How to ensure control reliability in Domoticz with espeasy modules?
Ibuprom 2154 9
How can I make Domoticz reliably keep ESPeasy-controlled outputs in sync after an ESP reboot or crash?
Domoticz does not give you built-in execution confirmation, so the practical fix is to add your own feedback/retry logic in DzVents or another script and periodically resend the desired output state to the ESP module [#18256912] [#18256987] On a timer, for example every 5 minutes, you can read the saved state from your own global variable and replay it, and DzVents lets you use `checkfirst()` or `silent()` to decide whether to send a command or only update Domoticz state [#18256987] The thread also suggests using API, Node-RED, Python, Lua, or MQTT to build that confirmation layer yourself, because Domoticz can be extended in several ways [#18256912] If you want restart recovery on the device side as well, one reply notes that Tasmota and ESPeasy can memorise output states in flash and restore them after a restart, and Domoticz does the same for its own state [#18341661]
  • #1 18256576
    Ibuprom
    Help: 52
    Rate: 180
    Anyone grasped the subject of the reliability of domoticz control of espeas-based modules? Domoticz as such does not check if the execution module has worked, it sends a command and that's it. The execution module could have crashed, then restarted, etc, and domoticz won't correct this because it doesn't know about it. MQTT is not a solution, because if it waits for a command to be received, it will not send it again when espeasy connects to domoticz after a reboot.
    How do you deal with the reliability of the control of the executive modules? Everywhere I see complacency about controlling the esp8266 when everything is working properly, but nowhere have I found solutions regarding long-term reliability.
  • #3 18256770
    Ibuprom
    Help: 52
    Rate: 180
    Well, yes, but ESP monitoring I can do myself with rssi charts. And that's not the point. How to force domoticz to detect and automatically update the status of the ESP when it restarts.
  • #4 18256844
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    To be honest, I don't use Espeasa much now. I prefer the more stable Tasmota. As for your question you can make yourself a feedback to Domoticz API and monitor e.g. rssi wifi in combination with notifications. E.g.when I have no rssi info from the module then Domoticz sends me notifications on Telegram.
  • #5 18256866
    Ibuprom
    Help: 52
    Rate: 180
    Ok, let it be tasmota. But notifications are a poor prosthesis, I have to log into domoticz and tap the appropriate option to update the status.
    That is to say, as I understand it, so far no one has paid attention to this and everyone is using an unpredictable system that is really useless for anything more advanced than lighting Christmas lights. The sensor monitoring works nicely, but the control is a stopgap.
    How about not domoticz and espeasy but a different set of software but still diy giving more reliability to control devices?
  • #6 18256912
    xury
    Help: 878
    Rate: 1497
    I don't really understand what you mean. You want a confirmation of execution, after all, this can be implemented for yourself and in several ways. You can use Mqtt as you mentioned yourself. You can use API, Node-red, dzvents, python, lua etc.
    You can set up telemetry (Tasmota) You can periodically renew the command, etc. You probably can't anticipate everything anyway, but the Domoticz environment is flexible enough that you can be tempted to make your own solutions.
    There are also alternative systems like Home Assistant or Openhab, Supla etc.
  • #7 18256943
    Ibuprom
    Help: 52
    Rate: 180
    Ok, then how do I set up in domoticz to periodically send the status of all outputs to the actuators? I have, for example, a lua script that calculates the pwm value depending on the slider setting called once when the slider is used. Or a simple on/off with on action and off action performed when changing the state of the switch. How to send the current settings for all actuators every e.g. 5 minutes? Then there is no need for esp restart detection. At most, you can signal its absence for more than x minutes. I have not found a solution on the domoticz forums, although I once asked a similar question there. Because I don't think it makes sense to save states as variables in a separate script and call it every 5 minutes, modifying the script every time we change something in domoticz.
  • #8 18256987
    xury
    Help: 878
    Rate: 1497
    E.g. with Dzvents. On timer every 5 minutes...
    Read about Dzvents. You can send a direct command or a command preceded by a state check - checkfirst(), or you can only change the state in Domoticz - silent().
    You can save the state to your own global variable and play it back even after restarting Domoticz.
  • #9 18257283
    Ibuprom
    Help: 52
    Rate: 180
    Ok, thank you for the tip. I will read. So far my simple automation consists of bash scripts where the control writes states to /tmp and the executive script reads them every minute and sends them to the executive modules. I thought this was covered in such an elaborate domoticz in a better way only I can't find it.
  • #10 18341661
    credens
    If my memory serves me correctly, tasmota and espeasy memorise the state of the outputs in flash and restore their value after a restart, the same with domoticz.
The discussion revolves around ensuring control reliability in Domoticz when using ESPeasy modules. The main concern is that Domoticz does not verify the execution status of commands sent to ESP modules, which may crash or restart without notification. Users suggest various methods to enhance reliability, including using the Domoticz API, MQTT for feedback, and alternative systems like Tasmota, which is preferred for its stability. Suggestions include implementing periodic status updates for actuators using Dzvents or custom scripts to maintain control even after module restarts. The conversation highlights the need for better solutions in long-term reliability for home automation systems.
