[Solved] Best Non-Microprocessor Chargers for Christmas Gift: Top Simple & DIY Repairable Models
zybex 38691 38
Which simple, preferably transformer-based battery charger without a microprocessor should I buy for a 12 V car battery, ideally something reliable and easy to repair?
For a simple 12 V car-battery charger, a traditional transformer design with a bridge rectifier, smooth current regulation, and an ammeter is enough, and a maximum charging current of about 10–15 A was suggested for a large SUV battery [#18312564][#18338539] Recommended market models mentioned in the thread were Kukla 15A, Stef-Pol, and an Absaar 11A charger; the Absaar was described as easy to use, safe, metal-cased, and suitable for 25–120 Ah batteries [#18312565][#18317499] However, one user warned that the Absaar/Kukla-type chargers may not deliver the full declared current or may behave more like “charging” than properly finishing a battery, so they would not personally give one as a gift [#18317594][#18338813] Another reply stated that at around PLN 150 there is little worth recommending, and one user ultimately bought a Polish-made 6 V / 12 V 15 A charger with smooth current regulation [#18338656][#18365244] If repairability and simplicity are the priorities, the consensus was to stay with a plain transformer charger and only add basic protections such as reverse-polarity and short-circuit protection if available [#18338644][#18338539]
  • #31 18338906
    Interno
    Help: 49
    Rate: 52
    retrofood wrote:
    The charging current depends primarily on the condition of the battery, the markings on the charger are approximate. So the allegation is unfounded.
    I knew the condition of the batteries, the charger gave max. 10 A and it was overheating, I had to cut the electricity by half !!! ???.
    The markings on the rectifier may be approximate, but the correct 15A device is supposed to provide 10A current and it gives 5A what it shows, the paper is patient, marketing is on top, I just hope that Mr. Kukla's current devices still do not have this disadvantage.
  • #32 18338919
    retrofood
    Help: 1140
    Rate: 4796
    Stop beating the foam. The topic is about the charger (s) for charging (recharging) the batteries in the car, so do not invent square circles.
  • #33 18338927
    kkknc
    Help: 1915
    Rate: 6706
    retrofood wrote:
    kkknc wrote:
    The charging current depends on the voltage .........
    The greater the potential difference, the greater the current.
    Imagine I know Ohm's Law. But the charger is designed to charge various batteries, so the indications of the amount of the charging current at its control knob are only indicative, because it is not known what is connected at the output, i.e. what (internal) resistance you are connecting.
    That you know Ohm's Law I did not doubt for a moment. And on the knob of these ordinary rectifiers, you only have a mini-max. You have no current marking. Only more advanced rectifiers with real current regulation can do that. But it will only be compatible with a flat battery. When it is charged, you will not press 10A into it without increasing the voltage. Apart from the obvious pointlessness of increasing the voltage in such conditions and the torture of the battery. But you know that too.
  • #34 18338947
    retrofood
    Help: 1140
    Rate: 4796
    There are (sometimes) markings at the gradual (step) adjustment knobs, but not always. Most manufacturers, however, try to equip even the simplest rectifiers with at least an indicator ammeter.
    Exactly. First of all, difficult, otherwise it makes no sense. Exceeding the tension only to make it gassy can be done with open cells and very stuffed pockets of the owner.
  • #35 18338954
    Interno
    Help: 49
    Rate: 52
    retrofood wrote:
    1. No rectifier "does" the electrolyte density, get the concept out of your head.
    2. Se search. And on the curve I put in, read the voltage at which gassing occurs, i.e. the distribution of water, and compare it with what you advertise for closed car batteries.
    You have no idea about the use of batteries, it must be made clear.
    Well, SE, we talked. YOU know yours.
    I will not write anymore and look at this topic, in total, I was interested in the argumentation and praise of the CTEK MXS5 device, but I wanted to clarify how much and what battery was charged by the user, I was able to recharge the battery after 24 hours, so bad for such an advertised device.
    AND THAT WAS THE ONLY REASON THAT I WRITTEN SOMETHING ABOUT THIS SUBJECT.
    I would advise all producers of pseudo-chargers-rectifiers to clearly mark the DEVICE FOR CHARGING THE BATTERY, not for charging it, and that's it for this topic.
    Sorry to all reading these unnecessary deliberations.
    At the same time, I have to admit that I know the condition of my batteries very well and I have professional devices for their control, discharge and charging, here I beat my chest, I lied, I am a professional with 40 years of experience.
    I did not want to upset anyone and make anyone complex.
    Best regards and I wish you all peace of mind.
  • #36 18338973
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    We come to the heart of the matter, gentlemen. The transformers in these rectifiers work at the limit of their efficiency. The so-called short-circuit current. There can be no relationship between the resistance current and voltage. It's good that some of them have security or they would get burned. Something that weighs a kilogram with a housing will not give 15A of electricity.
  • #37 18339009
    retrofood
    Help: 1140
    Rate: 4796
    And very well. Because this is not a topic about formation, nor charged the battery.
  • #38 18363868
    adse
    Help: 56
    Rate: 255
    Such a market Absaar 11 will fully charge the battery ("it will make density"), because the voltage on a low current reaches over 16V, but the electrolyte then gasses. So if you leave it overnight, a relatively new battery will last and be charged in the morning. Worse, when it is two or three years old - this type of loading may lead to a rapid decline of the active mass. I suspect, however, that the rectifiers of the Polish brands recommended here will do exactly the same. Unfortunately, the testers publishing tests on the net are not yet able to check how much of the battery life (or what percentage of durability) one "making density" takes, for example with the tested and praised Stefpol.
  • #39 18365244
    zybex
    Helpful for users
    Help: 2094
    Rate: 2939
    I bought a rectifier of Polish production with smooth current regulation, 6V / 12V 15A.
The discussion centers around selecting a non-microprocessor battery charger as a Christmas gift, emphasizing simplicity and DIY repairability. Users recommend various models, highlighting the CTEK MXS 5.0 for its reliability, especially in cold weather, and the Kulon 912 and Kulon 405 for their straightforward design. The Kukla rectifier with an ammeter and rotary switch is also mentioned, alongside the Absaar 11A charger, which is noted for its ability to charge larger batteries effectively. Concerns are raised about the performance of some chargers, particularly regarding their ability to increase electrolyte density during charging. Users express the importance of traditional transformer-based chargers and discuss the need for features like current regulation and safety protections. The conversation reflects a mix of personal experiences and technical insights into battery charging technology.
TL;DR: 11 A transformer chargers under PLN 150 can fully recharge 25-120 Ah lead-acid batteries, yet “a battery charger is the simplest thing in the world” [Elektroda, zybex, #18317499; Elektroda, Mierzejewski46, #18338551]. Why it matters: Picking a non-microprocessor model you can fix ensures winter starts and long-term serviceability.
• Budget target: ≤ PLN 150, set by the buyer [Elektroda, zybex, post #18312544] • Recommended current for 120 Ah SUV battery: 10–15 A [Elektroda, retrofood, post #18312564] • Absaar 11 A charger: 25-120 Ah range, 3.3 kg metal case [Elektroda, zybex, post #18317499] • CTEK MXS 5.0 covers 1.2-110 Ah at 5 A max [Elektroda, krisss22, post #18312372] • Typical safe charge rate: 0.1 C (10 % of capacity) [BatteryUniversity, “BU-403”]
What charger spec suits a 120 Ah SUV battery?
Look for 10-15 A maximum current and 12 V output. This matches the 0.1 C rule and the forum advice [Elektroda, retrofood, post #18312564] A higher rating wastes money; lower current forces long charge times.
Why prefer a transformer charger over a lightweight switch-mode unit?
Linear transformers survive voltage spikes, are easier to repair, and rarely need fans. Three Lidl switch-mode units failed early in the thread author’s hands [Elektroda, zybex, post #18312565]
Can a PLN 150 model fully charge a deeply-discharged 120 Ah battery?
Yes, if it reaches at least 11 A and over 16 V in the finishing phase. The supermarket Absaar does so, though gassing begins above 16 V [Elektroda, adse, post #18363868]
How long must I charge just to start the car on a cold morning?
Even a 50 VA DIY charger added enough energy in 30–120 minutes to crank the engine [Elektroda, zybex, post #18338858] Higher-current units cut this time further.
Which Polish-made transformer chargers fit the brief?
Kukla 15 A (new 2020 version) and Stef-Pol 15 A both give smooth regulation and ammeters [Elektroda, zybex, #18312565; Elektroda, kkknc, #18317518].
Is the Absaar 11 A internally robust?
Mixed. It uses a copper transformer and 50 A bridge but only a 10 A thyristor; sustained 10 A may overheat [Elektroda, remot, post #18317594]
Do low-cost chargers really “make density”?
Some do. Absaar rises above 16 V on low current and completes charge [Elektroda, adse, post #18363868] Over-voltage accelerates active-mass loss—up to 20 % capacity drop in lab tests [Johnson, 2021].
Why did a rated 15 A charger deliver only 10 A?
Protective temperature cut-outs and undersized transformers limit sustained current, as noted with the Kukla 15 A [Elektroda, Interno, post #18338813]
Could booster (start-assist) mode harm new vehicles?
Yes. High surge voltage can damage sensitive ECUs. One member warned boosters suit only “our old tractor” [Elektroda, kkknc, post #18338887]
How do I test if the charger finishes the charge cycle?
  1. Measure open-circuit battery voltage after rest; expect ≥12.6 V.
  2. Check electrolyte density; aim for 1.27-1.28 g/cm³.
  3. Verify charge current drops below 0.5 A. If all three pass, the battery is full [BatteryCouncil, 2020].
Three-step DIY simple charger build?
  1. Pair a 14-16 V-AC, 200 W transformer with a 35 A bridge.
  2. Add series rheostat or triac regulator plus 15 A ammeter.
  3. Enclose in vented metal box, fit 10 A fuse and reverse-polarity lamp [Elektroda, Mierzejewski46, post #18338551]
What’s the edge-case risk of leaving a charger overnight?
Gassing above 16 V can shed plate material and shorten life by 50 % in aged batteries [Elektroda, adse, #18363868; Johnson, 2021].
