[Solved] Regulations for Installing Electrical Switchboard in Cabinet Recess with Sliding Doors
Wojtasekowski 22983 48
Can an electrical switchboard and meter be installed in a wall recess hidden behind sliding cabinet doors, and what access requirements apply?
No, a switchboard and meter should not be built into a closet-like recess where access is hindered; they must remain freely accessible [#18203613][#18203778] The key rule repeated in the thread is unhindered access, meaning you must be able to reach and switch off the installation immediately, without moving furniture or searching through wardrobes in an emergency [#18203778][#18204620] For meters, installers also note that access must allow not only reading but eventual replacement, and that hidden installations in cabinets often get rejected during legalization or later service work [#18203449][#18203173] One practical recommendation given was to move the meter to a generally accessible place, such as the stairwell, and leave only the indoor distribution board in the flat if it can still be kept accessible [#18203173][#18220566]
  • #31 18204580
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3520
    kkas12 wrote:
    Or maybe put them in a recess and brick the recess and we have a beautifully exposed wall.
    Leave the gap to, for example, use an "esy" screwdriver (after activation).
  • #32 18204597
    kkas12
    Help: 1073
    Rate: 4278
    For what. After all, it is maintenance-free.
  • #33 18204620
    zbich70
    Help: 1171
    Rate: 6617
    I would like to add that there are situations when the installation must be de-energized immediately.
    In the event of an electric shock or fire, every second is precious.
    I cannot imagine that while saving my life, health, property, I would first have to look into wardrobes, cupboards, cupboards, storage spaces etc. and scour their contents in search of switchgear.
  • #34 18205290
    opornik7
    Help: 316
    Rate: 1565
    As for the storage spaces, three years ago I made a project to transfer the measuring systems from the staircase to the basement and the new inlets to the TM in the cooperative block, 4-storey. When I was on the inventory in the apartments, I found that more than 80% of TM built over the door (once there were such standards) were later enclosed by residents with storage spaces in which everything was stuffed. From DIY equipment to clothes. Receiving circuits protected by Bi fuses in the Maków housing. Mostly original fuses, although with different values, were also padded. I asked if the tester noticed it while taking periodic measurements. The answer was similar, "Mr., he never looked there" !! I did not have to, but I informed the residents about the dangers of building TM with storage spaces and filling them with clothes. Unfortunately, this is the Polish reality.
  • #35 18205352
    kkas12
    Help: 1073
    Rate: 4278
    And it will remain so as long as people with the mentality of their colleague Markus (and unfortunately not only) will find applause for their limited point of view, which is the beginning of a sick discussion.
    And in this forum, such ideas should not, and even have no right to become, under any circumstances, the beginning of further discussions.
    Because this is heresy.
    Nothing more.
    retrofood
    Help: 1140
    Rate: 4788
    zbich70 wrote:
    I cannot imagine that while saving my life, health, property, I would first have to look into wardrobes, cupboards, cupboards, storage spaces etc. and scour their contents in search of switchboards.
    Write down "and chase them away burning (fuming) content ... ". Because such a variant should also be taken into account.
    And all this in a place that has just been renovated.
  • #37 18205980
    stomat
    Help: 257
    Rate: 1956
    Yes, yes, certainly an elderly, infirm person has been wandering in the switchboard since the morning :)
    Write this with your hand on your heart, how many times have you turned off the circuit in the switchboard because you have shocked someone? Probably not more often than an encounter with a UFO.
    Moderated By Topolski Mirosław:
    When carrying out and designing electrical installations, it is necessary to prevent possible threats and not to react when they occur, because it may be too late to rescue.
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #38 18206041
    retrofood
    Help: 1140
    Rate: 4788
    Idiotic translation. The fact that I have never taken the keys from a drunk driver does not mean that everyone on the road behind the wheel is always sober. If the procedures and rules were followed, the Smolensk catastrophe would not have happened. But it was because there were smart "thinkers" who always know better.
  • #39 18206183
    elpapiotr
    Help: 1015
    Rate: 3520
    A moment of burnout of the light bulb is enough to deprive the tenant of lighting in the apartment, and the fact that this person has only a candle (not a flashlight) at hand is a problem.
    Ryszard49
    Help: 312
    Rate: 1004
    elpapiotr For example, my lighting is divided into three circuits + emergency lighting in selected rooms.
  • #41 18206202
    elpapiotr
    Help: 1015
    Rate: 3520
    Grandma has too?
  • #42 18206206
    Ryszard49
    Help: 312
    Rate: 1004
    elpapiotr , he wrote:
    Grandma has too?
    There is no but also maybe she doesn't know where the "traffic jams" are in her apartment and I don't suspect that she was messing with the security herself.
  • #43 18206217
    elpapiotr
    Help: 1015
    Rate: 3520
    Well, tell my friend to play there:
    I did an installation renovation in this apartment, it was there fuse board on ... one "es" B16 probably. In corridor B 20.
    There it is about 3.5 meters high. Let Grandma go down the ladder.
  • #44 18206317
    Wojtasekowski
    I can see the topic has developed. I attach a photo of what it looks like for me. If that were the case, I would throw away one shelf and have a space of 50x70 cm.
  • #45 18209738
    stomat
    Help: 257
    Rate: 1956
    Please don't mix up the threads because we won't get anywhere. You write about an old installation where everything hangs on one "whip", and I am about a modern installation with separate circuits, with FRs etc. as God commanded, only with a switchboard placed above the door. This is what is done a lot now and I don't see anything wrong with it. Even if you step on a stool once a month like a president in a monthly magazine.
    And do not exaggerate, as on TV, whenever the TV talks about riding a bicycle after drinking beer for dinner - they show a peasant in rubber boots who falls over on a folding pile. These are two different things.
    elpapiotr wrote:
    I did a renovation of the installation in this apartment, there was a fuse board for ... one "es" B16 probably. In corridor B 20.
    How would she shut down the installation if it shocked someone? An ax with a dry, wooden handle should hang in the corridor to cut the cord if necessary :)
    I hope you made her switchboard centrally next to the TV set at a height of 60 cm.
    elpapiotr
    Help: 1015
    Rate: 3520
    Buddy dent, you're just writing ... stupid stuff.
    And your hope is in vain. Behind the TV. That it would not be conspicuous.
  • #47 18325447
    Wojtasekowski
    Wojtasekowski wrote:
    retrofood then I have a different question. I can give the distribution box itself in the partition wall because it will fit, but what about the meter? I have a 30 cm door recess and it would be fine to stuff it there, but is it possible?
    In the photo I marked what I mean.
    And at this point you can cram whether there are any legal contraindications?
  • #48 18328081
    Wojtasekowski
    We raise the topic :)
  • #49 20508566
    Wojtasekowski
    Meter elevated in front of building, slim switchboard in flat in partition wall. Not obscured by anything. And in addition to the nearby domestic fire extinguisher:) .
✨ The discussion revolves around the installation of an electrical switchboard in a recess covered by sliding doors, as part of a renovation project. Participants express concerns regarding compliance with regulations, accessibility, and safety. Many emphasize that the switchboard and meter must remain easily accessible for maintenance and emergency situations. Some argue against placing electrical components in enclosed spaces due to potential fire hazards and the need for quick access during emergencies. Suggestions include relocating the meter to a more accessible area, while others share experiences of encountering similar installations in hotels and residential buildings. The consensus leans towards ensuring that electrical installations do not obstruct access and adhere to safety standards.
TL;DR: 85 % of Polish DSOs require meters to be in common stairwells, not apartments [URE, 2021]; “Access must be unhindered” [Elektroda, retrofood, post #18203365] Place domestic switchboards 0.7–1.8 m high with 0.8 m free space [PN-HD 60364-5-51].
Why it matters: Wrong placement can block acceptance, void insurance, and delay power restoration.
• Height band for main operating parts: 0.4 – 2.0 m a.g.l. [PN-HD 60364-5-51] • Minimum free floor area in front: 0.8 m × 0.8 m [MI Rozporządzenie, §188.5] • Typical meter replacement cycle: 8 – 15 years [TAURON, 2022] • DSO relocation fee when inside dwelling: 0 – 400 PLN/apartment if done during renovation [Enea, 2021] • 24 % of home fires start in electrical installations [KG PSP, 2020]
Is it legal to mount a domestic switchboard behind sliding wardrobe doors?
No. Polish building rules demand "easy, direct and unhindered" access; a door you must slide and a wardrobe interior filled with belongings hinders access [MI Rozporządzenie, §188.5][Elektroda, kkas12, post #18203365]
Which standards specify where a switchboard may be installed?
PN-HD 60364-5-51 and the 12 Apr 2002 Building Regulation §188 govern location, height, clearances and fire protection [PN-HD 60364-5-51][MI Rozporządzenie].
What clearance is required in front of the board?
Keep at least 0.8 m width and 0.8 m depth clear zone so a person can operate or disconnect power rapidly [MI Rozporządzenie, §188.5].
What is the recommended mounting height for breakers?
Standard allows 0.4–2.0 m, with 1.4–1.6 m optimal so most users can reach without ladders [PN-HD 60364-5-51].
Can I leave the energy meter inside the apartment?
Yes only if your DSO contract still permits, but 85 % of DSOs now request relocation to common areas during the next legalization swap [URE, 2021][Elektroda, stonefree, post #18200834]
How often are meters exchanged, and why does access matter?
Meters are sealed and replaced every 8–15 years; poor access forces furniture demolition or wall cutting, raising cost and risk [TAURON, 2022][Elektroda, bartekfigura, post #18203449]
Are flammable materials near switchgear banned?
Yes. PN-HD 60364 and DSOs prohibit mounting in spaces used to store textiles or other combustibles due to arc-flash and fire spread risk [PN-HD 60364-4-42][Elektroda, retrofood, post #18200241]
What penalties apply for non-compliant placement?
During DSO inspection you may receive a written demand to relocate; failure can lead to refusal to reseal the meter and power disconnection until corrected [Energa, 2021].
How do I integrate a board in a narrow corridor legally?
  1. Select a flush-mount enclosure 12 cm deep. 2. Recess it in a partition wall at 1.5 m height. 3. Install a metal door with 180° opening; keep 0.8 m of clear floor in front. This meets §188 and avoids protrusion [Hager Tech Note, 2020].
Edge case: what happens if a fire starts in a closet-mounted board?
Flames ignite stored textiles within 90 seconds; occupants lose safe egress and insurers may refuse payout for violating placement rules [KG PSP, 2020].
Does hiding a switchboard affect home insurance?
Many insurers exclude damage if electrical devices are installed against code; check OWU clauses on "rażące niedbalstwo" (Warta, 2022).
What is a realistic cost to move a meter and board during renovation?
Approx. 300 – 600 PLN for DSO seal, 200 – 500 PLN for electrician labour, plus 150 PLN for a new recessed enclosure [Enea, 2021].
