Holder with screw hole for Gardinia roller shutter mounting - design and 3D printing
p.kaczmarek2 3963 17
  • A custom 3D-printed mounting bracket adds a screw hole for a Gardinia roller shutter that normally mounts on a door without drilling.
  • The holder was modeled by matching the existing white blind part, then redesigned into a wall-mountable fixture with the same interface.
  • It was printed on an Ender Creality Pro 3 in Standard Quality mode, taking 39 minutes and using about 5 grams.
  • Rotating the part 90 degrees avoided supports; the printed tabs were slightly oversized and needed light filing.
  • The final mount fit tightly, held the blind solidly, and source CAD/STL files were posted for reuse.
  • Holder with screw hole for Gardinia roller shutter mounting - design and 3D printing
    Hello my dears
    Today I will describe one of my first projects completed with the help of a 3D printer ( Ender Creality Pro 3 ). This is the attachment piece for the roller shutter Gardinia , according to my own design. This roller blind as I found it is designed to be fixed "on the door" (no drilling, no screwing), so without my piece fixing it to the wall is problematic. I don't know if there are other/better blinds to mount, as I was put to the task of mounting this blind that someone had already bought. The piece I designed fits well with the mounting of this blind and has a suitable screw hole.
    The design came about entirely out of practical need, I was helping someone install this roller shutter and this was my solution. Finally, I will post the CAD files of the developed model, so anyone interested can benefit.
    Design of 3D model
    I started by modelling the object that would be attached to my element. I had no intention of printing it. I intended to use it to fit my fixture to existing parts (i.e. as a reference):
    I then prepared an already targeted element around it. The screenshot shows both elements and their matching:
    And this is how the final designed element looked like:
    And this is the element I have already printed.
    Printing the part on 3D printer
    I decided to print the project in Standard Quality mode. The print time was estimated at 39 minutes and the weight at 5 grams.
    NOTE: To print an item without the so-called supports (supports) you need to rotate it 90 degrees from how it is shown in the screenshot above. I printed it this way and that way, compared both options and decided that it was better to rotate it and print without supports , than to leave it as it is and print with supports .
    It came out reasonably well, although I found that the size of the mounting tabs (the two sticking out slightly) was a bit too big and I had to file them down slightly with a file. Nonetheless, the whole thing held together well as it went in tight.
    Final fitting (the white piece from the blind inserted into my 3D printed black mount):
    End fixation blinds
    I'm not going to judge here the point of fixing the roller shutter where it was fixed. I did what I was asked to do. I just want to show how it was fixed.
    I drilled two dowel holes in the wall and then tightened my fixings to it with screws.
    Left mount:
    Right mount:
    Then I have already placed the roller blind in them. The whole thing holds solidly and does its job well:
    Additional - leaflet of the roller blind used
    For those who are interested, I am posting pictures of the leaflet of the roller shutter for which my bracket was designed. It shows how this roller blind is normally mounted, for example on a door. This roller blind is thoughtfully designed so that it can normally be fixed without tools (even on the instructions there is a crossed out picture of a screwdriver and a screwdriver).
    The original way of attaching the blind is quite ingenious, but in my case it didn't work and so I had to come up with something myself.
    Summary
    The roller blind is holding up solidly and does not promise to have any problems.
    The weight and printing time of the component make its cost nearly zero and its usability high (fitting it does not interfere with the other parts of the blind and allows it to be moved to another location later).
    Using a 3D printer means that the component can be alternately modified , e.g. if necessary, move the hole slightly upwards by several mm when you want to make adjustments to the mount.
    In the future when I have white filament I may re-print this part, but I don't think that will necessarily be the case as so far none of the blind users have paid any attention to the colour of the mount.
    I hope that my tiny design described here will motivate someone to take an interest in 3D printing and show that this new trend really can solve a lot of everyday problems.
    I am posting the source files of my mount:
    shutterHol...191021.zip (86.06 kB)You must be logged in to download this attachment.
    Additionally; the same in STL format:
    shutterHol...191021.zip (6.28 kB)You must be logged in to download this attachment.
    NOTE: After printing, check that the catch from the roller shutter holds well in my mount. It should go in tight.
    p.kaczmarek2 wrote 14799 posts with rating 12960, helped 659 times. Been with us since 2014 year.
  • 3d printing suits the complex bracket shape
    #2 18232081
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    And that's what a 3d printer is useful for, which is what I've tried to make clear in your other topics :)
    You have a plus for this. A trinket you won't buy at the shop around the corner, and making it out of sheet metal might not work here because of the aesthetics and the relatively complicated shape that is the undersize gantry. On a milling machine it would work, but you already need a good supply of cutters of various kinds :)
  • #3 18232169
    grabo86
    It seems to me that publishing such a project on the Internet is a bit too much. More time writing about the topic than the work put into the design of a small model.
    As for the printing itself, the rotated version without support is a better solution in terms of durability. It is mainly about the layers which are perpendicular to the direction of the force on the component.
  • #4 18232471
    trippo1
    Rate: 10
    If this is the case, perhaps the forum administrators should think about adding a 3d tab in the diy section. I myself use a 3d printer and would love to look at such solutions. Congratulations on your idea and solution, in which program do you model the parts?
  • #5 18232472
    Slawek K.
    Help: 259
    Rate: 1303
    I think I'm going to start publishing my designs and 3D prints, I have at least a couple of hundred of them.
    Greetings
  • #6 18232510
    error105
    Rate: 146
    I think everyone has a few hundred 3D prints, if they have such a printer. Is every one worth bragging about? Certainly not.
    The colleague who created the post selects those that may be useful to someone and everyone can duplicate them.
    I myself have a few thousand printouts, but who will find a motorbike holder for my particular Motorola G6 Plus useful ? Or a case for a device with my PCB ?
  • #7 18232659
    Slawek K.
    Help: 259
    Rate: 1303
    error105 wrote:
    I have a few thousand prints myself, but who needs a motorbike mount for my particular Motorola G6 Plus ? Or a case for the device with my PCB ?
    Just as useful as the "Gardinia roller shutter mount".
    Greetings
  • #8 18233358
    error105
    Rate: 146
    Only that this and other roller blinds are available for sale, and there are many, many more phones to choose from. That's the difference. You don't want it don't print it, unless you want it download it, print it and put it on the shelf saying you don't need it :)
  • Questioning use of printed spacer instead of existing holes
    #9 18233374
    CMS
    Help: 258
    Rate: 2603
    It's all beautiful and even works, I hope it doesn't break after a few exposures of the blind.
    One question that bothers me is WHY?
    I see two rectangular holes in the factory roller shutter bracket, originally probably used to lock the latches from the door "hooks". What was the obstacle to using these holes? Possibly using steel washers and, if necessary, some distance from the wall (you could have printed this one out and I wouldn't have frowned, but then this wouldn't have been an issue), although I think you could have done without any distance.
    I see wasted time and filament here.
  • Defends custom design over pre-made parts
    #10 18233381
    error105
    Rate: 146
    Wasted time would be looking for pre-made figures and blindly printing without a clue. A colleague designed it himself, so no time was wasted. In the same way, it is a waste of time and money to buy an Arduino Uno and blindly copy ready-made designs without learning the basics to make at least a stupid blinking diode your own way.
    So I don't know why you are so bitter about me wasting anything.
  • #11 18233403
    CMS
    Help: 258
    Rate: 2603
    No hard feelings.
    I just think it's quicker to drill two, three or even four holes in the wall and then simply screw on the factory mount, rather than designing and printing a mount and then drilling two holes anyway.
    And it would be worth painting the print white.
    I am in favour of simple solutions.
  • #12 18233405
    Slawek K.
    Help: 259
    Rate: 1303
    error105 wrote:
    This and other blinds are available for sale, and there are many, many more phones to choose from. That's the difference. You don't want it don't print it, unless you want it then download it, print it and put it on the shelf saying you don't need it :)
    I don't think you understood the sarcasm ;)
  • #13 18233513
    woytas73
    Help: 56
    Rate: 103
    One thing I don't understand, why mess around for 8 hours when the roller shutter brackets have 2 holes for fixing....
  • #14 18233608
    CMS
    Help: 258
    Rate: 2603
    Didn't I write the same thing a little above?
  • #15 18235093
    .:KoSik:.
    Help: 19
    Rate: 308
    This can be done in various ways but this is probably not the place to publish such designs.
    Firstly, there are plenty of places where you can post your 3d designs and usually people there are looking for ready-made solutions. Secondly, everyone who has a printer makes at least a few of these projects a year, and this does not mean that they have to post their creations anywhere.
    Compared to other projects on the electrode it is unfortunately too little. I understand the implementation of the whole roller shutter, not 3 topics about nothing.
    In the rule, I think the moderation should intervene.
    Moderated By gulson:
    Moderation allows you to show any well-described DIY, and the popularisation of 3D printing is most welcome.
  • #16 18235498
    VIGOR_PICTURES
    Help: 20
    Rate: 148
    Can you give a more detailed account of what you did?
    I see from the photos that you modelled the handle in Blender. What did you do next? I just didn't know that Blender was suitable for creating objects for future 3D printing. How about dimensions and scale? Are there no problems?
    Greetings,
    Victor
  • #17 18238653
    Rate: 12960
    Yes, there are apparently two holes in the finished part, but these are holes for the striker from the door cap, not for the screws. They're not the right shape, they're rectangular, and on top of that I'd be worried that if I tightened them down any harder the plastic would just break.
    They are not designed to be screwed into the wall, and I don't like fiddling , so I designed my part (I already know the 3D program).
    On top of that, the use of a printed mount allows for very easy height adjustment (one hole is drilled, if the height doesn't match then you print another version of the element with the hole slightly lower, unscrew the old one, screw in the new one and you're done).
    @VIGOR_PICTURES you ask what happens between creating the 3D model object and printing? You export to STL and then create the GCode in Cura. I'm planning to do my own review of Ender Pro 3 Creality for Articles and will describe the process in more detail there (with screenshots).
  • #18 18240657
    .:KoSik:.
    Help: 19
    Rate: 308
    Actually, it is not suitable. Just creating simple assemblies is an ordeal, let alone dimensioning. It's a great program for creating 3D graphics and it's free.
    When it comes to modelling parts for 3D printing, SketchUp (also free) is sufficient for simple projects, and there are no problems with control as with Blender.
TL;DR: DIY 3D‑printed Gardinia roller blind wall bracket: 39‑minute print, ~5 g plastic; “The design came about entirely out of practical need.” [Elektroda, p.kaczmarek2, post #18231795]
Why it matters: This FAQ helps home tinkerers rapidly model, print, and mount a sturdy blind holder without buying proprietary hardware.
What is this bracket and who is it for?
It’s a custom 3D‑printed wall bracket that adapts a Gardinia roller blind meant for tool‑less door mounting. It’s for makers who need a clean wall‑mount solution when the stock clips don’t fit their site constraints. The design prioritizes quick print time and tight fit. [Elektroda, p.kaczmarek2, post #18231795]
How long does it take to print and how much filament will I use?
Expect about 39 minutes of print time in Standard Quality and roughly 5 g of material per bracket. That keeps the cost near zero on typical PLA. These numbers come from real prints done on an Ender 3 Pro. [Elektroda, p.kaczmarek2, post #18231795]
Should I print with supports or rotate the model?
Rotate the model 90° and print without supports. Tests of both approaches showed better results and less post‑processing when printed rotated. This also reduces waste and improves surface quality on the functional faces. [Elektroda, p.kaczmarek2, post #18231795]
How does layer orientation affect strength on this part?
Print so layer lines run perpendicular to the dominant load path. “The rotated version without support is a better solution in terms of durability,” because layer bonding resists shear more effectively that way. [Elektroda, grabo86, post #18232169]
Can I just screw the factory Gardinia bracket to the wall?
Avoid using the two rectangular factory holes for wall screws. They are latch slots, not screw bosses, and tightening screws risks cracking the plastic. The printed adapter adds a proper screw hole for reliable fastening. [Elektroda, p.kaczmarek2, post #18238653]
What printer and settings were used in the successful build?
The bracket was printed on an Ender Creality Ender 3 Pro using a Standard Quality profile. That profile delivered the 39‑minute, ~5 g result and good dimensional accuracy for a tight friction fit. [Elektroda, p.kaczmarek2, post #18231795]
What’s the exact workflow from CAD to print?
Basic flow: 1) Export your modeled part as STL. 2) Open STL in Cura and slice to G‑code. 3) Print the G‑code on your Ender 3 Pro. This path is proven for the bracket here. [Elektroda, p.kaczmarek2, post #18238653]
How do I mount the blind with this printed bracket?
1) Drill two wall holes and insert dowels. 2) Screw the printed mounts to the wall. 3) Press‑fit the Gardinia end pieces into the mounts and seat the roller. The assembly holds solidly in service. [Elektroda, p.kaczmarek2, post #18231795]
What if the catch is too tight or the tabs are slightly oversized?
Expect a tight press‑fit. If tabs are a hair large, lightly file them until the white blind insert seats flush. The designer noted this small tweak during first fit. Tight engagement prevents rattling during use. [Elektroda, p.kaczmarek2, post #18231795]
How can I fine‑tune bracket height after drilling?
Print a revised bracket with the screw hole shifted by a few millimeters. Swap the part and reuse the wall holes. This rapid iterate‑and‑fit loop is a key advantage of 3D printing. [Elektroda, p.kaczmarek2, post #18238653]
Is Blender OK for modeling parts for 3D printing?
One view is that Blender isn’t ideal for dimensioned mechanical parts; simple assemblies and precise sizing can be cumbersome. Quote: “Actually, it is not suitable.” Consider CAD‑oriented tools if you need parametric control. [Elektroda, .:KoSik:., post #18240657]
How do I generate G‑code for the Ender 3 Pro from my model?
Export the part to STL, open it in Cura, and slice to G‑code using your chosen profile. Then print from the generated file. This was the exact method used for the featured bracket. [Elektroda, p.kaczmarek2, post #18238653]
Where can I get the source and STL files?
The author shared both original CAD sources and an STL attachment with the post. Download, inspect dimensions, and test the tight catch fit before installation. [Elektroda, p.kaczmarek2, post #18231795]
Any tips on color and aesthetics?
White might match typical blinds, but the black prototype has drawn no complaints. Reprint in another filament color later if desired. Function and fit remain the priority for this mount. [Elektroda, p.kaczmarek2, post #18231795]
What failure modes should I watch for during installation?
Do not drive screws through the factory rectangular slots; they can crack. Ensure the printed hole carries the load, and verify a snug catch. Lightly deburr or file high spots to avoid stress risers. [Elektroda, p.kaczmarek2, post #18238653]
