Configuration of ESP8266 nodemcu v3 I2S with 74HC595 shift register and max485 modules
ArtGateOne 969 0
  • Feasibility of ESP8266 I2S driving 74HC595 at 250 kHz
    #1 19253531
    ArtGateOne
    Help: 16
    Rate: 8
    I am starting the adventure with esp8266.
    I want to use I2S and a 74HC595 shift register controlling 8 modules with max485 - to send 8xDMX512
    Please give a hint to wiser heads if this is feasible.
    WS signal - controls the latch on the register
    connections
    74HC595
    14 DS Serial data input (SD)<--
    12 ST_CP Storage register clock input (WS)<--
    11 SH_CP Shift register clock input (SCK)<--
    ESP8266
    I2S
    GPIO3/RX0 Data bits (SD)-->
    GPIO15 Data bit-clock (SCK)-->
    GPIO2/TX1 Word select (WS)-->
    WS controls the latch.
    And now the question
    1 Is the I2S rate setting correct (data on register latched every 4 microseconds)
    i2s_set_rate(250000);
    2 Is the 74HC595 sliding register able to operate correctly at this speed ?
    3 If yes - is 5v necessary for it (or is 3.3 enough)
