How to rewrite the Arduino code for a Hall sensor flow meter under Blynk?
MMIchalCC 876 0
  • Need help adapting Hall sensor flow meter code for Blynk
    #1 18390375
    MMIchalCC
    Welcome,
    I'm just starting my IoT adventure and am looking for help with connecting a Hall sensor flow meter ( ebay.co.uk/itm/DN50-G2-Water-Flow...RK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 ) to the Blynk app.
    I hook it up to the D1 mini and the Node MCu - on both it works without a problem. With the Arduino IDE I have the correct readout, however I cannot manage to rewrite the program for the Blynk application.
    My base program is in the appendix.
    I also tried to convert the software from the Instructables project (instructables.com/id/WATER-SUPPLY-ALERT-MONITORING-SYSTEM-Blynk/ ) and leave only the Flow Rate Lit/Min, but unfortunately this is beyond me at the moment.
    Can you advise on this subject?
    Best regards,
    Michal
    • Flow.zip (1.61 KB) You must be logged in to download this attachment.
