin6660
    Rate: 152
    I have connectors and I write U on them. So it's not like this, I guess.
