How to connect DI and RO from RS485 converter to ESP8266 NodeMCU?
robo1973 2976 14
How do I connect the DI and RO pins of an RS485-to-TTL converter to an ESP8266 NodeMCU, and what do I need to do about DE/RE?
Connect DI to the NodeMCU TX pin and RO to the NodeMCU RX pin; the RS485 transceiver also needs DE/RE control for transmit/receive direction [#18262228] [#18262239] If you only want to receive, you still need to handle DE/RE, and the ModbusMaster RS485_HalfDuplex example shows using `preTransmission()` and `postTransmission()` callbacks to control the transceiver [#18262535] Do not use `Serial.swap()` if you want USB logging on UART0, because it moves UART0 away from the usual USB pins [#18282384] Also, ESP8266 `Serial1` cannot receive data, so it cannot be used as an RS485 RX interface [#18282384]
  • #1 18262035
    robo1973
    Rate: 59
    Hello !!!!
    I bought an RS485 ba TTL adapter .
    In the loaded program I have the description
      // communicate with Modbus slave ID 2 over Serial (port 0)
      node.begin(1, Serial);
    To which pin to connect DI and R0 from the converter ?
    Greetings !!!
  • #2 18262228
  • #3 18262239
    piterek-23
    Help: 162
    Rate: 427
    You still need to connect DE/RE to control the direction of reception/transmission
  • #4 18262290
    robo1973
    Rate: 59
    piterek-23 wrote:
    You still need to connect DE/RE to control the receive/transmit direction
    I only want to receive from the device How to connect these signals ?
  • #5 18262365
  • #6 18262514
    robo1973
    Rate: 59
    #include <ModbusMaster.h>
    #include <ArduinoOTA.h>
    // instantiate ModbusMaster object
    ModbusMaster node;
    void setup(){
      // use Serial (port 0); initialize Modbus communication baud rate
      Serial.begin(115200);
      delay(10);
      //Serial.swap();
      //RS 482  DI z TX, a R0 z RX.
      //RS 482
  • #8 18262562
    robo1973
    Rate: 59
    which means that
      // Callbacks allow us to configure the RS485 transceiver correctly
      node.preTransmission(preTransmission);
      node.postTransmission(postTransmission);
    settles the matter?
    By the way, what does this function do
    publishFloat("Ppv", glueFloat(node.getResponseBuffer(1), node.getResponseBuffer(2)));
    because client.publish(topic, value); publishes to mqtt a publishFloat ?
  • #9 18262583
  • #10 18263039
    robo1973
    Rate: 59
    hee ok thank you for your help
    so it sends data to topic_char, value_char ?
  • #11 18282311
    robo1973
    Rate: 59
    How do I define communication over UART 1 TX1 RX1 ?
    Currently I have after UART 0 TX,RX
    void setup(){
      Serial.swap();
    Serial.swap(); function starts communication on UART 1 but disables it on UART 0 And I would like to have RS458 on uart1 and uart0 logging on usb
  • #13 18284437
    robo1973
    Rate: 59
    Can you explain to me how this function counts ?
    float glueFloat(unsigned int d1, unsigned int d0){
      unsigned long t;
      t = d1 << 16;
      t += d0;
      float f;
      f = t;
      f = f / 10;
      return f;
     publishFloat("Pac", glueFloat(node.getResponseBuffer(11), node.getResponseBuffer(12)));
  • #14 18284720
  • #15 18285244
    robo1973
    Rate: 59
    for the number d0 = 10 the function gives the value 1
    what does d1 do I don't really understand what it affects because each value does not change the result of the function ?
The discussion revolves around connecting the DI (Data Input) and RO (Receive Output) pins from an RS485 to TTL converter to an ESP8266 NodeMCU for Modbus communication. Users clarify that DI should connect to the TX pin and RO to the RX pin of the NodeMCU. Additionally, it is emphasized that DE/RE pins must be controlled to manage the direction of data transmission. The conversation also touches on using the ModbusMaster library for communication, with examples provided for setting up the serial communication and handling data transmission. Follow-up questions address UART configuration and the functionality of specific code snippets related to data publishing and float conversion.
TL;DR: For NodeMCU+RS485, wire DI→TX0, RO→RX0, and control DE/RE via callbacks. ESP8266 has 2 UARTs; "Serial1 cannot receive data, only send it." Use UART0 for RS485 and keep USB or Wi‑Fi logging. For makers wiring MAX485‑type modules to ESP8266 NodeMCU with ModbusMaster. [Elektroda, khoam, post #18282384]
  • Wiring: DI→MCU TX, RO→MCU RX; receive‑only: hold DE low and /RE low; terminate bus with 120 Ω at both ends. [“MAX485 datasheet”]
  • ESP8266 UARTs: UART0 TX0/RX0 on GPIO1/3 (USB); Serial.swap→GPIO15/13; UART1 TX‑only on GPIO2. [“Arduino core for ESP8266 — Serial”]
  • ModbusMaster usage: node.begin(slaveId, Serial); preTransmission/postTransmission toggle RE/DE via GPIO for half‑duplex. [“ModbusMaster RS485_HalfDuplex example”]
  • Voltage: ESP8266 is 3.3 V logic; inputs are not 5 V tolerant—use 3.3 V transceivers or level shifting. [“ESP8266EX Datasheet”]
  • Register math example: two 16‑bit registers → one 32‑bit value, then divide by 10 in glueFloat(). [Elektroda, khoam, post #18284720]
How do I connect DI and RO from an RS485 converter to ESP8266 NodeMCU?
Connect DI to NodeMCU TX0 (U0TXD) and RO to RX0 (U0RXD). This pairs the converter’s TTL side with Serial on the ESP8266. Then manage direction using DE/RE as described below. [Elektroda, khoam, post #18262228]
I only want to receive—how should I wire DE/RE?
On MAX485‑type chips, enable receive and disable transmit. Set DE LOW and /RE LOW. If your board ties DE and /RE together, pull the combined pin LOW. This keeps the driver off and the receiver on. [“MAX485 datasheet”]
Do preTransmission and postTransmission callbacks handle RS485 direction for me?
Yes. Register these callbacks in ModbusMaster to drive your RE/DE GPIO before and after each Modbus frame. The example shows how and lets you choose any pin. "DE/RE support is included." [Elektroda, khoam, post #18262535]
What does publishFloat("Ppv", glueFloat(...)) actually do?
It formats the float with one decimal, builds a topic like inverter/Ppv, and publishes retained to MQTT. The function fills topic_char and value_char buffers and calls client.publish(topic_char, value_char, true). [Elektroda, khoam, post #18262583]
Does publishFloat send to topic_char and value_char?
Yes. The function converts the float to value_char, builds topic_char, and passes both to client.publish as payload and topic. [Elektroda, khoam, post #18262583]
Can I run RS485 on UART1 and keep USB logging on UART0?
Not for receiving. ESP8266 has two UARTs, but UART1 is TX‑only on GPIO2. "Serial1 cannot receive data, only send it." Use UART0 for RS485 and log via Wi‑Fi or a second USB‑serial. [Elektroda, khoam, post #18282384]
What exactly does Serial.swap() change on ESP8266?
Serial.swap() remaps UART0 from GPIO1/3 to GPIO15/13. The onboard USB interface then stops, since it connects to GPIO1/3. Use swap only if you relocate your USB‑serial to GPIO15/13. [Elektroda, khoam, post #18282384]
How do I set the Modbus slave ID with ModbusMaster?
Call node.begin(slaveId, Serial). Example: node.begin(1, Serial) targets slave ID 1 on UART0. Ensure the slave ID matches your device configuration. [Elektroda, robo1973, post #18262514]
How do I combine two Modbus registers into a 32‑bit value?
Use glueFloat(d1, d0): compute (d1 << 16) + d0, then divide by 10 for scaling. On ESP8266, unsigned int is 32‑bit, so a single expression works. Two 16‑bit registers represent one 32‑bit number. [Elektroda, khoam, post #18284720]
d0 = 10 returns 1.0 — what does d1 change?
d1 is the high 16‑bit word. With d1 = 0, the function returns d0/10, so 10 becomes 1.0. If d1 changes but results do not, verify response buffer indexes and the device’s word order. [Elektroda, khoam, post #18284720]
How do I set up DE/RE control with ModbusMaster (quick steps)?
  1. Choose a GPIO for RE/DE and set it as OUTPUT.
  2. Write preTransmission() to set RE/DE HIGH; write postTransmission() to set it LOW.
  3. Register callbacks with node.preTransmission(...) and node.postTransmission(...), then call node.read/write functions. [“ModbusMaster RS485_HalfDuplex example”]
Which pins are UART0 and UART1 on NodeMCU?
UART0: TX0=GPIO1, RX0=GPIO3 (USB). With Serial.swap, TX0=GPIO15 and RX0=GPIO13. UART1: TX1=GPIO2 only; it has no RX. [Elektroda, khoam, post #18282384]
Is ESP8266 5 V tolerant on RX when my RO outputs 5 V?
No. ESP8266 inputs are 3.3 V only. Use a 3.3 V‑compatible RS485 transceiver or level‑shift RO to 3.3 V to protect RX0. [“ESP8266EX Datasheet”]
How should I terminate an RS485 bus for reliable Modbus?
Place a 120 Ω resistor across A and B at each end of the cable. Add bias resistors if needed per the transceiver’s recommendations. Keep stubs short to reduce reflections. [“MAX485 datasheet”]
