[Solved] Replacements for the wall-mounted remote control for the Somfy Dexxo Pro 1000 RTS operator
MarioCraft 1989 8
  • #1 18386464
    MarioCraft
    Do any of you know of any replacements that I could use as a wireless wall remote for controlling a garage door fitted with a Somfy Dexxo Pro 1000 RTS operator? I would like this remote to look like a regular wall switch, I know I have the option to do it wired but I would prefer radio. If anyone knows of any tried and tested solutions I would appreciate your help.
  • #2 18386885
    ak44
    Help: 106
    Rate: 207
    Remote control manufacturing/selling companies have remote controls with a button output in their offers. You mount a button, e.g. a bell button, and insert the remote control into the box.
    I also have a Somfy just a different type, there was no problem. They said to come over with the original remote then they will pick something up.
  • #4 18387764
    MarioCraft
    Not really a zamel, I have a cable and can connect a normal bell, I'm looking for something more like a wall-mounted remote control. There are plenty of these on eBay, but not for this particular drive.
  • #5 18387845
  • #6 18387940
    MarioCraft
    Price-wise it cracks me up. Over 200 for a gate opener button is a bit much
  • #7 18387969
  • #9 18390914
    MarioCraft
    I found something like this https://www.pilotydobram.pl/nadajnik-nascienny-radiowy-dwukanalowy-somfy-rts-2-kanalowy , it doesn't look like a light button but ... does the job and in the garage it does not have to look ;) topic to be closed. Thanks for the hints.
    Added after 43 [seconds]: .
The discussion revolves around finding a wireless wall-mounted remote control replacement for the Somfy Dexxo Pro 1000 RTS garage door operator. Users suggest various solutions, including the Zamel RZB-01, which operates at 868MHz and offers multiple mounting options. Some participants express concerns about the high cost of dedicated remote controls and propose modifying a radio-controlled alarm system to work with the garage door. A user also shares a link to a dual-channel wall-mounted transmitter compatible with Somfy RTS, which, while not resembling a traditional light switch, serves the intended purpose effectively.
