Securing an openHAB server on a Raspberry Pi without the cloud - nginx configuration?
tikooo 1068 6
  • #1 18134515
    tikooo
    Hi, can anyone tell me how I can secure a raspberrypi pi based openhab server so that when connecting from the outside a password is required without using the cloud.
    The configuration of the raspberry pi 3 on it placed openhab`ian.
    Is it possible to do it on nginx ? if yes how to configure it correctly I added it from openhabian-config level but nothing happens i.e. it does not ask for login and password.
  • #2 18134837
    cayc01
    For a quick and not-so-secure solution, you can put an .htpassword file generated, for example, from here, into the directory with openHAB (where the website starts): http://www.htaccesstools.com/htpasswd-generator/
    Ultimately make yourself an SSL certificate (at Let’s Encrypt it is free) and connect via SSL (just change the port from the default 443 to some other).
  • #3 18135537
    tikooo
    I did as you wrote but no change
  • #5 18135804
    tikooo
    I have a configuration that is created automatically
    # openHABian NGINX Confiuration #
    ## Redirection
    server {
    listen 80;
    server_name localhost;
    return 301 https://$server_name$request_uri;
    ## Reverse Proxy to openHAB
    server {
    # listen 80;
    listen 443 ssl;
    add_header Strict-Transport-Security "max-age=31536000; includeSubDomains;
    # Cross-Origin Resource Sharing.
    add_header 'Access-Control-Allow-Origin' 'http://localhost:8080/rest';
    add_header 'Access-Control-Allow_Credentials' 'true';
    add_header 'Access-Control-Allow-Headers' 'Authorization,Accept,Origin,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Content-Range,Range';
    add_header 'Access-Control-Allow-Methods' 'GET,POST,OPTIONS,PUT,DELETE,PATCH';
    ## Secure Certificate Locations
    # ssl_certificate /etc/ssl/certs/openhab.crt;
    # ssl_certificate_key /etc/ssl/certs/openhab.key;
    location / {
    proxy_pass localhost/;
    # proxy_buffering off; # openHAB supports non-buffering specifically for SSEs now
    proxy_set_header Host $http_host;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Proto $scheme;
    ## Password Protection
    # auth_basic "Username and Password Required";
    # auth_basic_user_file /etc/nginx/.htpasswd;
    ## Let's Encrypt webroot location
    # location /.well-known/acme-challenge/ {
    # root /var/www/localhost;
    # vim: filetype=conf
    and now yes openhab is running on port 8090 is redirected externally to port e.g.: 3030
    raspberry address let's say 192.168.0.5
    and the external address let's say 26.25.26.309 how to enter it correctly in this configuration
  • #6 18135820
    cayc01
    From what I understand now nginx runs on port 80 and does not serve OpenHab (which runs on port 8090). So you are not connecting to this nginx at all - at first I understood that you had configured this.
    Why don't you just use Google? Here it says exactly what you can and cannot do: https://www.openhab.org/docs/installation/security.html
  • #7 18135891
    tikooo
    After entering the sudo nginx - t command in the console, it returns a message that it works
    But when I type the IP address of the raspberry, it does not display any page and the address bar shows localhost
✨ The discussion revolves around securing an openHAB server running on a Raspberry Pi 3 without relying on cloud services. The user seeks guidance on configuring nginx to require a password for external access. Initial suggestions include using an .htpassword file for basic authentication and setting up SSL certificates via Let's Encrypt. However, the user encounters issues with nginx not serving openHAB correctly, as it appears to be misconfigured to listen on the wrong ports. Further advice points to checking the nginx configuration and ensuring it properly proxies requests to openHAB, which operates on port 8090. The user also attempts to verify the configuration with the command `sudo nginx -t`, confirming that nginx is operational but still faces access issues.
