Samsung Dishwasher 4C Error: Troubleshooting Tips for Water Supply, Filters & Drain Issues
Poni 63153 4
  • #1 18228767
    Poni
    Hello, I have a problem with the dishwasher, as it displays error 4c in the subject. I checked the water supply, everything is ok, the pressure is right, all the filters and filters are ok. I also checked the water drain, after the reset, the water from the dishwasher is supplied correctly. When the dishwasher starts, you can hear it taking in water for about 5 seconds, then there is 3 minutes of silence and an alarm with error 4c. Does anyone have any idea what can be there and if there is no service without the service, I will add that the dishwasher is not under warranty.
  • #2 18340474
    Fil1592
    Rate: 73
    Hello, I have the same problem, did I find out what is the cause?
  • #3 18340489
    Kenworth 18
    Help: 2427
    Rate: 3726
    You should create your own topic and enter the model of the dishwasher you are asking for.
  • #4 18407137
    paczekpl
    Rate: 9
    problem with the dishwasher, as the topic displays mistake 4c.
    No water supply Error code - 4C, 4C2
    Water is not drained Error code - 5C
    Operating the washing machine with the door open Error code - dC, DC
    Main door lock / unlock not working properly Error code - DC1
    Water overflows Error code - OC
    Check the drain hose (drain hose) Error code - LC, LC1
    The washing machine does not spin Error code - UB, Ub
    Motor / pulsator motor operation error Error code - 3C, 3CP se HE
    Voltage error Error code - UCRExpand
    Water sensor error Error code - 1C
    Has anyone checked - ::
    it flies and hums systematically A [] flies like a splash from a cup B [] buzzes / beeps and you can hear a stream of water C []
    A.) 1 models with water shut-off [protection against flooding] (too rapid pressure changes) fuse on the lead with a red eyelet, flow-through connection manual ;-)
    [first start-up: 1, after installing the outlet and inflow: 2 turn on the dishwasher, it opens the solenoid valve and takes water in, so open the tap, the supply installation will gradually fill, pushing the air out !!!
    B)
    1. :arrow: water level sensor (dirty sediment / limescale) for unskilled similar in washing machines Link /
    - the hose connected to the sensor may be clogged, it does not indicate the minimum status and is too much. cuts off the water reports an error
    2. the sensor in the lower housing is not wet if it is not leaking
    3.inlet - >>> it's strange - Rinse with water, 2 blow with air (,), place a pot of 15 liters under the valve and fast with water so that particles and rust flow out of the installation an intense stream :) or connect a garden hose and rinse the water supply to the sink. & look at the instructions; )
    if not electronics ,,
    Link sensor from level /// min max /// /// ///
    :arrow: any idea what can be there and without the service there will be no work :cry: ,
    :idea: unless you already know how the fault is? of these 3
    Useful ? :!:
  • #5 18407164
    TONI_2003
    Moderator
    Help: 2193
    Rate: 3820
    paczekpl wrote:
    problem with the dishwasher, as in the topic it displays error 4c
    Buddy, you should set up your own topic and give the full and correct model of the dishwasher you are asking for.
