How do I start the server on the ESP8266 automatically after booting?
VanKiller003 747 3
  • #1 18161668
    VanKiller003
    Rate: 26
    I am starting my ESP adventure using the relay board shown below. It is configured as an AP with address 192.168.4.1, and I can connect to it with my phone via wifi. I am simultaneously creating an android app to control the relay connected to the ESP8266 via TCP.
    Communication via the serial monitor of the Arduino application works without a problem. However, I would like the server ( read AT+CIPSERVER=1, 8080 command ) to be started automatically when the device is connected to a power source. Logic dictates that one would have to code an automatic start in flash memory, e.g. with the AT+CIPSERVER_DEF command - but this does not exist. I would appreciate your help in finding a solution to this problem.
    Regards
    How do I start the server on the ESP8266 automatically after booting? .
  • #2 18161760
  • #3 18161963
    VanKiller003
    Rate: 26
    Thanks for the reply.
    I'd love to, I can't find any material about this Arduino HAL though. Could you give me some links?
