[Solved] Perfecta Control Application Connectivity Issues with Orange SIM Card on Perfecta 32 Headquarters
Daro1003 30321 9
Why does the Perfecta Control app stop connecting with an Orange SIM card in a Perfecta 32 alarm panel, and how can I restore the connection?
The most likely cause is that Orange has blocked or limited the SIM for use in the alarm panel, so changing the tariff alone will not fix it [#18066763][#18066860] In the reported working case, the user called Orange, explained that the card was in an alarm control panel and needed 2G/EDGE internet, and the consultant checked the blocks and removed the so-called “safe internet” block; after that, Perfecta Control started working again [#18071544] If the SIM is already blocked, Orange may unlock it only temporarily, and the problem can return later [#18068237] One reply also recommends testing the card in a phone, forcing 2G, checking coverage, internet access and account balance to confirm whether the SIM itself is still usable [#18066763]
  • Orange SIM intermittently blocks Perfecta Control and Perfecta Soft
    #1 18066711
    Daro1003
    Help: 295
    Rate: 608
    I am asking experienced colleagues for help in ensuring the correct operation of the Perfecta Control application in the Perfecta 32 headquarters with a Sim1 Orange card, Orange YES tariff - for top-ups.
    So it looks like this:
    On July 15, I launched Perfecta with an Orange SIM card and the Orange YES card tariff, everything worked fine - mainly the operation of the Perfecta Control application. Yesterday, July 16, I replaced the SIM card with a client's card, also with an Orange card, and there was a problem, the Perfecta Control application could not connect, so I removed the card and installed it in the phone. I checked the Internet, connections, text messages, everything works. I installed my own Oranga card in the headquarters on which I configured everything and the application connections worked fine, so I reinstalled the client's Orange card in the headquarters and the Perfecta Control application started working properly for about 3 hours, after which a message appeared in the application "No connection. The device is not connected to the server." And it is so until now. What is the problem here? Is the Orange network blocking something?
    I will add that the connection to the control panel via Perfecta Soft also stopped working.
  • #2 18066763
    bezpiecznykrakow
    Help: 39
    Rate: 128
    Remove the card from the control panel, insert it into the phone and check:
    -does he log in to the network?
    - switch your phone to 2G and verify whether it has coverage and whether the Internet via GPS works
    -state of funds
    Basically, in this offer, the regulations prohibit the use of a SIM card in this type of devices, so Orange could have blocked you. Unfortunately, it happens.
    BEZPIECZNY KRAKÓW (Creative Dawid Pietrzykowski-Preston)
    al. 29 Listopada 130, Kraków, 31-406 | Tel.: +48XXXXXXXXX (Show) | Company Website: https://bezpiecznykrakow.pl
  • #3 18066826
    Daro1003
    Help: 295
    Rate: 608
    Is changing the tariff alone enough?
    What pre-paid Orange tariff will work? I'm asking for a solution.
    Prepaid Orange SIMs can still lose communication
    #4 18066860
    bezpiecznykrakow
    Help: 39
    Rate: 128
    If you have a blocked SIM card, you can't change anything.
    The only sure solution is this: https://www.orange.pl/kid,4003317950,id,4003995568,title,oferta,helparticle.html
    In practice, pre-paid offers are used and people pray not to have bad luck (usually these prayers are answered).
    There were a lot of discussions on the forum about the offers, but practically all of them boil down to their profitability (so much Internet here, so many text messages there, and for PLN 3 or PLN 5, and valid for a year, etc.), which is secondary to the fact that the control panel may lose communication at any time.
  • Orange SIM cards appear to be blocked for app setup
    #5 18066923
    Daro1003
    Help: 295
    Rate: 608
    So the current card is no longer suitable for operation? The operator will not unblock it even at the request of the user/customer?
    This is the second such situation in Orange, except that in the previous case the client did not need the application but everything went wrong during installation, so any tariff in Orange is immediately blocked because my Orange card used for configuration is still being installed. works. It's probably better in other networks, but in the frequently used and not recommended Play network, I didn't have such a case.
  • Orange SIMs may be blocked after heavy SMS use
    #6 18068237
    bezpiecznykrakow
    Help: 39
    Rate: 128
    If you promise to use it on your phone, they may unlock it, but they will keep an eye on it and the situation will probably repeat itself.
    I have the impression that they are most eager to block when a lot of text messages are sent from the card - it is probably easiest for them to detect that the card is working in the headquarters. You can try switching to in-app notifications + clip in the event of an alarm, but this is in a new tab.
    From my observations, Orange is the least problematic.
  • #7 18071544
    Daro1003
    Help: 295
    Rate: 608
    The application is launched.
    Today the client dialed the number to Orange, provided his details and gave me the consultant, I told him that the card is in the alarm control panel and we need the Internet to work in 2G and EDGE technology, the consultant checked the blockages and refreshed the network operation, and the only thing that was blocking was the so-called safe internet blockage after its removal, the application started up again. Customer satisfied.
  • #9 18071725
    Daro1003
    Help: 295
    Rate: 608
    He didn't just say anything like that. He said that such problems often occur and that refreshing the network and removing the safe internet block helps. And if that doesn't help, the Sim card is damaged and please replace it at the showroom because they'll fix it as well. But I explained to the client what the problem was and that it might stop working overnight.
  • #10 18076527
    Daro1003
    Help: 295
    Rate: 608
    Contacting Orange solved the problem.
The discussion revolves around connectivity issues with the Perfecta Control application when using an Orange SIM card in the Perfecta 32 headquarters. Initially, the application functioned correctly with an Orange YES tariff SIM card, but problems arose after switching to a client's SIM card. Users suggested troubleshooting steps, including checking network access and switching to 2G. It was noted that Orange may block SIM cards used in control panels, leading to connectivity issues. A successful resolution was achieved by contacting Orange support, which involved removing a "safe internet blockage" that was preventing the application from functioning. Users shared experiences indicating that while Orange may block SIM cards, refreshing network settings can sometimes restore functionality.
