Welding Electrode Color Coding and Significance: Red vs Pink Coatings
Kukiz18 174487 7
  • #1 4798703
    Kukiz18
    Help: 8
    Rate: 38
    how in the topic, can someone name the colors of the welding electrodes and briefly describe something about them?
    because recently I was welding such an electric welder, made, and there were red electrodes with such a reddish cover, now I bought pink and that's not what it is?
  • #3 4798852
    Kukiz18
    Help: 8
    Rate: 38
    Jesus, how much of it is there, I can't figure it out, can someone explain it to the peasants' mind? what and how?
  • #4 4798939
    RoTr
    Rate: 11
    It depends on what material you welded - whether ordinary steel or, for example, stainless steel and with what current you were welding - direct or alternating - welding position?
    Some electrodes will be better suited for welding with direct current and others with alternating current - it is best to specify the type of electrode and the material to be welded. :)
    For some electrodes (e.g. ER 346) you need a little more patience - I mean arc ignition - but the welds are great - it depends more on the skills and experience in welding.
    Which material ? grade / thickness whether tube or sheet
    What welder? - direct / alternating current - and finally the selection of the electrode
  • #5 4798964
    Kukiz18
    Help: 8
    Rate: 38
    welding of steel profiles, approx. 2-3 mm thick,
    the welder is made, transformer on strength, so probably for alternating current, I will add that it is strong. How to transfer the plate to the end (max ampere) is the 4mm electrode, how to stick to the plate and do not tear off in 1 s, it is red
  • #6 4798985
    andk1eltd
    Level 37  
    Help: 396
    Rate: 375
    Generally, the type of electrode used depends on the material that is being welded. Then it is important which welder. And welding is a kaaaawal of solid knowledge. So in everyday life you need to know:
    - basic electrodes - only for DC welding
    - rutile - for e.g. the simplest "made" welding machines.
    And in everyday practice, pink electrodes are used for simple installation of angles and other wires - usually in 2 thicknesses for thin and thicker things :D
    The difference you noticed when switching from red to pink can be found on the Baildon website - the red one needs a lower voltage to strike the arc. And in a "made" welding machine, as a rule, you save on voltage in order to "force" as much current as possible from your core.
    If someone understands at least the basic principles of welding, he can learn a lot from the electrode table itself (it is not necessary to know what rutile is :D )
  • #7 6478206
    Paszczak22
    Rate: 114
    I am also a layman and do not know much about it. Please advise what electrodes to buy to use in simple household chores? (welding of the entrance gate, motor, barriers, etc.) So that it was easy and good. I bought a welder on the 60A-140A allegro, I don't know what current it is for, but I plug it in under 230V, so probably variable. greetings
  • #8 6478292
    niutat
    Level 36  
    Help: 288
    Rate: 760
    Buy yourself ER146 with a thickness of 2.5 and 3.25mm (for thicker welds 4mm), they are enough for the household. In stores they sell them by piece or by weight, so you don't have to buy the whole package.
The discussion revolves around the color coding of welding electrodes, specifically the differences between red and pink coatings. Red electrodes are noted for requiring lower voltage to strike the arc, making them suitable for certain welding machines, while pink electrodes are commonly used for simpler tasks and installations. The choice of electrode depends on the material being welded (e.g., steel profiles) and the type of welder (direct or alternating current). Recommendations for household welding tasks include using ER146 electrodes in thicknesses of 2.5mm and 3.25mm, with 4mm for thicker welds. The importance of understanding the specific electrode types and their applications is emphasized for effective welding.
